WMV1 and Samsung D5500
mykee
Post Wed Nov 23, 2011 8:56 pm
Hi all,
I have D500 TV and I tried play an old WMV files, but I haven't. No supported my file.
Here is ffmpeg -i log:
nfig
Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000
/1) -> 25.00 (25/1)
Input #0, asf, from 'k:\Korcsolyagála Budapest 1 Eurosport.wmv':
    WMFSDKVersion   : 9.00.00.2980
    WMFSDKNeeded    : 0.0.0.0000
    IsVBR           : 0
  Duration: 00:19:20.42, start: 0.000000, bitrate: 699 kb/s
    Stream #0.0(hun): Audio: wmav2, 44100 Hz, 2 channels, s16, 64 kb/s
    Stream #0.1(hun): Video: wmv1, yuv420p, 320x240, 632 kb/s, 25 tbr, 1k tbn, 1
k tbc
Here is with latest ffmpeg:
ffmpeg version N-35057-g2c44aed, Copyright (c) 2000-2011 the FFmpeg developers
  built on Nov 21 2011 02:36:31 with gcc 4.6.2
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
  libavutil    51. 26. 0 / 51. 26. 0
  libavcodec   53. 36. 0 / 53. 36. 0
  libavformat  53. 21. 0 / 53. 21. 0
  libavfilter   2. 49. 0 /  2. 49. 0
  libpostproc  51.  2. 0 / 51.  2. 0
[asf @ 01CD84A0] parser not found for codec wmav2, packets or times may be inval
id.
/1) -> 25.00 (25/1)
    IsVBR           : 0
    Stream #0:0(hun): Audio: wmav2 (a[1][0][0] / 0x0161), 44100 Hz, 2 channels,
s16, 64 kb/s
    Stream #0:1(hun): Video: wmv1 (WMV1 / 0x31564D57), yuv420p, 320x240, 632 kb/
s, 25 tbr, 1k tbn, 1k tbc
I try add this line to profiles.xml like this:
         <!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems-->
         <Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true">
            <Matches container="asf" vCodec="mpeg2video" />
        <Matches container="asf" vCodec="wmv1" aCodec="wmav2"/>
        <Matches container="asf" vCodec="wmv2" />
This will be good for me?
Post Thu Nov 24, 2011 1:09 pm
Re: WMV1 and Samsung D5500
Serviio doesn't distunguish between wmv1 and wmv2 so you'd have to transcode all to mpeg2video.
Like this (somewhere at the bottom of the transcoding config block):
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192">
    <Matches container="asf" />
mykee
Post Thu Nov 24, 2011 3:12 pm
Thanks for solution, I will try it! I have full HD MOV file, and that's is unsupported too. Like your solution I need set to MOV files too your settings? special
Like this:
<Matches container="mov" />
Or can I set a special parameters for HD files (resolution higher than 720x576)?
Update: I tried your settings, but I get "Not supported video codec" message from TV. Like transcode no working with wmv... Server stopped and restarted after I changed file.
Here is my profile from xml:
   <Profile id="7" name="Samsung TV / player (C/D-series)" extendsProfileId="2">
      <Detection>
         <UPnPSearch>
            <FriendlyName>(^TV-\d{2}C\d{3}.*)|(^\[TV\][A-Z]{2}\d{2}D\d{3}.*)</FriendlyName>
            <ModelNumber>(1\.0)|(AllShare1\.0)</ModelNumber>
         </UPnPSearch>
         <HttpHeaders>
            <!-- for BD players -->
            <User-Agent>(.*SEC_HHP_BD-[CD].*)|(.*SEC_HHP_\[HT\][CD].*)</User-Agent>
         </HttpHeaders>
      </Detection>
      <DeviceDescription>
         <ExtraElements>
              &lt;sec:ProductCap&gt;smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:ProductCap&gt;
            &lt;sec:X_ProductCap&gt;smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:X_ProductCap&gt;
           </ExtraElements>
      </DeviceDescription>
      <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.SamsungContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
         <!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
            <Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.2" />
            <Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.2" />
            <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.2" />
            <Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.2" />
         <!-- transcode H264 MP4 files with LPCM audio -->
            <Matches container="mpegts" aCodec="mp2" />
            <Matches container="mp4" aCodec="lpcm" />
            <Matches container="matroska" vCodec="vc1" />
            <Matches container="ogg" vCodec="mpeg4" />
            <Matches container="3gp" aCodec="amrnb" />
         <!-- transcode MKV with MPEG2 video, remux into mpeg2ts -->
         <!-- transcode AVI with AVC video -->
         <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
            <Matches container="flv" />
            <Matches container="ogg" />
            <Matches container="wtv" />
      <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192" >
         <!-- transcode audio only for wmv with wmapro -->
         <Video targetContainer="asf" targetACodec="ac3" aBitrate="256">
            <Matches container="asf" aCodec="wmapro" />
            <Matches container="mp4" />
            <Matches container="flac" />
         </Audio>
Post Thu Nov 24, 2011 4:39 pm
do you actualy close serviio completely or did u try it from console ??
mykee
Post Thu Nov 24, 2011 5:00 pm
Yes, but no helped. But I made my own profile, with a little change (extendsProfileId="1" over extendsProfileId="2"), and add a few options. Here is my profile, and wmv is working now:
<Profile id="21" name="Mykee Samsung TV" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
      <DeviceDescription>
         <ExtraElements>
           </ExtraElements>
      <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192" maxVBitrate="8192" forceVTranscoding="true">
         <Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true" maxVBitrate="8192">
         <Video targetContainer="asf" targetACodec="ac3" aBitrate="256" >
         </Audio>
But I have an MPEG2 file with .mpg name and 1080x1920 full HD avi file what I cannot play yet... How can I change resolution for transcode to smaller? LimitImageResolution will good for transcode?
Just a tip for next version: will help a button to console or a menu with Restart Serviio what restart console, server and service, if possible... :oops:
mykee
Post Fri Nov 25, 2011 7:43 pm
I update my file for Samsung D series, include fix for WMV (for WMV1) and FLV (for VP6) files:
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
      <DeviceDescription>
         <ExtraElements>
           </ExtraElements>
      <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" maxVBitrate="8192">
        <Matches container="mpegts" vCodec="mpeg2video" />
         </Audio>
I wait for resize options to later serviio versions for higher resolution files too. ;)
johnboy
Post Sat Dec 03, 2011 5:13 am
mykee wrote:I update my file for Samsung D series, include fix for WMV (for WMV1) and FLV (for VP6) files:
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
      <DeviceDescription>
         <ExtraElements>
           </ExtraElements>
         </Audio>
Yay worked for .wmv (on C series) cool
Post Sat Dec 03, 2011 7:21 pm
zip wrote:Serviio doesn't distunguish between wmv1 and wmv2 so you'd have to transcode all to mpeg2video.
Seems to me that this will also transcode wmv3/vc1 which the Samsung can play natively so the rule should be:
Can someone confirm that this will transcode wmv1 and wmv2 and play wmv3 natively?
Post Sun Dec 04, 2011 2:08 pm
wmv2 catches all wmn1,wmv2 and wmv3. vc1 is separate matcher.
wehr
Post Sun Mar 04, 2012 12:57 pm
Using your profile i can get wmv to play on Samsung PS51D550, but all my mkv dont play anymore (They did with Samsung C/D profile).
I tried finding lines you changed to write your profile but can't get it to work correctly. So i was wondering if there actually is any way to modify the Samsung C/D profile or your profile to play both file type?
