Help with setting up Cx520
term4
Post Thu Nov 24, 2011 4:57 am
I have 46cx520 and I wasnt successful with making it work with serviio.
It works perfectly with Mezzmo and WMP12.
Serviio sees tv as active, but when I go to tv, I cant see Serviio server
(155.41 KiB) Downloaded 708 times
Post Thu Nov 24, 2011 8:20 am
Re: Help with setting up Cx520
Not sure to understand your network installation...
It seems that Sony TV IP address is 192.168.1.65 and PC IP address is 192.168.1.66.
On serviio console, remove the 178.77.13.115 IP bound (why this value ??), try with empty value or with 192.168.1.66. When you change this value, save and restart serviio service.
Post the same log file after modification.
term4
Post Thu Nov 24, 2011 7:52 pm
yes tv ip is as you mentioned, that thing trying to connect with ip 176 was WMP12, dunno why.
So, i removed all devices, disabled WMP12 streaming, and now i only have 192...65 device in that list which now is detected automatically.
Now i see servio server on TV, but its grey and unaccessible...
EDIT: for some reason that IP 176 keeps comming back, dunno how to solve this
(194.02 KiB) Downloaded 731 times
Post Thu Nov 24, 2011 8:41 pm
wmp wont assign its own IP so something else is causing this random ip, have you got all devices set to static IP addresses on your network? can you go in CMD and run `ipconfig` and paste the info received here, also can you run this tool and paste the info here.
viewtopic.php?f=3&t=3923#p26629
term4
Post Thu Nov 24, 2011 9:09 pm
how to paste from cmd, or copy
dunno much about PC's
how to run that program you mentioned?
term4
Post Thu Nov 24, 2011 9:11 pm
Post Thu Nov 24, 2011 9:20 pm
As much as I use the command console, I never understood why windows made it so difficult to copy or paste information into it.
This recipe also works well for pasting information into a DOS program.
To enable QuickEdit Mode:
1. Open a command prompt/command console
2. Right-click on the title bar
3. Select properties
4. Select QuickEdit Mode
5. Select Save Properties for future windows with same title if you want to keep this change forever. Select Apply Properties for current window only if you only want to enable QuickEdit for this session.
6. Click OK
With QuickEdit Mode Enabled:
To Paste Information Into the Command Console:
1. Place information into the clipboard
2. Right click into the console to paste the information
To Copy Information From the Console into the Clipboard:
1. Click and drag to highlight the information in the console
2. Press ENTER/RETURN key
term4
Post Thu Nov 24, 2011 9:30 pm
thanks for explaining
here is javanic
Exception in thread "main" java.lang.NoClassDefFoundError: ListNic
Caused by: java.lang.ClassNotFoundException: ListNic
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
Could not find the main class: ListNic. Program will exit.
term4
Post Thu Nov 24, 2011 9:32 pm
here is ipconfig
PPP adapter Logosoft:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Logosoft
Physical Address. . . . . . . . . :
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 178.77.9.182(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 0.0.0.0
DNS Servers . . . . . . . . . . . : 217.75.192.10
217.75.192.11
NetBIOS over Tcpip. . . . . . . . : Disabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Realtek RTL8168C(P)/8111C(P) Family PCI-E
Gigabit Ethernet NIC (NDIS 6.20)
Physical Address. . . . . . . . . : 90-E6-BA-30-C1-84
Link-local IPv6 Address . . . . . : fe80::d114:74a5:3e3b:8670%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.66(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 244377274
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-16-2C-69-37-90-E6-BA-30-C1-84
217.75.192.11
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter 6TO4 Adapter:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
IPv6 Address. . . . . . . . . . . : 2002:b24d:9b6::b24d:9b6(Preferred)
Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
217.75.192.11
Tunnel adapter isatap.{28CCE25A-2DDF-47D9-A546-6DB9FE8B3F65}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Tunnel adapter isatap.{BC4B72A5-E16F-4ADD-A9B0-DE3EA9DE4F44}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fd:3ca3:18a6:4db2:f649(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::3ca3:18a6:4db2:f649%12(Preferred)
Post Thu Nov 24, 2011 9:37 pm
217.75.192.11
there ya go something called logosoft has created a network interface for that random ip, from memory that relates to a program call logosoft comfort which is designed for connection development (siemans) so u need to uninstall it.
term4
Post Thu Nov 24, 2011 9:39 pm
Logosoft is my ISP :)
And i am connecting via PPPOE, thats why it creates that entry and has to. Else I wouldnt be able to be on intertet :)
Post Thu Nov 24, 2011 9:44 pm
dont know what to suggest, as it seems serviio will not work with that system running as its hogging the network interface and using none standard internal IP.
term4
Post Thu Nov 24, 2011 10:13 pm
ok, tested it, when i disconnect from internet i everything works fine
it is strange though how mezzmo works normally even when connected :S
there should be some workarround for sure
also i cant play avi xvid files if they are larger than 700mb :S
Post Thu Nov 24, 2011 10:22 pm
term4 wrote:ok, tested it, when i disconnect from internet i everything works fine
make a new thread for your file wont play issue please as for mezzmo i cant comment on there setup and ZIP will no doubt look at this thread and hopefully be able to work out a fix.
term4
Post Thu Nov 24, 2011 10:36 pm
Hope Illico might have solution or something :)
any specific place where to open thread for playback issues or this subforum is ok?
Post Thu Nov 24, 2011 10:40 pm
yer in this subforum is perfect then illico will comment when he sees it :)
Post Fri Nov 25, 2011 12:08 pm
Very strange installation!!
One question, what is the device with 192.168.1.254 IP address (default Realtek NIC gateway address)?
I think, it should be better to fix the PC IP address (its seems to be in automatic mode).
So to resume:
Sony TV IP Address : 192.168.1.65
PC(Serviio) Realtek NIC : 192.168.1.66 (must be connected to the TV - via switch if necessary )
PPP adapter Logosoft: 178.77.9.182
Could you try with 192.168.1.66 on the serviio IP Bound field ? (save then restart serviio service and check log file).
Post Fri Nov 25, 2011 12:09 pm
term4 wrote:thanks for explaining
here is javanic
You have to invoke it from the folder whene ListNic.class is stored.
Please retry.
Post Fri Nov 25, 2011 12:27 pm
Illico wrote:Very strange installation!! yer not one most support techs have seen fortunately i have ;)
One question, what is the device with 192.168.1.254 IP address (default Realtek NIC gateway address)? yes exactly
I think, it should be better to fix the PC IP address (its seems to be in automatic mode). nope it in static/prefered mode
So to resume:
PC(Serviio) Realtek NIC : 192.168.1.66 & PPP adapter Logosoft: 178.77.9.182 = the same network adaptor so when logosoft is ON adaptor has 178 ip and when its OFF it has 192 IP
Could you try with 192.168.1.66 on the serviio IP Bound field ? (save then restart serviio service and check log file). wont work
term4
Post Fri Nov 25, 2011 12:53 pm
So to resume:
yeah, it might be strange installation, but it works :)
cant put my router into routed mode, else i would loose IPTV and IP phone :) tried million ways but none worked so have to leave it this way.
192.168.1.254 is my router, Billion model
IP adress of my Lan Card is Static
