Serviio on WHS - HP micro server
psionguy
Post Wed Nov 30, 2011 4:46 pm
Would appresiate some guidance on how to install Serviio on WHS 11, installed on my HP micro server.
Post Wed Nov 30, 2011 5:45 pm
Re: Serviio on WHS - HP micro server
zip wrote:As said before, you have to log into your HP using Remote Desktop and install it using the .exe as you would on a normal PC. It will not appear in the WHS console, because there is not add-in for it (although I'm looking for volunteers).
What I normally do is:
1) copy the .exe on your shared drive, e.g. Public
2) log into your HP using Remote Desktop
3) copy the .exe from Public onto the Desktop (you cannot execute anything from your shares)
4) right-click on the .exe and click Unblock
5) run the .exe
6) after installation open the console and share your drive like: \\Music, \\Videos, etc.
Post Wed Nov 30, 2011 5:54 pm
Post Wed Nov 30, 2011 6:00 pm
Cerberus wrote:erm try this - viewtopic.php?f=17&t=2461
That is for the Add in and does not support WHS 2011 yet.
Post Wed Nov 30, 2011 6:01 pm
yes this i know but the dev also asked for tester with 2011 so he could make it work ;)
