Sony Bravia 2011 Series
tagini
Post Mon Nov 28, 2011 11:24 pm
Re: Sony Bravia 2011 Series
Setup Serviio to run under "serviio" user, following the daemon setup guide.
Alas, I still receive thesame error:
2011-11-29 00:19:25,472 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/198.24.116.59, Profile=Sony Bravia TV 2011'
2011-11-29 00:19:25,472 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2011-11-29 00:19:25,473 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2011-11-29 00:19:25,473 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2011-11-29 00:19:25,474 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2011-11-29 00:19:25,477 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'IPAddress=/198.24.116.59, Profile=Sony Bravia TV 2011'
2011-11-29 00:19:25,477 DEBUG [VideoDeliveryEngine] Delivering file 'avatar.2009.1080p.bluray.x264.mkv' using transcoding
2011-11-29 00:19:25,478 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/198.24.116.59, Profile=Sony Bravia TV $
2011-11-29 00:19:25,479 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2011-11-29 00:19:25,483 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /var/media/fileserver/avatar.2009.1080p.bluray.x264.mkv
2011-11-29 00:19:25,484 DEBUG [ProcessExecutor] Starting ffmpeg -i /var/media/fileserver/avatar.2009.1080p.bluray.x264.mkv -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec$
2011-11-29 00:19:25,663 WARN  [ProcessExecutor] Process ffmpeg has a return code of 134! This is a possible error.
2011-11-29 00:19:25,664 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2011-11-29 00:19:25,986 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
        at org.serviio.delivery.resource.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:117)
        at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:93)
        at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:121)
        at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:116)
Post Tue Nov 29, 2011 8:33 am
Do you have enough space in your temporary folder?
tagini
Post Tue Nov 29, 2011 8:44 am
Illico wrote:Do you have enough space in your temporary folder?
Yes, I have 25gb free.
NX3
Post Tue Nov 29, 2011 8:05 pm
tagini wrote:Yes, I have 25gb free.
How big is the source file ?
tagini
Post Tue Nov 29, 2011 11:52 pm
+-14gb
But never mind all of this. By searching for the return code 134 of ffmpeg, I stumbled upon an other thread here (lost the link, sorry).
It seems that I had ffmpeg ver 0.5.1, which does not seem to go well with some setups. Updated to the latest (0.8.7) and it works fantastic!
As a sidenote, since the Ubuntu/Debian repositories are where I got ver 0.5.1 of ffmpeg from, they are obviously outdated and should not be used.
A big thanks to all helpful people here, and a big cheer to the whole Serviio team!
Post Wed Nov 30, 2011 8:18 am
tagini wrote:Updated to the latest (0.8.7) and it works fantastic!
Cool, topic solved.
johnboy
Post Sat Dec 03, 2011 12:31 am
NX3 wrote:
Lowlander wrote:Should the 0.6 Bravia 2011 profile be able to handle AVI (mpeg4/mp3) without video transcoding? I have got quite a few of them, and they only started playing after I added a matching rule for mpeg4/mp3 to the transcode-anything-the-tv-can't-play-to-mpeg2/ac3 section of the profile.
To full understand, these aren't xvid or divx video codec AVI but mpeg4 something ? Can you clarify exactly what codec ? All the AVI's I have are xvid with mp3 but I had some test samples of other and they are working well with the 2011 profile.
I had the same issue with the profile that came when i Installed 0.6.0.1 (my first time with Serviio) and AVIs. I added the AVI to the last video section line (added the last line shown in the code below) then all was good.
<Matches container="asf" />
<Matches container="mp4" />
<Matches container="flv" />
<Matches container="wtv" />
<Matches container="ogg" />
<Matches container="avi" />
I really like Serviio! If not, I wouldn't have signed up so I could post. I didn't see the answer to the AVI details question from earlier, so I'll put my AVI details:
video codec DX50 name DivX 5.x/6.x
MPG4
NVOP PVOP BVOP PB
audio codec 0x0055 MPEG-1 layer 3
[ISFT] VirtualDubMod 1.5.10.2 (build 2540/release)
[JUNK] VirtualDubMod build 2540/release
[USER] DivX503b1393p
[USER] XviD0050
File Length Correct
DivX Style "packed bitstream" AVI
OpenDML (AVI v2.0)
Interleave: 1 vid frame (42 ms), preload=504
Audio frames: Aligned on interleaves
Video: 668 MB (83.56%)
Audio: 124 MB (15.54%)
AVI Overhead: 7.16 MB (0.90%)
Hope it helps
NX3
Post Sat Dec 03, 2011 11:22 am
johnboy, not sure I know what your question is ? If you have the latest version of serviio installed and a 2011 Sony tv then AVI will play natively, you don't need to edit the profile. If you have a 2010 model or previous, they are transcoded.
What model sony tv have you got ? Can you clarify what is or isn't happening ?
johnboy
Post Sat Dec 03, 2011 11:57 am
NX3 wrote:johnboy, not sure I know what your question is ? If you have the latest version of serviio installed and a 2011 Sony tv then AVI will play natively, you don't need to edit the profile. If you have a 2010 model or previous, they are transcoded.
I read the thread and didn't see an answer to the AVI details question so I tried to give my AVI details. I have a fresh from the store (1 week) KDL-55HX729 and installed Serviio v 0.6.0.1 about 5 days ago. This was a new install on a machine that had never had Serviio before, not an upgrade.
I have seen the datasheet that shows AVI support but the AVI files I had didn't show up.
I selected Sony Bravia TV 2011 for the profile. The device name populated correctly. I have transcoding enabled. The server was working, but my AVIs were not visible. I modified the profile similar to what Lowlander had done. In your post you asked about the AVI being mpeg4 or something. So I ran a program to get more details and posted.
I guess my question would be why didn't those AVIs show up with the Sony Bravia TV 2011 profile. When I opened the xml, I noticed that at the bottom catch all files area, AVI wasn't on the list. I added it and then my AVIs worked. I was mostly posting that the profile modification allowed me to view the AVIs.
EDIT: One thing it could be is that I think for native divx stuff there's something to do in the Sony menu with VOD registration. I never did that.
I also had to do edit the profile for my Samsung UN32C6500 profile for WMV.
NX3
Post Sat Dec 03, 2011 3:16 pm
Hmm since 0.6 AVI play natively, you should have to update the profile.
As per this posting, this is the latest profile that works. Is this as per your sony profile 2011 settings ?
viewtopic.php?f=11&t=3662
I don't think the divx vod registration makes much difference really unless your doing divx with drm from a vod source.
johnboy
Post Sun Dec 04, 2011 4:42 am
Yes that is the same as my profile, except that at
<!-- All Others video/audio codec will be transcoded into mpeg2ts, mpeg2video and ac3 audio -->
<!-- expected profile MPEG_TS_SD_EU/MPEG_TS_SD_NA/MPEG_TS_SD_KO -->
<Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="192">
I added that last AVI line.
My model number KDL-55HX729 isn't on that list of 2011 Bravia models. I don't see any 729s on there. Mine has a different software than whats listed, perhaps its been updated, I have PKG3.507AAA
Post Sun Dec 04, 2011 8:37 am
johnboy wrote:My model number KDL-55HX729 isn't on that list of 2011 Bravia models. I don't see any 729s on there. Mine has a different software than whats listed, perhaps its been updated, I have PKG3.507AAA
I did not have check all Sony device model, I suppose that your HX729 should be a 2011 model.
Could you check that linkand provide GetProtocolInfo result?
Post Mon Dec 05, 2011 8:20 am
Thanks Johnboy for the HX729 GetProtocolInfo result : http://wiki.serviio.org/doku.php?id=dev ... port&#sony
In fact this the same that other 2011 models (NX720,EX720) without AVI/DIVX format and Digital Transmission Content Protection (dtcp):
http-get:*:video/x-msvideo:*,
http-get:*:video/x-divx:*,
http-get:*:video/divx:*,
http-get:*:video/avi:*,
http-get:*:application/x-dtcp1;*
Are you in US or CA region?
NX3
Post Mon Dec 05, 2011 9:45 am
It looks like a Sony USA model from 2011, strange it lacks avi / divx support give all other models from 2011 appear too.
Johnboy, to check, you have updated your firmware to the latest version ? 10/10/2011 Version PKG3.507AAA ?
johnboy
Post Tue Dec 06, 2011 1:57 am
It is a US 2011 model. The software I have is PKG3.507AAA.
patters
Post Fri Dec 23, 2011 2:40 am
Not sure why this isn't being detected by the 2011 profile. The regex should catch it, so if it's not working then maybe this particular TV doesn't support UPnPSearch properly.
The regex is:
<FriendlyName>BRAVIA KDL-\d{2}([A-Z]X\d2\d|CX400).*</FriendlyName>
So "BRAVIA KDL-(two digits) then ((any capital letter, X , any single digit, number 2, any single digit) OR CX400)" followed by any other characters to catch whitespace
NX3
Post Sun Feb 26, 2012 11:28 am
NX3 wrote:I've tested a lot of AVI files, most XVID or DIVX work regardless of the following settings:
- Writing application : transcode-1.0.6
- Writing library : XviD 1.2.0
- Format settings, Matrix : Default (H.263)
- Muxing mode: n/a
The only constant I can find is ' transcode-1.0.6' generated files are usually a problem for the tv but its not the only generator that has caused an issue. As far as a solution goes, thats going to be tough to filter out and maybe the best solution is all AVI files are transcoded to mpeg as per the 2010 profile ?
This problem comes up often and no just with Sony tvs and the issue for Sony, LG and Panasoinc is the way 'transcode' is writing the AVI files. The work around is to set for Sony in Serviio, as the 2010 profile so they are transcoded to mpeg2.
Or another work around - run the file through Virtualdub in 'direct stream copy' for both audio and video and that appears to fixes it. It took about 5 seconds for a 30min xvid so its quick. It doesn't change the formats etc which leads me think this is an error with the way in which some software is setting the headers etc. (Virtualdub highlights the following error with the original (non playing) files - "A non-zero wBitsPerSample value was detected in the MP3 audio format structure. This has been corrected in-memory to zero for better compatibility with commonly installed MP3 audio codecs.")
koan00
Post Wed Feb 29, 2012 2:43 pm
I'm not sure if this is the same problem the other user is having. My problem is that no avi files show up when I browse serviio. I can see and play mp4 and mkv, but not avi. The AVI files do show up and play fine when i browse using a DirecTV device.
ffmpeg -i shows the files are all divx/xvid with either mp3 or AC3 audio streams. I can post the full output if needed.
I have a US/2011 KDL55NX720 with the latest firmware and a fresh install of serviio 0.6.2. TV is properly detected as a 2011 Sony Bravia.
Post Wed Feb 29, 2012 3:13 pm
koan00 wrote:I'm not sure if this is the same problem the other user is having. My problem is that no avi files show up when I browse serviio. I can see and play mp4 and mkv, but not avi. The AVI files do show up and play fine when i browse using a DirecTV device.
yes please can i have the output, but i suspect there broken avi files and you will need to follow this wiki.
http://wiki.serviio.org/doku.php?id=fix_avis
koan00
Post Wed Feb 29, 2012 9:31 pm
Here are 2 of them:
k@MotherPenguin:/home/mp3/Video/Curious George$ ffmpeg -i Curious\ George\ 1.avi
ffmpeg version git-2012-02-28-34210e8 Copyright (c) 2000-2012 the FFmpeg developers
  built on Feb 28 2012 16:16:22 with gcc 4.6.2
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid
  libavutil      51. 41.100 / 51. 41.100
  libavcodec     54.  4.100 / 54.  4.100
  libavformat    54.  1.100 / 54.  1.100
  libavdevice    53.  4.100 / 53.  4.100
  libavfilter     2. 62.101 /  2. 62.101
  libswresample   0.  7.100 /  0.  7.100
Input #0, avi, from 'Curious George 1.avi':
    encoder         : VirtualDubMod 1.5.4.1 (build 2178/release)
    IAS1            : English
  Duration: 00:14:58.06, start: 0.000000, bitrate: 2927 kb/s
    Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 720x544 [SAR 1:1 DAR 45:34], 23.98 tbr, 23.98 tbn, 23.98 tbc
    Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, stereo, s16, 192 kb/s
k@MotherPenguin:/home/mp3/Video/Curious George$ ffmpeg -i Curious.George.2.Follow.That.Monkey.2009.avi
Input #0, avi, from 'Curious.George.2.Follow.That.Monkey.2009.avi':
    encoder         : VirtualDubMod 1.5.10.2 (build 2540/release)
  Duration: 01:16:47.84, start: 0.000000, bitrate: 1274 kb/s
    Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 624x352 [SAR 1:1 DAR 39:22], 25 tbr, 25 tbn, 25 tbc
    Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 112 kb/s
