Random pausing during playback of MKV's
Two Samsung TV's 46C6900 and 40C5000
Windows 2008 R2 server delivering over gigabit to both TV's
Unsure of issue need help to diagnose?
No idea how to read these outputs from ffmpeg or mediainfo
This works fine no issues at all..
C:\Program Files (x86)\Serviio\lib>ffmpeg -i "D:\working 1.mkv"
nfig
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 6. 0 / 53. 6. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 25. 0 / 2. 25. 0
libswscale 2. 0. 0 / 2. 0. 0
[matroska,webm @ 003e8a00] max_analyze_duration 5000000 reached at 5002000
[matroska,webm @ 003e8a00] Estimating duration from bitrate, this may be inaccur
ate
Input #0, matroska,webm, from 'D:\working 1.mkv':
Duration: 02:41:41.65, start: 0.000000, bitrate: 1536 kb/s
Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x1080, PAR 1:1 DAR 16:9,
23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0.1(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s (default)
title : English DTS 1509kbps
Stream #0.2(eng): Subtitle: [0][0][0][0] / 0x0000 (forced)
title : English
Stream #0.3(eng): Subtitle: [0][0][0][0] / 0x0000
title : English
C:\Program Files (x86)\Serviio\lib>[/code]
The next two fail badly, they play but stutter to certain degrees one will pause every 5 or so seconds and the other is more random.
C:\Program Files (x86)\Serviio\lib>ffmpeg -i "D:\not working 2.mkv
nfig
[matroska,webm @ 01668a40] Estimating duration from bitrate, this may be inaccur
ate
Input #0, matroska,webm, from 'D:\not working 2.mkv':
Duration: 01:41:49.73, start: 0.000000, bitrate: 1536 kb/s
Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x800, PAR 1:1 DAR 12:5, 2
title : english
C:\Program Files (x86)\Serviio\lib>ffmpeg -i "D:\not working 1.mkv"
nfig
[matroska,webm @ 01398a40] max_analyze_duration 5000000 reached at 5002000
[matroska,webm @ 01398a40] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5994/1
25) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'D:\not working 1.mkv':
Duration: 01:23:03.03, start: 0.000000, bitrate: 1536 kb/s
Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x800 [PAR 1:1 DAR 12:5],
title : DTS
What other information is needed, to possbily help out?
Cheers
nfig
ate
title : English
title : English
nfig
ate
title : english
nfig
ate
title : DTS
Cheers
