LG BD-390
Post Tue Aug 10, 2010 8:16 am
Re: LG BD-390
I'll look later but Corba has nothing to do with streaming, it's there only to communicate between console and the server. But I suspect it needs to keep network connection and if it fails, I'd say there is something wrong with your connection keeping steady link - which would also make sense regarding your streams being interrupted.
Obviously this is just a wild shot ;-)
sdt1
Post Tue Aug 10, 2010 6:08 pm
Re: LG BD-390
zip wrote:I'll look later but Corba has nothing to do with streaming, it's there only to communicate between console and the server. But I suspect it needs to keep network connection and if it fails, I'd say there is something wrong with your connection keeping steady link - which would also make sense regarding your streams being interrupted.
Petr,
What machine (renderer) do you recommend that you know works perfectly with your software...not a TV with built in wi-fi/internet, but a separate device like BD player or other? I am thinking of tagging and bagging the LG BD390 for all the grief its caused. Thanks.
Post Wed Aug 11, 2010 5:50 pm
Re: LG BD-390
wow, you really want to return your player to accommodate my sw? I'm honored :-) I think people with the Samsung players are ok, check the experience thread or ask in the forum.
sdt1
Post Thu Aug 12, 2010 8:03 pm
Re: LG BD-390
zip wrote:wow, you really want to return your player to accommodate my sw? I'm honored :-) I think people with the Samsung players are ok, check the experience thread or ask in the forum.
I really would if I cannot get these issues resolved with the LG BD390 player. In my previous post with the debug info, I also listed MediaInfo on an audio encoding that wouldn't play. Now, I have the MediaInfo on a video encode that stops playing mid-stream....this is not a network (LAN) issue because I can replay the same file in fast-forward, and get past the point where it had previously stopped playing -- but then the minute I hit play to resume play, the file stops playing again and returns to the file menu on the player. Here's the MediaInfo:
Complete name :
/***/Covert Affairs/covert.affairs.s01e02.hdtv.xvid-fqm.avi
Format :
AVI
Format/Info :
Audio Video Interleave
File size :
350 MiB
Duration :
42mn 16s
Overall bit rate :
1 159 Kbps
Writing application :
transcode-1.0.4
ID :
0
Format :
MPEG-4 Visual
Format profile :
Advanced Simple@L5
Format settings, BVOP :
Yes
Format settings, QPel :
No
Format settings, GMC :
No warppoints
Format settings, Matrix :
Default (H.263)
Codec ID :
XVID
Codec ID/Hint :
XviD
Duration :
42mn 16s
Bit rate :
988 Kbps
Width :
624 pixels
Height :
352 pixels
Display aspect ratio :
16:9
Frame rate :
23.976 fps
Color space :
YUV
Chroma subsampling :
4:2:0
Bit depth :
8 bits
Scan type :
Progressive
Bits/(Pixel*Frame) :
0.188
Stream size :
299 MiB (85%)
Writing library :
XviD 1.2.1 (UTC 2008-12-04)
ID :
1
Format :
MPEG Audio
Format version :
Version 1
Format profile :
Layer 3
Codec ID :
55
Codec ID/Hint :
MP3
Duration :
42mn 16s
Bit rate mode :
Variable
Bit rate :
128 Kbps
Channel(s) :
2 channels
Sampling rate :
48.0 KHz
Bit depth :
16 bits
Stream size :
47.7 MiB (14%)
Alignment :
Aligned on interleaves
Interleave, duration :
24 ms (0.58 video frame)
And here's another file that I could not fast-forward at all, which played approx. half way through before stopping and returning to the folder tree on the player:
Complete name :
/***/This Is Not My Life/This Is Not My Life S01E04 [Antipode.TheEmpire].mkv
Format :
Matroska
File size :
1.02 GiB
Duration :
43mn 58s
Overall bit rate :
3 320 Kbps
Encoded date :
UTC 2010-08-12 10:31:08
mkvmerge v4.0.0 ('The Stars were mine') built on Jun 6 2010 16:18:42
Writing library :
libebml v1.0.0 + libmatroska v1.0.0
ID :
1
Format :
AVC
Format/Info :
Advanced Video Codec
Format profile :
High@L4.1
Format settings, CABAC :
Yes
Format settings, ReFrames :
4 frames
Muxing mode :
Container profile=Unknown@4.1
Codec ID :
V_MPEG4/ISO/AVC
Duration :
43mn 58s
Nominal bit rate :
3 000 Kbps
Width :
1 280 pixels
Height :
720 pixels
16:9
Frame rate :
25.000 fps
Color space :
YUV
4:2:0
Bit depth :
8 bits
Scan type :
Progressive
0.130
Writing library :
x264 core 98 r1649 20cbe10
Encoding settings :
cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
ID :
2
Format :
AAC
Format/Info :
Advanced Audio Codec
Format version :
Version 4
Format profile :
LC
Format settings, SBR :
No
Codec ID :
A_AAC
Duration :
43mn 58s
Channel(s) :
2 channels
Channel positions :
Front: L R
Sampling rate :
48.0 KHz
Post Fri Aug 13, 2010 6:32 am
Re: LG BD-390
Have you tried other servers, do the files stop playing as well?
sdt1
Post Sat Aug 14, 2010 12:39 am
Re: LG BD-390
zip wrote:Have you tried other servers, do the files stop playing as well?
Yes, Twonky Media Server, and the files play all the way through.
http://www.twonky.com
sdt1
Post Sun Aug 15, 2010 3:52 am
Re: LG BD-390
Petr,
I can't believe I had not figured this out sooner, but it turns out that the LG BD-390 can make LAN SAMBA connections to shared folders on a Mac, Linux, or Windows OS. I tested the SAMBA connection and it works perfectly -- without all the problems I had been having with playback, returning to menu after file ends, out of sync audio/video hiccups, etc. In addition, and I'm not really sure why, the picture quality is crisper. The downside is that you can only view all sub-folders, and there is no sorting by recently added, etc., and no thumbnails or transcoding (if an when Serviio will have a transcoding profile for the LG BD390?), which are very nice features within Serviio. Knowing that a SAMBA connection works flawlessly, would this information help to improve Serviio's compatibility with this player?
Post Sun Aug 15, 2010 8:45 am
Re: LG BD-390
Hi, Samba is completely different protocol so it'll not help much. I'm currently working on removing Corba from the app so will see if you can see some improvement - will send you a beta when it's ready.
Alain
Post Mon Mar 07, 2011 12:40 pm
Re: LG BD-390
I add my experience with LG BD-390 saying it works perfectly with serviio with all my video files (mainly mkv).
The only lack is the ability to play subtitles (in my case they are often embedded in mkv container)
Previous
Return to User experiences
Users browsing this forum: Baidu [Spider] and 18 guests
