[SOLVED] C6000 and aac audio files
drago17
Post Tue Nov 22, 2011 11:53 pm
hello!
i have a c6000 samsung tv (it cant play aac audio).
in the settings of profile i choose "samsung tv/player (c/d series)", with transcodific enabled, but when i try to play the file (mkv with aac audio) the tv tell me "audio codec not supported".
If i choose "A series" profile the transcodific work and the tv play the file with the audio...
why i have to choose the "A profile" if i have a C6000?
thanks
Post Wed Nov 23, 2011 12:16 pm
Re: C6000 and aac audio files
can you post ffmpeg -i of the file?
drago17
Post Wed Nov 23, 2011 6:15 pm
this is a report created by mkv info...
is ok?
file.txt
(9.75 KiB) Downloaded 1318 times
Post Wed Nov 23, 2011 9:31 pm
drago17 wrote:this is a report created by mkv info...
is ok?
Profilo h.264: High @L5.1
Profile level 5.1 is not supported, you have to re-encode with lower level or try to change in the header with this tools:http://forum.serviio.org/viewtopic.php?f=17&t=2118
drago17
Post Wed Nov 23, 2011 9:58 pm
level changed to 4.1, but nothing is changed...
profile c/d= audio codec not supported...
profile a= work great!!!
drago17
Post Fri Nov 25, 2011 11:34 am
news?
i tried with other mkv with aac audio and the result is the same...
with the "samsung a series" the audio work, but not the rewind and fast-forward.
with the "b Series" the result is "codec audio not supported".
thank for all helps!
Post Fri Nov 25, 2011 1:27 pm
A series profile transcodes everything, B only remuxes - therefore uses the original data. It seems there is something wrong with how the file has been encoded.
drago17
Post Fri Nov 25, 2011 1:55 pm
and "c series"?
Post Fri Nov 25, 2011 2:05 pm
the same
drago17
Post Fri Nov 25, 2011 2:21 pm
but this problem occurs with all files with AAC audio.
so the only way to see them is to use the profile "A" even though my tv is "C"?
Post Fri Nov 25, 2011 2:37 pm
AAC is normally supported audio format of the TV, so it's something specific to your files. You could set up transcoding files with aac to ac3.
drago17
Post Fri Nov 25, 2011 3:35 pm
zip wrote:You could set up transcoding files with aac to ac3.
can you explain me what i have to do?
thanks
Post Fri Nov 25, 2011 3:55 pm
Find this in the C/D profile:
<!-- transcode H264 MP4 files with LPCM audio -->
                <Matches container="mpegts" aCodec="mp2" />
                <Matches container="mp4" aCodec="lpcm" />
                <Matches container="matroska" vCodec="vc1" />
                <Matches container="ogg" vCodec="mpeg4" />
                <Matches container="3gp" aCodec="amrnb" />
and replace it with
                <Matches container="matroska" vCodec="h264" aCodec="aac" />
drago17
Post Sat Nov 26, 2011 11:14 am
NOW IS GREAT!!!
but for my curiosity, what did you do??? :?: :?: :?:
Post Sat Nov 26, 2011 1:55 pm
added this line
which transcodes aac audio to ac3 in every mkv file with h264 video.
drago17
Post Mon Nov 28, 2011 5:10 pm
Ok, great.
you can replace the title of the topic with the "SOLVED" mark!
Thank you so much!
drago17
Post Thu Feb 02, 2012 11:41 pm
Re: [SOLVED] C6000 and aac audio files
after an update i have to replace the "profile" files whit this?
Post Fri Feb 03, 2012 12:18 pm
yes, add the line again. there should also be a .bak profiles file in the config folder with your profiles version before update.
drago17
Post Thu Nov 22, 2012 9:12 pm
if i got x264 video and aac audio how can i fix?
thanks
drago17
Post Sat Apr 09, 2016 4:10 pm
in the last version (1.6.1) the file "profile" is totally changed... how its work? thanks in advance
Users browsing this forum: Baidu [Spider] and 17 guests
