Help with a profile
bonafied
Post Wed Aug 11, 2010 7:49 pm
Help with a profile
Hi!
I need some help creating a profile that works with my Samsung UE55B7070.
I'm running Serviio on a Imac 10.6.4.
The only profile I got working with my TV is the Samsung WiseLink Pro C-series.
But I cant get it to transcode mkw with DTS to AC3.
I also need some help down sampling 6 channels AC3 audio to 2 channels.
Well, thats about it.
With kind regards
/n00b Martin
Post Wed Aug 11, 2010 11:24 pm
Re: Help with a profile
You should use Samsung B-series (see the B in the TV model name). That has got dts -> ac3 transcoding setup.
bonafied
Post Thu Aug 12, 2010 7:58 pm
Well, I get fileformat not suported.
mkv file.
Post Fri Aug 13, 2010 6:34 am
post results of ffmpeg -i "<your mkv file>" and also detailed log of when you try to play the file.
jescar50dx
Post Wed Aug 18, 2010 12:53 am
I'm having the same issue with my LG TV. If I use the Samsung B series I get invalid file format on MKV files. If I use Samsung series C, the video plays ok but no Audio. The audio is DTS 6 channel.
