Serviio UPnP e QNAP NMP-1000
valix85
Post Wed Nov 30, 2011 12:38 am
Hello i have a qnap nmp-1000 but i can't see serviio UPnP resources with my qnap. I have just tray to disable my windows firewall but i can't see serviio too.
what can i do for play my computer video into my tv with qnap nmp-1000?
how i can enable UPnP for serviio in windows 7?
thank you
Post Wed Nov 30, 2011 11:41 am
Re: Serviio UPnP e QNAP NMP-1000
My device doesn't see Serviio
This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console or pass system variable serviio.boundAddr including the IP address when starting the server.
Also make sure that TCP port 8895 and UDP 1900 are open in your firewall.
If you are on a Linux based OS, make sure you set up multicast routes properly.
If on Windows, you can push Serviio service down in starting order.
valix85
Post Wed Nov 30, 2011 12:17 pm
nothing to do...Servio is UPnP server? or is only a client?
i have set manualli ip address in serviio with mi local machine address (my lan is 172.17.16.x and my pc is 172.17.1.106 and qnap is 172.17.16.99)
in windows i must to start some services?
qnap don't see serviio, but if i use ps3 media server or windows media player qnap see correct, but i don't like these software for my use.
(i had test both firewall than none)
Post Wed Nov 30, 2011 12:37 pm
Serviio is a DLNA server. UPnp is a part of DLNA.
The service is started automatically when windows is started.
Can you post your serviio.log file, it is in the serviio directory in the log folder. Maybe we can see something in the log causing your problem.
Also can you run the script in this thread and post the results.
http://forum.serviio.org/viewtopic.php?f=3&t=3923#p26629
valix85
Post Wed Nov 30, 2011 4:08 pm
2011-11-30 17:04:16,024 INFO  [ServiioConsole] Starting Serviio Console
2011-11-30 17:04:16,289 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-11-30 17:04:23,864 WARN  [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-11-30 17:04:31,179 WARN  [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-11-30 17:04:31,284 INFO  [Messages] Loaded console message bundle for locale: en
2011-11-30 17:04:36,364 INFO  [MediaServer] ------------------------------------------------------------------------
2011-11-30 17:04:36,364 INFO  [MediaServer] Serviio DLNA media streaming server v 0.6.0.1 (rev. 8e4ee98bff12)
2011-11-30 17:04:36,364 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-11-30 17:04:36,364 INFO  [MediaServer] http://www.serviio.org
2011-11-30 17:04:36,364 INFO  [MediaServer] Java 1.6.0_26-Sun Microsystems Inc.
2011-11-30 17:04:36,364 INFO  [MediaServer] OS Windows 7 amd64 6.1
2011-11-30 17:04:36,364 INFO  [MediaServer] File encoding: windows-1252
2011-11-30 17:04:36,364 INFO  [MediaServer] Headless mode enabled: true
2011-11-30 17:04:36,364 INFO  [MediaServer] User home dir: C:\
2011-11-30 17:04:36,364 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2011-11-30 17:04:36,449 INFO  [RestletServer] Starting Restlet server exposed on port 23423
2011-11-30 17:04:36,492 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-11-30 17:04:37,712 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-11-30 17:04:37,724 INFO  [UpdateChecker] Checking if a new version is available
2011-11-30 17:04:37,824 INFO  [ServiioConsole] Leaving Serviio Console
2011-11-30 17:04:38,224 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-11-30 17:04:38,444 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-11-30 17:04:38,579 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-11-30 17:04:38,702 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-11-30 17:04:38,804 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-11-30 17:04:38,914 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-11-30 17:04:39,149 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-11-30 17:04:39,194 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2011-11-30 17:04:39,482 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-11-30 17:04:39,979 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-11-30 17:04:40,174 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-11-30 17:04:40,334 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2011-11-30 17:04:40,374 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2011-11-30 17:04:40,397 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2011-11-30 17:04:40,467 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2011-11-30 17:04:40,502 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2011-11-30 17:04:40,582 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2011-11-30 17:04:40,849 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV 2011' (id=19)
2011-11-30 17:04:41,089 INFO  [ProfilesDefinitionParser] Added profile 'Sony SMP-N100' (id=20)
2011-11-30 17:04:41,104 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-11-30 17:04:41,109 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-11-30 17:04:41,112 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-11-30 17:04:41,112 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-11-30 17:04:41,112 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-11-30 17:04:41,112 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-11-30 17:04:41,112 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1322669081112, LastAccessTime = 1322669081112, getTimeToLiveSeconds() = -1, createTime = 1322669081112 ]
2011-11-30 17:04:41,129 INFO  [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
2011-11-30 17:04:41,129 INFO  [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-11-30 17:04:41,132 INFO  [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
2011-11-30 17:04:41,132 INFO  [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-11-30 17:04:41,132 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-11-30 17:04:41,132 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-11-30 17:04:41,132 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-11-30 17:04:41,132 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-11-30 17:04:41,132 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-11-30 17:04:41,132 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-11-30 17:04:41,132 INFO  [CompositeCacheConfigurator] Parsed regions [thumbnails, online_feeds, local_default, local_resetafterplay]
2011-11-30 17:04:41,132 INFO  [CompositeCacheConfigurator] Finished configuration in 23 ms.
2011-11-30 17:04:41,139 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-11-30 17:04:41,139 INFO  [Device] Created UPnP Device with UUID: 3e6578d2-5a90-3ab6-8ffb-d8ceab95f569, bound address: 172.17.1.106
2011-11-30 17:04:41,154 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files (x86)\Serviio\bin\..\plugins
2011-11-30 17:04:41,154 INFO  [PluginCompilerThread] Started looking for plugins
2011-11-30 17:04:41,249 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-11-30 17:04:41,269 INFO  [WebServer] WebServer starting on port 8895
2011-11-30 17:04:41,274 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-11-30 17:04:41,274 INFO  [EventDispatcher] Starting EventDispatcher
2011-11-30 17:04:41,274 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-11-30 17:04:41,277 INFO  [RendererSearchSender] Searching for Renderer devices
2011-11-30 17:04:41,277 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-11-30 17:04:41,387 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Realtek PCIe GBE Family Controller #2) and address 172.17.1.106, timeout = 0
2011-11-30 17:04:44,909 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-11-30 17:04:45,369 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: it
this is my log file, help me pls
Post Wed Nov 30, 2011 5:40 pm
valix85 wrote:nothing to do...Servio is UPnP server? or is only a client?
Your PC must use the same IP subnet format as your Qnap.
Your PC is 172.17.1.106 and your qnap is 172.17.16.99. Change your PC to 172.17.16.106 and it should work.
From the log file.
valix85
Post Thu Dec 01, 2011 1:23 am
sorry is a write error, device are in the same network 172.17.1.106 e 172.17.1.99, but qnap don't see serviio :(
Post Thu Dec 01, 2011 11:45 am
ok, Is that the full log? I do not see anywhere in the log serviio looking for renderers.
valix85
Post Thu Dec 01, 2011 5:34 pm
yes is full, now the new log is:
2011-11-30 17:05:13,817 INFO  [FeedUpdaterThread] Started looking for information about online feeds
2011-11-30 17:05:13,817 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-11-30 17:05:13,817 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-11-30 19:23:30,026 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file A_Venezia_Muore_Un'Estate.avi [VideoDescription [type=FILM, names=[a venezia muore un'estate, null], year=null, season=null, episode=null]]
2011-11-30 19:23:30,594 INFO  [LibraryAdditionsCheckerThread] Added file 'A_Venezia_Muore_Un'Estate.avi' (title: A_Venezia_Muore_Un'Estate) to Library
2011-12-01 03:28:56,778 INFO  [LibraryAdditionsCheckerThread] Added file 'Big.avi' (title: Big) to Library
2011-12-01 04:42:43,462 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file 5BDivX_-_ITA5D_Abbronzatissimi_2_-_Un_Anno_Dopo_1993.avi [VideoDescription [type=FILM, names=[5b, null], year=null, season=null, episode=null]]
2011-12-01 04:42:43,554 INFO  [LibraryAdditionsCheckerThread] Added file '5BDivX_-_ITA5D_Abbronzatissimi_2_-_Un_Anno_Dopo_1993.avi' (title: 5BDivX_-_ITA5D_Abbronzatissimi_2_-_Un_Anno_Dopo_1993) to Library
2011-12-01 09:31:35,540 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Abbandonata.Dal.Destino.2003.iTALiAN.AC3.DVDRip.XviD.ABSM.avi [VideoDescription [type=FILM, names=[abbandonata dal destino, null], year=2003, season=null, episode=null]]
2011-12-01 09:31:35,614 INFO  [LibraryAdditionsCheckerThread] Added file 'Abbandonata.Dal.Destino.2003.iTALiAN.AC3.DVDRip.XviD.ABSM.avi' (title: Abbandonata.Dal.Destino.2003.iTALiAN.AC3.DVDRip.XviD.ABSM) to Library
2011-12-01 15:00:29,576 INFO  [LibraryAdditionsCheckerThread] Added file 'Abandon.Misteriosi.Omicidi.2002.iTaLiAn.DVDrip.5.1.Divx5.RhM.avi' (title: Abandon) to Library
Post Thu Dec 01, 2011 5:58 pm
ok I missed this in your 1st post.
I use XBMC for my windows 7 DLNA client. See thread for more information
http://forum.serviio.org/viewtopic.php?f=3&t=4217&p=27883#p27883
XBMC can be downloaded from the following url.
http://www.xbmc.org
How long have you had your NMP-1000. When they initially came out, a DLNA server was not in the firmware. Make sure that you have downloaded the current firmware.
valix85
Post Thu Dec 01, 2011 8:14 pm
i have just update my nmp-1000 to last firmware, i check version firmware periodically and iu up to date.
windows 7 have just a UPnP/DLNA server, is not possibole use it with serviio?
i must install another software?
thank you
Post Thu Dec 01, 2011 8:18 pm
I will keep trying to get serviio to work as long as you keep trying. does the IP address for the Qnap show up on the serviio console.
if it does not add it manually and see if it sees serviio then. If it does not try the xbox profile and see if the qnap can see serviio.
valix85
Post Thu Dec 01, 2011 8:45 pm
i try to use media player for see local UPnP/DLNA but media player retrive folder shared by serviio but the content of this folder is empty despite i have shared a local folder... why do it?
Post Thu Dec 01, 2011 8:56 pm
valix85 wrote:i try to use media player for see local UPnP/DLNA but media player retrive folder shared by serviio but the content of this folder is empty despite i have shared a local folder... why do it?
Ok so the media player is seeing serviio but the folder is empty? change the profile to directTV which transcodes everything, restart serviio and see if there is any files in the serviio folder.
valix85
Post Thu Dec 01, 2011 9:18 pm
for media player i did to windows media player :) i have set mi local pc as a direct tv but nothing to do :S
Post Thu Dec 01, 2011 9:32 pm
Can you see the serviio server on the Qnap?
valix85
Post Thu Dec 01, 2011 11:34 pm
ok, now qnap work fine, qnap see shared folder and play correctly without transcodifications, but windows media player don't see the file.
now qnap is added manually and is DLNA GENERIC device type.
i try to add my pc both 172.17.1.106 than 127.0.0.1 and i try to set generic dlna, tv direct and xbox360 but media player don't see folder correct.
wmp see me folder than not exits, ex: "playlist".
how can i resolve it?
for now qnap work fine, i don't know because it before don't work, bho
thanks for your help :)
