Cannot read file
collider
Post Tue Nov 22, 2011 3:15 am
Cannot read file
Hi there,
I'm using Serviio 0.6.0.1 with a Viera TV. I'm getting "Cannot read file" for everything except 1 MP4 file and some FLVs. The strange thing is I see the thumbnails for the other files, but they simply give me that error.
Serviio profile is correctly set to Panasonic Viera, and I've updated the logging to DEBUG but I don't even see an entry for the files it cannot read, it's as if it never gets to Serviio. However, it consistently plays the MP4 and FLVs without problem, I see the FFMPEGWrapper entries in the logs and they always play fine.
I'm on a wired network.
I can post the log, but it has an awful lot of file references, including library updates where it scans all the files (both the ones that play and the ones that don't). I basically see no errors and am very confused.
I even updated FFMpeg in lib to see if that changed anything, but it doesn't.
Any advice on anything else to check?
Thanks a lot - I'd really love to get this working.
-collider
Post Tue Nov 22, 2011 9:56 am
Re: Cannot read file
What is your Panasonic reference model ? Could you check this link?)
Could you provide information about some files that not play (ffmpeg -i and MediaInfo) (see link) ?
collider
Post Tue Nov 22, 2011 4:26 pm
I believe the TV is a TC-L42E30 although I'm not at home right now to confirm. It doesn't appear in Device Spy as I was checking that this weekend.
I will also share some output from ffmpeg -i when I get home, definitely.
I'm curious about the logic within Serviio though. Should I see FFMPEGWrapper entries in the logs for items the TV can't read? Point being, does the ffmpeg -i output really factor into the problem if ffmpeg is never being called?
Will post those details tonight - thanks Illico!
-collider
Post Tue Nov 22, 2011 7:46 pm
collider wrote:I believe the TV is a TC-L42E30 although I'm not at home right now to confirm. It doesn't appear in Device Spy as I was checking that this weekend.
I suppose its PANASONIC TX-L42E30E model.
Seems that AVCHD et DivX are not supported over DLNA
collider wrote:I'm curious about the logic within Serviio though. Should I see FFMPEGWrapper entries in the logs for items the TV can't read? Point being, does the ffmpeg -i output really factor into the problem if ffmpeg is never being called?
"ffmpeg -i" and MediaInfo are used to identify the movie source codec/formats.
collider
Post Tue Nov 22, 2011 8:01 pm
I appreciate that, and will definitely share the output. My only thought was that I didn't see any failed ffmpeg calls in the logs, so was wondering how much detail Serviio would show if it was a transcoding failure vs. something else.
Thanks again!
collider
Post Fri Nov 25, 2011 1:28 am
I confirmed the television model is: TC-L42E3 (not the E30 as I originally thought) which appears to have the following certification: http://certification.dlna.org/certs/REG62367504.pdf
The TV is running the latest software version 1.300
Here's info from ffmpeg a file that gives "Cannot read file":
ffmpeg version N-34906-g4e7b3ef, Copyright (c) 2000-2011 the FFmpeg developers
  built on Nov 16 2011 12:39:54 with gcc 4.6.2
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enab
le-libschroedinger --enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
  libavutil    51. 25. 0 / 51. 25. 0
  libavcodec   53. 34. 0 / 53. 34. 0
  libavformat  53. 20. 0 / 53. 20. 0
  libavfilter   2. 48. 1 /  2. 48. 1
  libpostproc  51.  2. 0 / 51.  2. 0
[mpeg4 @ 0000000001BC8310] Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'v:\wont_play.avi':
  Duration: 00:11:05.04, start: 0.000000, bitrate: 1446 kb/s
    Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 720x416 [SAR 1:1 DAR 45:26], 25 tbr, 25 tbn, 25 tbc
    Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 192 kb/s
I tried a few new files, and got some that play video but not audio. Here's one of those:
[dca @ 0000000001BD6C60] Number of channels changed in DCA decoder (6 -> 2)
Input #0, matroska,webm, from 'v:\video_but_no_audio.mkv':
  Duration: 01:08:59.96, start: 0.000000, bitrate: 6801 kb/s
    Chapter #0.0: start 0.000000, end 845.803000
      title           : 00:00:00.000
    Chapter #0.1: start 845.803000, end 1211.627000
      title           : 00:14:05.803
    Chapter #0.2: start 1211.627000, end 1977.434000
      title           : 00:20:11.627
    Chapter #0.3: start 1977.434000, end 2746.911000
      title           : 00:32:57.434
    Chapter #0.4: start 2746.911000, end 3399.021000
      title           : 00:45:46.911
    Chapter #0.5: start 3399.021000, end 4139.969000
      title           : 00:56:39.021
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, stereo, s16, 1536 kb/s (default)
Also, I wonder if my Serviio database is simply corrupt? When I added the path to the new files, it seems to have created 3 entries for each of them. I've no idea how to fix this?
Post Fri Nov 25, 2011 10:15 am
are u running on linux by any chance?
collider
Post Fri Nov 25, 2011 2:50 pm
Nope, Windows 7, why? Would Linux help? :)
Post Fri Nov 25, 2011 3:08 pm
the first one might be corrupt due to:
collider
Post Fri Nov 25, 2011 7:09 pm
I noticed that on a lot of files that play fine locally with VLC, MPC, etc. I tried googling but it seems like a really common issue.
Can you give me an ffmpeg command that serviio uses so I can try running manually? I was able to transcode the file that didn't play into a couple different vcodec/acodec formats without issue.
collider
Post Mon Nov 28, 2011 12:37 am
Was testing some more files, here's another that gives "Cannot read file":
Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/2733) -> 23.98 (2997/125)
Input #0, avi, from 'v:\wont_play_2.avi':
    encoder         : VirtualDubMod 1.5.10.2 (build 2540/release)
  Duration: 01:29:27.28, start: 0.000000, bitrate: 1030 kb/s
    Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 624x336 [SAR 1:1 DAR 13:7], SAR 21:26 DAR 3:2, 23.98 tbr, 23.98 tbn, 23.98 tbc
    Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, stereo, s16, 192 kb/s
And here are 2 that play but have no audio:
Input #0, matroska,webm, from 'v:\video_but_no_audio_2.mkv':
  Duration: 02:08:46.63, start: 0.000000, bitrate: 9721 kb/s
    Chapter #0.0: start 0.000000, end 253.587000
    Chapter #0.1: start 253.587000, end 518.309000
      title           : 00:04:13.587
    Chapter #0.2: start 518.309000, end 971.929000
      title           : 00:08:38.309
    Chapter #0.3: start 971.929000, end 1303.135000
      title           : 00:16:11.929
    Chapter #0.4: start 1303.135000, end 2002.459000
      title           : 00:21:43.135
    Chapter #0.5: start 2002.459000, end 2508.798000
      title           : 00:33:22.459
    Chapter #0.6: start 2508.798000, end 2878.000000
      title           : 00:41:48.798
    Chapter #0.7: start 2878.000000, end 3220.592000
      title           : 00:47:58.000
    Chapter #0.8: start 3220.592000, end 3886.674000
      title           : 00:53:40.592
    Chapter #0.9: start 3886.674000, end 4379.709000
      title           : 01:04:46.674
    Chapter #0.10: start 4379.709000, end 4847.885000
      title           : 01:12:59.709
    Chapter #0.11: start 4847.885000, end 5178.965000
      title           : 01:20:47.885
    Chapter #0.12: start 5178.965000, end 5513.383000
      title           : 01:26:18.965
    Chapter #0.13: start 5513.383000, end 6143.637000
      title           : 01:31:53.383
    Chapter #0.14: start 6143.637000, end 6652.688000
      title           : 01:42:23.637
    Chapter #0.15: start 6652.688000, end 6733.936000
      title           : 01:50:52.688
    Chapter #0.16: start 6733.936000, end 7090.875000
      title           : 01:52:13.936
    Chapter #0.17: start 7090.875000, end 7191.601000
      title           : 01:58:10.875
    Chapter #0.18: start 7191.601000, end 7316.434000
      title           : 01:59:51.601
    Chapter #0.19: start 7316.434000, end 7726.636000
      title           : 02:01:56.434
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1040, SAR 1:1 DAR 24:13, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), s16, 1536 kb/s (default)
    Stream #0:2(eng): Subtitle: text
Input #0, matroska,webm, from 'v:\video_but_no_audio_3.mkv':
  Duration: 01:32:20.45, start: 0.000000, bitrate: 10166 kb/s
    Chapter #0.0: start 0.000000, end 251.793000
    Chapter #0.1: start 251.793000, end 763.721000
      title           : 00:04:11.793
    Chapter #0.2: start 763.721000, end 1046.796000
      title           : 00:12:43.721
    Chapter #0.3: start 1046.796000, end 1196.737000
      title           : 00:17:26.796
    Chapter #0.4: start 1196.737000, end 1587.294000
      title           : 00:19:56.737
    Chapter #0.5: start 1587.294000, end 1655.696000
      title           : 00:26:27.294
    Chapter #0.6: start 1655.696000, end 1957.831000
      title           : 00:27:35.696
    Chapter #0.7: start 1957.831000, end 2173.046000
      title           : 00:32:37.831
    Chapter #0.8: start 2173.046000, end 2411.993000
      title           : 00:36:13.046
    Chapter #0.9: start 2411.993000, end 2672.211000
      title           : 00:40:11.993
    Chapter #0.10: start 2672.211000, end 3186.517000
      title           : 00:44:32.211
    Chapter #0.11: start 3186.517000, end 3408.614000
      title           : 00:53:06.517
    Chapter #0.12: start 3408.614000, end 3535.574000
      title           : 00:56:48.614
    Chapter #0.13: start 3535.574000, end 3780.694000
      title           : 00:58:55.574
    Chapter #0.14: start 3780.694000, end 4304.759000
      title           : 01:03:00.694
    Chapter #0.15: start 4304.759000, end 4493.322000
      title           : 01:11:44.759
    Chapter #0.16: start 4493.322000, end 4724.219000
      title           : 01:14:53.322
    Chapter #0.17: start 4724.219000, end 4889.802000
      title           : 01:18:44.219
    Chapter #0.18: start 4889.802000, end 5068.230000
      title           : 01:21:29.802
    Chapter #0.19: start 5068.230000, end 5540.451000
      title           : 01:24:28.230
I really love Serviio and would be more than happy to help debug these issues. I can try commands manually, recompiling libraries, whatever it takes. My family would be so grateful if we got this working. :)
Thanks again,
-collider
Post Mon Nov 28, 2011 7:33 am
First file try renaming it to .mp4 if not then it looks like it maybe corrupt. The other 2 file need all of the chapter infomation removed from them using something like mkvmerge and then they should play.
ZIP/ILLICO - does the panasonic profile support DTS audio?
Post Mon Nov 28, 2011 8:15 am
Cerberus wrote:ZIP/ILLICO - does the panasonic profile support DTS audio?
All DTS tracks are transcoded into AC3
Post Mon Nov 28, 2011 10:36 am
thanks illico that what i thought. :)
collider
Post Mon Nov 28, 2011 2:53 pm
Interesting, I was wondering if the chapters were causing a problem!
Thanks for your suggestions Cerberus, I'll give them a whirl at home tonight!
Post Mon Nov 28, 2011 3:03 pm
your very welcome :)
Post Mon Nov 28, 2011 3:37 pm
Could you also provide MediaInfo tool result of these files ? (see signature links)
collider
Post Mon Nov 28, 2011 3:45 pm
Definitely. Will do so tonight. Thanks Illico!
ssccoorrcchhiioo
Post Fri Jan 27, 2012 6:54 pm
I had no luck getting the previously supplied Viera config to work and was hoping this thread would come up with a solution. I am completely new to Serviio and not that deeply experienced in codecs but eventually I created the attached profile.
The manual for the TV says DLNA is compatible with:
SD-Video files (ver 1.3)
AVCHD compatible files
MP4 (video codec H.264 + audio codec MP3/AC3/LPCM)
MKV (ditto)
MPEG-2 PS
MPEG-2 TS
I ignored the SD-Video & AVCHD. It seems that Serviio cannot transcode TO MP4 or Matroska containers. So the rules I tried to set up were:
- If it is MP4 or Matroska container (H.264 video & valid audio) then leave it.
- If it is MPEG-2 PS or MPEG-2 TS with valid audio then leave it.
By trial-and-error I discovered that MPEG-2 version 1 doesn't work, so added that into the rules.
Attached is the profile that I ended up with and it plays everything I need.
Note:
- You'll need to set your own attribute for "ID" in the opening <Profile> tag.[/list]
- There might be some <Matches> which cannot happen (combos of container with video codec) - as I said, I'm no expert in this. Hopefully I haven't missed out combos which DO happen.
- This is on Win 7 64 bit, with Shark007's Windows Codecs installed as my primary set of codecs
Would be nice to hear if this helps anyone.
James
TC-L42E3Profile.xml
(4.83 KiB) Downloaded 806 times
collider
Post Fri Jan 27, 2012 7:05 pm
Thanks ssccoorrcchhiioo - I meant to get further deetails into this thread but time was in short supply. Will reassess tonight. Appreciate you sharing your profile! Did you see 100% playability of your files with it?
Return to Panasonic
Users browsing this forum: Baidu [Spider] and 2 guests
