ffmpeg.exe encoutered a problem
jbfarin
Post Mon Dec 05, 2011 2:32 am
Re: ffmpeg.exe encoutered a problem
this help at all.......I only posted what the last part of this log had....I did it right after the error message again came up
2011-12-04 18:27:57,046 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = ONLINE_VIDEO_SOURCES, mediaItemId = 102)
2011-12-04 18:27:57,062 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = EMBEDDED, mediaItemId = 102)
2011-12-04 18:27:57,093 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_10_1.VOB' (title: Life as a House) to Library
2011-12-04 18:27:57,281 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023167494287 from address /192.168.1.7:49153
2011-12-04 18:27:57,593 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: F:\classics\1000831223_-_Deliverance_(1972)_ANiPUNK
2011-12-04 18:27:57,609 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: F:\classics\1000848299_-_National_Lampoons_Dirty_Movie_2011
2011-12-04 18:27:58,046 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2011-12-04 18:27:58,046 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-12-04 18:27:58,046 DEBUG [LocalContentCacheDecorator] Cleared cache (local_default)
2011-12-04 18:27:59,437 DEBUG [LibraryAdditionsCheckerThread] Found file 'EMBER-NLDM.avi', checking if it's already in the Library
2011-12-04 18:27:59,437 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item EMBER-NLDM.avi
2011-12-04 18:27:59,437 DEBUG [MediaItemDAOImpl] Media item EMBER-NLDM.avi doesn't exist in DB yet
2011-12-04 18:27:59,437 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2011-12-04 18:27:59,437 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: F:\classics\1000848299_-_National_Lampoons_Dirty_Movie_2011\EMBER-NLDM.avi
2011-12-04 18:27:59,437 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: F:\classics\1000848299_-_National_Lampoons_Dirty_Movie_2011\EMBER-NLDM.avi
2011-12-04 18:27:59,437 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i F:\classics\1000848299_-_National_Lampoons_Dirty_Movie_2011\EMBER-NLDM.avi
2011-12-04 18:28:00,609 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023183935347 from address /192.168.1.11:49153
2011-12-04 18:28:02,687 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023167494287 from address /192.168.1.11:49153
2011-12-04 18:28:06,718 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve thumbnail for file: F:\classics\1000848299_-_National_Lampoons_Dirty_Movie_2011\EMBER-NLDM.avi
2011-12-04 18:28:06,718 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -ss 120 -i F:\classics\1000848299_-_National_Lampoons_Dirty_Movie_2011\EMBER-NLDM.avi -an -vframes 1 -f image2 pipe:
2011-12-04 18:28:08,468 DEBUG [LibraryManager] Metadata found via extractor EMBEDDED: VideoMetadata [title=EMBER-NLDM, filePath=F:\classics\1000848299_-_National_Lampoons_Dirty_Movie_2011\EMBER-NLDM.avi, fileSize=731245046, audioBitrate=32, audioCodec=MP3, audioStreamIndex=1, bitrate=1071, channels=2, container=AVI, contentType=UNKNOWN, coverImage=org.serviio.library.local.metadata.ImageDescriptor@bfae78, duration=5457, episodeNumber=null, fps=23.976, frequency=48000, h264Level=null, h264Profile=null, height=432, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=MPEG4, videoStreamIndex=0, width=640]
2011-12-04 18:28:08,468 DEBUG [TheMovieDBSourceAdaptor] Searching for movie 'ember' (language: en)
2011-12-04 18:28:09,015 DEBUG [TheMovieDBSourceAdaptor] Found 1 matches
2011-12-04 18:28:09,015 DEBUG [TheMovieDBSourceAdaptor] Searching for movie '1000848299 - national lampoons dirty movie' (language: en)
2011-12-04 18:28:09,359 DEBUG [TheMovieDBSourceAdaptor] Found 0 matches
2011-12-04 18:28:09,375 DEBUG [TheMovieDBSourceAdaptor] Found a suitable movie match, id = 57414
2011-12-04 18:28:09,375 DEBUG [TheMovieDBSourceAdaptor] Retrieving details of movie (movieId = 57414, language = en)
2011-12-04 18:28:09,593 DEBUG [LibraryManager] Metadata found via extractor ONLINE_VIDEO_SOURCES: VideoMetadata [title=Ember Days, filePath=null, fileSize=0, audioBitrate=null, audioCodec=null, audioStreamIndex=null, bitrate=null, channels=null, container=null, contentType=MOVIE, coverImage=null, duration=null, episodeNumber=null, fps=null, frequency=null, h264Level=null, h264Profile=null, height=null, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=null, videoStreamIndex=null, width=null]
2011-12-04 18:28:09,593 DEBUG [VideoService] Adding video into database: Ember Days
2011-12-04 18:28:09,593 DEBUG [FolderDAOImpl] Looking for folder hierarchy 1000848299_-_National_Lampoons_Dirty_Movie_2011
WildRushSykes
Post Mon Dec 05, 2011 5:23 am
Try organising your movies like this
for example....
Avatar (2009).avi
check the openmoviedb for the correct year and label accordingly
jbfarin
Post Mon Dec 05, 2011 5:30 am
how do I do that?
WildRushSykes
Post Mon Dec 05, 2011 7:09 am
Just go to where your movies are and rename them
the openmoviedb link is here
http://www.themoviedb.org/
this is the site which serviio uses to look up thumbnails and metadata
just punch the title of the movie in the search bar and make sure the movie it returns is the right one then rename your file with the exact name and the date in brackets
like
Rise of the Planet of the Apes (2011)
then peform a library refresh and it should fix your issue all my movies are lablelled this way in one folder and ive had all my movies returned correctly with no ffmpeg errors and full metadata :)
Having a look at the log you supplied the way your movies are labeled and organised using 1000848299_-_National_Lampoons_Dirty_Movie_2011\EMBER-NLDM.avi as an example is why ffmpeg is crashing.
just put all your movies in one folder labeled correctly and you SHOULD have no issues :)
My Movies are organised like this....
1TB external hard drive with 1 folder labelled HD Movies 1 then within that folder i have my movies labelled
2 Fast 2 Furious (2003)
5 Days of August (2011)
13 (2011)
and so on
then my other hard drive has a folder named HD Movies 2 with the same file structure
hope this helps
Keep me updated :D
Post Mon Dec 05, 2011 8:02 am
please attach the whole log file, not just a section.
in regards to filename that is unrelated to your problem and can be sorted by using a tool like this one: viewtopic.php?f=17&t=2878
jbfarin
Post Mon Dec 05, 2011 5:16 pm
Ok I will try that but truthfully I don't think that is it because all my movies are on external harddrives and I actually run two different machines ( one a desktop ( the one having issues) and a laptop. I have no issues on the laptop using the exact same external harddrives and the same labeling. I know you might say then why don't I just use my laptop but I can't as that machine goes with me whereever i go so would liek the desktop to be my main machine....Does this all make sense? Seriously, I so appreciate the help...also when I get home I will send the whole log but it is long....
Post Mon Dec 05, 2011 6:01 pm
jbfarin wrote:Ok I will try that but truthfully I don't think that is it because all my movies are on external harddrives and I actually run two different machines ( one a desktop ( the one having issues) and a laptop. I have no issues on the laptop using the exact same external harddrives and the same labeling. I know you might say then why don't I just use my laptop but I can't as that machine goes with me whereever i go so would liek the desktop to be my main machine....Does this all make sense? Seriously, I so appreciate the help...also when I get home I will send the whole log but it is long....
i cant comment yet on why your having issues until i can see the full log. ;)
jbfarin
Post Mon Dec 05, 2011 6:08 pm
ok will do when I get home......thanks...
jbfarin
Post Tue Dec 06, 2011 1:49 am
1-12-05 17:06:03,937 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2011-12-05 17:06:03,937 INFO [ServiioConsole] Starting Serviio Console
2011-12-05 17:06:05,468 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2011-12-05 17:06:06,015 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-12-05 17:07:25,750 INFO [Messages] Loaded console message bundle for locale: en
2011-12-05 17:11:21,765 DEBUG [ApplicationInstanceManager] Shared key matched - new application instance found
2011-12-05 17:11:48,968 DEBUG [ServiioConsole] Retrieving preferred console language
2011-12-05 17:11:49,859 DEBUG [ServiioConsole] Setting console locale to be: en
2011-12-05 17:11:49,859 INFO [Messages] Loaded console message bundle for locale: en
2011-12-05 17:11:51,375 DEBUG [ServiioFrameView] Initializing main frame
2011-12-05 17:11:51,937 DEBUG [ServiioFrameView] System tray is supported
2011-12-05 17:15:17,968 DEBUG [RepositoryView$LibraryStatusCheckerThread] Starting library status checking thread
jbfarin
Post Tue Dec 06, 2011 1:52 am
doubt that helps....been trying for awhile to send but keeps saying file too big no matter what i do...
Post Tue Dec 06, 2011 7:59 am
jbfarin wrote:doubt that helps....been trying for awhile to send but keeps saying file too big no matter what i do...
1. Close serviio console and server
2. Delete the current logs
3. Restart serviio
4. Leave runn for a few mins, try and replicate the error.
5. Close serviio console and server.
6. attach log file here for me to review.
jbfarin
Post Tue Dec 06, 2011 10:33 pm
maybe this?
(2.16 KiB) Downloaded 800 times
Post Wed Dec 07, 2011 7:45 am
again that that an excert i need the FULL log.
jbfarin
Post Wed Dec 07, 2011 3:04 pm
even the attatctment? then I am doing something very wrong....
Post Wed Dec 07, 2011 5:35 pm
log file should look somethig liek this :
Bjur wrote:The log is below. I REALLY hope you can help..
2011-12-01 13:14:40,635 INFO [MediaServer] ------------------------------------------------------------------------
2011-12-01 13:14:40,760 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.0.1 (rev. 8e4ee98bff12)
2011-12-01 13:14:40,760 INFO [MediaServer] Petr Nejedly 2009-2011
2011-12-01 13:14:40,760 INFO [MediaServer] http://www.serviio.org
2011-12-01 13:14:40,760 INFO [MediaServer] Java 1.6.0_29-Sun Microsystems Inc.
2011-12-01 13:14:40,760 INFO [MediaServer] OS Windows Server 2008 R2 amd64 6.1
2011-12-01 13:14:40,760 INFO [MediaServer] File encoding: windows-1252
2011-12-01 13:14:40,807 INFO [MediaServer] Headless mode enabled: true
2011-12-01 13:14:40,807 INFO [MediaServer] User home dir: C:\
2011-12-01 13:14:40,807 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2011-12-01 13:14:40,807 INFO [MediaServer] ------------------------------------------------------------------------
2011-12-01 13:14:44,457 INFO [RestletServer] Starting Restlet server exposed on port 23423
2011-12-01 13:14:45,799 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-12-01 13:15:05,424 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-12-01 13:15:06,547 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-12-01 13:15:06,921 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-12-01 13:15:07,108 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-12-01 13:15:07,233 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-12-01 13:15:07,327 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-12-01 13:15:07,420 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-12-01 13:15:07,654 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-12-01 13:15:07,686 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2011-12-01 13:15:07,888 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-12-01 13:15:08,169 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-12-01 13:15:08,263 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-12-01 13:15:08,341 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2011-12-01 13:15:08,372 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2011-12-01 13:15:08,388 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2011-12-01 13:15:08,434 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2011-12-01 13:15:08,450 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2011-12-01 13:15:08,497 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2011-12-01 13:15:08,653 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV 2011' (id=19)
2011-12-01 13:15:08,793 INFO [ProfilesDefinitionParser] Added profile 'Sony SMP-N100' (id=20)
2011-12-01 13:15:08,949 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-12-01 13:15:09,074 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-12-01 13:15:09,090 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-12-01 13:15:09,090 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-12-01 13:15:09,105 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-01 13:15:09,105 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-12-01 13:15:09,105 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1322741709105, LastAccessTime = 1322741709105, getTimeToLiveSeconds() = -1, createTime = 1322741709105 ]
2011-12-01 13:15:09,183 INFO [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
2011-12-01 13:15:09,183 INFO [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-01 13:15:09,183 INFO [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
2011-12-01 13:15:09,183 INFO [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-01 13:15:09,183 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
jbfarin
Post Wed Dec 07, 2011 5:44 pm
ok will try again when I get home.....there are two servio log files in the folder, i wills end you both cuz i be lost....am sure you can tell am lost....the thing is the files seem to stillw ork even though the ffmpg crases over and over, like every 5 minutes the error message comes up. I bet this morning I had hundreds of the error message on my computer...Its the message that if you want can send to microsoft...
jbfarin
Post Thu Dec 08, 2011 12:05 am
2011-12-07 15:49:09,750 INFO [MediaServer] ------------------------------------------------------------------------
2011-12-07 15:49:09,750 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.0.1 (rev. 8e4ee98bff12)
2011-12-07 15:49:09,750 INFO [MediaServer] Petr Nejedly 2009-2011
2011-12-07 15:49:09,750 INFO [MediaServer] http://www.serviio.org
2011-12-07 15:49:09,765 INFO [MediaServer]
2011-12-07 15:49:09,765 INFO [MediaServer] Java 1.7.0_01-Oracle Corporation
2011-12-07 15:49:09,765 INFO [MediaServer] OS Windows XP x86 5.1
2011-12-07 15:49:09,765 INFO [MediaServer] File encoding: windows-1252
2011-12-07 15:49:09,765 INFO [MediaServer] Headless mode enabled: true
2011-12-07 15:49:09,765 INFO [MediaServer] User home dir: C:\
2011-12-07 15:49:09,765 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2011-12-07 15:49:09,765 INFO [MediaServer] ------------------------------------------------------------------------
2011-12-07 15:49:10,406 INFO [RestletServer] Starting Restlet server exposed on port 23423
2011-12-07 15:49:10,750 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-12-07 15:49:10,828 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2011-12-07 15:50:44,859 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2011-12-07 15:50:44,875 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2011-12-07 15:50:44,875 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2011-12-07 15:50:44,875 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2011-12-07 15:50:44,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2011-12-07 15:50:44,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2011-12-07 15:50:44,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2011-12-07 15:50:44,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2011-12-07 15:50:44,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2011-12-07 15:51:27,265 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-12-07 15:51:27,593 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2011-12-07 15:51:31,218 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-12-07 15:51:31,218 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2011-12-07 15:51:32,937 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-12-07 15:51:32,937 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2011-12-07 15:51:34,906 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-12-07 15:51:34,906 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2011-12-07 15:51:35,390 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-12-07 15:51:35,390 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2011-12-07 15:51:35,781 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-12-07 15:51:36,109 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2011-12-07 15:51:36,453 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-12-07 15:51:36,468 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2011-12-07 15:51:37,343 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-12-07 15:51:37,343 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2011-12-07 15:51:37,484 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2011-12-07 15:51:37,484 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2011-12-07 15:51:38,750 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-12-07 15:51:38,750 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2011-12-07 15:51:40,656 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-12-07 15:51:40,687 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2011-12-07 15:51:41,921 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-12-07 15:51:41,921 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2011-12-07 15:51:42,953 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2011-12-07 15:51:43,000 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2011-12-07 15:51:43,687 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2011-12-07 15:51:43,687 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2011-12-07 15:51:43,875 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2011-12-07 15:51:43,921 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2011-12-07 15:51:44,484 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2011-12-07 15:51:44,531 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2011-12-07 15:51:46,125 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2011-12-07 15:51:46,140 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2011-12-07 15:51:46,625 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2011-12-07 15:51:46,625 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 19
2011-12-07 15:51:48,421 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV 2011' (id=19)
2011-12-07 15:51:48,421 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2011-12-07 15:51:50,687 INFO [ProfilesDefinitionParser] Added profile 'Sony SMP-N100' (id=20)
2011-12-07 15:51:53,437 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-12-07 15:51:54,250 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-12-07 15:51:54,562 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-12-07 15:51:54,562 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-12-07 15:51:54,578 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-07 15:51:54,578 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-12-07 15:51:54,578 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1323301914578, LastAccessTime = 1323301914578, getTimeToLiveSeconds() = -1, createTime = 1323301914578 ]
2011-12-07 15:51:55,953 INFO [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
2011-12-07 15:51:55,953 INFO [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-07 15:51:55,953 INFO [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
2011-12-07 15:51:55,953 INFO [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-07 15:51:55,953 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-12-07 15:51:55,953 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-12-07 15:51:55,953 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-07 15:51:55,953 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-12-07 15:51:55,953 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-12-07 15:51:55,953 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-07 15:51:55,953 INFO [CompositeCacheConfigurator] Parsed regions [thumbnails, online_feeds, local_default, local_resetafterplay]
2011-12-07 15:51:55,953 INFO [CompositeCacheConfigurator] Finished configuration in 1610 ms.
2011-12-07 15:51:56,671 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2011-12-07 15:51:59,859 INFO [WebServer] Socket buffer set to 65535 bytes
2011-12-07 15:51:59,859 INFO [Device] Created UPnP Device with UUID: 204683ed-9f48-3c47-b70d-0da4ab7276fa, bound address: 192.168.1.4
2011-12-07 15:52:03,828 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2011-12-07 15:52:03,937 INFO [PluginCompilerThread] Started looking for plugins
2011-12-07 15:52:04,531 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2011-12-07 15:52:04,937 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2011-12-07 15:52:39,937 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-12-07 15:52:39,937 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: C:\WINDOWS\TEMP\Serviio
2011-12-07 15:52:55,578 DEBUG [AbstractTranscodingDeliveryEngine] Deleted file C:\WINDOWS\TEMP\Serviio\transcoding-temp-864-MPEG2PS.stf: true
2011-12-07 15:52:58,562 INFO [WebServer] WebServer starting on port 8895
2011-12-07 15:52:59,140 DEBUG [DiscoveryManager] UPNP device 204683ed-9f48-3c47-b70d-0da4ab7276fa (192.168.1.4) is available
2011-12-07 15:52:59,156 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-12-07 15:52:59,156 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-12-07 15:52:59,156 INFO [EventDispatcher] Starting EventDispatcher
2011-12-07 15:52:59,500 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-12-07 15:52:59,515 INFO [RendererSearchSender] Searching for Renderer devices
2011-12-07 15:52:59,703 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Intel(R) PRO/100 VE Network Connection - Packet Scheduler Miniport) and address 192.168.1.4, timeout = 0
2011-12-07 15:52:59,703 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Intel(R) PRO/100 VE Network Connection - Packet Scheduler Miniport) and address 192.168.1.4, timeout = 0
2011-12-07 15:52:59,703 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth1 (MAC Bridge Miniport - Packet Scheduler Miniport) and address 192.168.0.1, timeout = 0
2011-12-07 15:52:59,703 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth0 (Intel(R) PRO/100 VE Network Connection - Packet Scheduler Miniport) and address 192.168.1.4, timeout = 0
2011-12-07 15:53:01,203 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023183935347 from address /192.168.1.10:49153
2011-12-07 15:53:01,328 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 204683ed-9f48-3c47-b70d-0da4ab7276fa
2011-12-07 15:53:01,328 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-12-07 15:53:01,359 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-12-07 15:53:01,359 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.4:1038
2011-12-07 15:53:01,375 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.10:49153/virtual/description.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-12-07 15:53:01,406 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 29bbe0e1-1a6e-47f6-8f8d-005094caf396 from address /192.168.1.10:49153
2011-12-07 15:53:01,421 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.11:49153/virtual/description.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-12-07 15:53:01,421 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 29bbe0e1-1a6e-47f6-8f8d-005094f6f996 from address /192.168.1.11:49153
2011-12-07 15:53:01,593 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.8:49153/virtual/description.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-12-07 15:53:01,609 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 29bbe0e1-1a6e-47f6-8f8d-000378b42151 from address /192.168.1.8:49153
2011-12-07 15:53:01,656 DEBUG [WebServer] Incoming connection from /192.168.1.7:33922
2011-12-07 15:53:01,656 DEBUG [WebServer] Incoming connection from /192.168.1.8:35383
2011-12-07 15:53:01,718 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.10:49153/virtual/description.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-12-07 15:53:01,718 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 29bbe0e1-1a6e-47f6-8f8d-005094caf396 from address /192.168.1.10:49153
2011-12-07 15:53:01,781 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.7 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0])
2011-12-07 15:53:01,781 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.7
2011-12-07 15:53:01,781 DEBUG [WebServer] Incoming connection from /192.168.1.8:35384
2011-12-07 15:53:01,843 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.7:49153/virtual/description.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-12-07 15:53:01,843 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 29bbe0e1-1a6e-47f6-8f8d-000378b42150 from address /192.168.1.7:49153
2011-12-07 15:53:01,906 DEBUG [WebServer] Incoming connection from /192.168.1.10:35400
2011-12-07 15:53:01,906 DEBUG [WebServer] Incoming connection from /192.168.1.7:33923
2011-12-07 15:53:01,906 DEBUG [WebServer] Incoming connection from /192.168.1.10:35399
2011-12-07 15:53:01,890 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.8 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0])
2011-12-07 15:53:02,015 DEBUG [WebServer] Incoming connection from /192.168.1.11:33159
2011-12-07 15:53:02,015 DEBUG [WebServer] Incoming connection from /192.168.1.11:33160
2011-12-07 15:53:02,046 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.8:49153/virtual/description.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-12-07 15:53:02,046 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 29bbe0e1-1a6e-47f6-8f8d-000378b42151 from address /192.168.1.8:49153
2011-12-07 15:53:02,046 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.10 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1])
2011-12-07 15:53:02,046 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.7 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1])
2011-12-07 15:53:02,046 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.10 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0])
2011-12-07 15:53:01,890 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.8 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1])
2011-12-07 15:53:02,093 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.11 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0])
2011-12-07 15:53:02,125 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.11 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1])
2011-12-07 15:53:02,171 DEBUG [WebServer] Incoming connection from /192.168.1.6:63764
2011-12-07 15:53:02,234 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.6 (headers = [Host: 192.168.1.4:8895,Date: Wed, 07 Dec 2011 23:53:01 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="Media Player";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Media Player"; mv="2.0";])
2011-12-07 15:53:02,312 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023183935347 from address /192.168.1.11:49153
2011-12-07 15:53:02,531 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.6:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-12-07 15:53:02,531 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-544249c19889 from address /192.168.1.6:54346
2011-12-07 15:53:02,593 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023167494287 from address /192.168.1.10:49153
2011-12-07 15:53:02,609 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.10:49153/virtual/description.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-12-07 15:53:02,625 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 29bbe0e1-1a6e-47f6-8f8d-005094caf396 from address /192.168.1.10:49153
2011-12-07 15:53:02,703 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023183935347 from address /192.168.1.7:49153
2011-12-07 15:53:02,703 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.7:49153/virtual/description.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-12-07 15:53:02,703 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 29bbe0e1-1a6e-47f6-8f8d-000378b42150 from address /192.168.1.7:49153
2011-12-07 15:53:02,718 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0]
2011-12-07 15:53:02,718 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.7
2011-12-07 15:53:02,734 DEBUG [RendererDAOImpl] Deleting a Renderer (uuid = 29bbe0e1-1a6e-47f6-8f8d-000378b42150)
2011-12-07 15:53:02,765 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.6:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-12-07 15:53:02,765 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-544249c19889 from address /192.168.1.6:54346
2011-12-07 15:53:02,953 DEBUG [RendererManager] Adding renderer Renderer [uuid=29bbe0e1-1a6e-47f6-8f8d-005094f6f996, ipAddress=192.168.1.11, name=MediaRenderer, profileId=6, manuallyAdded=false] to list of active renderers
2011-12-07 15:53:02,968 DEBUG [RendererManager] Adding renderer Renderer [uuid=29bbe0e1-1a6e-47f6-8f8d-005094caf396, ipAddress=192.168.1.10, name=MediaRenderer, profileId=6, manuallyAdded=false] to list of active renderers
2011-12-07 15:53:02,968 DEBUG [RendererManager] Adding renderer Renderer [uuid=29bbe0e1-1a6e-47f6-8f8d-000378b42150, ipAddress=192.168.1.7, name=MediaRenderer, profileId=6, manuallyAdded=false] to list of active renderers
2011-12-07 15:53:02,984 DEBUG [RendererManager] Adding renderer Renderer [uuid=00000000-0000-1010-8000-544249c19889, ipAddress=192.168.1.6, name=Media Player, profileId=20, manuallyAdded=false] to list of active renderers
2011-12-07 15:53:03,000 DEBUG [RendererManager] Adding renderer Renderer [uuid=29bbe0e1-1a6e-47f6-8f8d-000378b42151, ipAddress=192.168.1.8, name=MediaRenderer, profileId=6, manuallyAdded=false] to list of active renderers
2011-12-07 15:53:03,078 DEBUG [WebServer] Incoming connection from /192.168.1.3:54078
2011-12-07 15:53:03,078 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.3 (headers = [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.1.4:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50])
2011-12-07 15:53:03,312 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.11:49153/virtual/description.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-12-07 15:53:03,312 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 29bbe0e1-1a6e-47f6-8f8d-005094f6f996 from address /192.168.1.11:49153
2011-12-07 15:53:03,437 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth1 (MAC Bridge Miniport - Packet Scheduler Miniport) and address 192.168.0.1, timeout = 0
2011-12-07 15:53:03,437 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 204683ed-9f48-3c47-b70d-0da4ab7276fa
2011-12-07 15:53:03,703 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023167494287 from address /192.168.1.7:49153
2011-12-07 15:53:03,703 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.10:49153
2011-12-07 15:53:03,703 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.10:49153
2011-12-07 15:53:04,328 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023167494287 from address /192.168.1.11:49153
2011-12-07 15:53:05,234 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.6:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-12-07 15:53:05,234 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-544249c19889 from address /192.168.1.6:54346
2011-12-07 15:53:05,437 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-12-07 15:53:05,859 DEBUG [RendererManager] Removing renderer 29bbe0e1-1a6e-47f6-8f8d-000378b42150 from list of active renderers
2011-12-07 15:53:05,859 DEBUG [RendererDAOImpl] Creating a new Renderer (uuid = 481f71d5-9311-41f4-81ba-0bd1a3525220)
2011-12-07 15:53:06,390 INFO [RendererManager] Stored a new renderer: uuid='481f71d5-9311-41f4-81ba-0bd1a3525220', name = 'DirecTV HD-DVR', ipAddress='192.168.1.7', profile = '6'
2011-12-07 15:53:06,390 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.3
2011-12-07 15:53:06,390 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.1.4:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50]
2011-12-07 15:53:06,406 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.3
2011-12-07 15:53:06,406 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2011-12-07 15:53:06,406 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4:8895,Date: Wed, 07 Dec 2011 23:53:01 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="Media Player";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Media Player"; mv="2.0";]
2011-12-07 15:53:06,421 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2011-12-07 15:53:06,421 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-12-07 15:53:06,421 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1]
2011-12-07 15:53:06,421 DEBUG [RendererDAOImpl] Deleting a Renderer (uuid = 29bbe0e1-1a6e-47f6-8f8d-005094f6f996)
2011-12-07 15:53:06,421 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.7
2011-12-07 15:53:06,500 DEBUG [RendererManager] Removing renderer 29bbe0e1-1a6e-47f6-8f8d-005094f6f996 from list of active renderers
2011-12-07 15:53:06,500 DEBUG [RendererDAOImpl] Creating a new Renderer (uuid = 2c4dfd68-2911-41ac-bb86-1beef86a4f02)
2011-12-07 15:53:06,640 INFO [RendererManager] Stored a new renderer: uuid='2c4dfd68-2911-41ac-bb86-1beef86a4f02', name = 'DirecTV HD-DVR', ipAddress='192.168.1.11', profile = '6'
2011-12-07 15:53:06,640 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-12-07 15:53:06,640 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0]
2011-12-07 15:53:06,640 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2011-12-07 15:53:06,640 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1]
2011-12-07 15:53:06,640 DEBUG [RendererDAOImpl] Deleting a Renderer (uuid = 29bbe0e1-1a6e-47f6-8f8d-000378b42151)
2011-12-07 15:53:06,656 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-12-07 15:53:06,812 DEBUG [RendererManager] Removing renderer 29bbe0e1-1a6e-47f6-8f8d-000378b42151 from list of active renderers
2011-12-07 15:53:06,812 DEBUG [RendererDAOImpl] Creating a new Renderer (uuid = 7e1e0cd0-90c4-4860-902e-fb25057207b5)
2011-12-07 15:53:06,921 INFO [RendererManager] Stored a new renderer: uuid='7e1e0cd0-90c4-4860-902e-fb25057207b5', name = 'DirecTV HD-DVR', ipAddress='192.168.1.8', profile = '6'
2011-12-07 15:53:06,921 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2011-12-07 15:53:06,937 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2011-12-07 15:53:06,937 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0]
2011-12-07 15:53:06,937 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2011-12-07 15:53:06,937 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0]
2011-12-07 15:53:06,937 DEBUG [RendererDAOImpl] Deleting a Renderer (uuid = 29bbe0e1-1a6e-47f6-8f8d-005094caf396)
2011-12-07 15:53:07,156 DEBUG [RendererManager] Removing renderer 29bbe0e1-1a6e-47f6-8f8d-005094caf396 from list of active renderers
2011-12-07 15:53:07,156 DEBUG [RendererDAOImpl] Creating a new Renderer (uuid = 2ff26750-764d-497f-a522-89514a0b72c7)
2011-12-07 15:53:07,265 DEBUG [WebServer] Incoming connection from /192.168.1.10:35401
2011-12-07 15:53:07,265 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.10 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:03 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1])
2011-12-07 15:53:07,296 INFO [RendererManager] Stored a new renderer: uuid='2ff26750-764d-497f-a522-89514a0b72c7', name = 'DirecTV HD-DVR', ipAddress='192.168.1.10', profile = '6'
2011-12-07 15:53:07,296 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.7
2011-12-07 15:53:07,296 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1]
2011-12-07 15:53:07,296 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2011-12-07 15:53:07,312 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:52:57 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1]
2011-12-07 15:53:07,312 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2011-12-07 15:53:07,312 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:03 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1]
2011-12-07 15:53:07,437 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2011-12-07 15:53:07,375 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2011-12-07 15:53:08,218 DEBUG [RendererManager] Retrieve device description from http://192.168.1.8:49153/virtual/description.xml
2011-12-07 15:53:09,312 INFO [UpdateChecker] Checking if a new version is available
2011-12-07 15:53:11,859 DEBUG [RendererManager] Looking for a renderer profile for: friendly name = 'DIRECTV Mediashare Renderer', model name= 'MediaRenderer', model number = '1.0', product code = 'null', server name = 'Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1'
2011-12-07 15:53:11,859 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2011-12-07 15:53:11,875 DEBUG [RendererDAOImpl] Deleting a Renderer (uuid = 7e1e0cd0-90c4-4860-902e-fb25057207b5)
2011-12-07 15:53:11,906 DEBUG [RendererDAOImpl] Creating a new Renderer (uuid = 29bbe0e1-1a6e-47f6-8f8d-000378b42151)
2011-12-07 15:53:12,046 INFO [RendererManager] Stored a new renderer: uuid='29bbe0e1-1a6e-47f6-8f8d-000378b42151', name = 'MediaRenderer', ipAddress='192.168.1.8', profile = '6'
2011-12-07 15:53:12,046 DEBUG [RendererManager] Adding renderer Renderer [uuid=29bbe0e1-1a6e-47f6-8f8d-000378b42151, ipAddress=192.168.1.8, name=MediaRenderer, profileId=6, manuallyAdded=false] to list of active renderers
2011-12-07 15:53:15,500 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Intel(R) PRO/100 VE Network Connection - Packet Scheduler Miniport) and address 192.168.1.4, timeout = 0
2011-12-07 15:53:15,500 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 204683ed-9f48-3c47-b70d-0da4ab7276fa
2011-12-07 15:53:15,531 DEBUG [WebServer] Incoming connection from /192.168.1.10:35402
2011-12-07 15:53:15,531 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.10 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1])
2011-12-07 15:53:15,531 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2011-12-07 15:53:15,531 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1]
2011-12-07 15:53:15,531 DEBUG [WebServer] Incoming connection from /192.168.1.11:33161
2011-12-07 15:53:15,546 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.11 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0])
2011-12-07 15:53:15,546 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-12-07 15:53:15,546 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0]
2011-12-07 15:53:15,546 DEBUG [WebServer] Incoming connection from /192.168.1.7:33925
2011-12-07 15:53:15,546 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.7 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1])
2011-12-07 15:53:15,546 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.7
2011-12-07 15:53:15,546 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1]
2011-12-07 15:53:15,609 DEBUG [WebServer] Incoming connection from /192.168.1.8:35385
2011-12-07 15:53:15,609 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.8 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0])
2011-12-07 15:53:15,609 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2011-12-07 15:53:15,609 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0]
2011-12-07 15:53:15,609 DEBUG [RendererDAOImpl] Deleting a Renderer (uuid = 29bbe0e1-1a6e-47f6-8f8d-000378b42151)
2011-12-07 15:53:15,625 DEBUG [WebServer] Incoming connection from /192.168.1.8:35386
2011-12-07 15:53:15,625 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.8 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1])
2011-12-07 15:53:15,625 DEBUG [WebServer] Incoming connection from /192.168.1.7:33926
2011-12-07 15:53:15,625 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.7 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0])
2011-12-07 15:53:15,625 DEBUG [WebServer] Incoming connection from /192.168.1.10:35403
2011-12-07 15:53:15,640 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.10 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0])
2011-12-07 15:53:15,656 DEBUG [WebServer] Incoming connection from /192.168.1.11:33162
2011-12-07 15:53:15,656 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.11 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1])
2011-12-07 15:53:15,718 DEBUG [RendererManager] Removing renderer 29bbe0e1-1a6e-47f6-8f8d-000378b42151 from list of active renderers
2011-12-07 15:53:15,718 DEBUG [RendererDAOImpl] Creating a new Renderer (uuid = 16147f2d-64f5-4e43-a142-a443bb21ac7e)
2011-12-07 15:53:15,828 INFO [RendererManager] Stored a new renderer: uuid='16147f2d-64f5-4e43-a142-a443bb21ac7e', name = 'DirecTV HD-DVR', ipAddress='192.168.1.8', profile = '6'
2011-12-07 15:53:15,828 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-12-07 15:53:15,828 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1]
-b70d-0da4ab7276fa
jbfarin
Post Thu Dec 08, 2011 12:06 am
2011-12-07 15:53:15,828 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2011-12-07 15:53:15,828 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2011-12-07 15:53:15,843 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0]
2011-12-07 15:53:15,843 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.7
2011-12-07 15:53:15,843 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0]
2011-12-07 15:53:15,843 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2011-12-07 15:53:15,843 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2011-12-07 15:53:15,859 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:11 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1]
2011-12-07 15:53:15,859 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2011-12-07 15:53:16,171 DEBUG [WebServer] Incoming connection from /192.168.1.6:63780
2011-12-07 15:53:16,265 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.6 (headers = [Host: 192.168.1.4:8895,Date: Wed, 07 Dec 2011 23:53:15 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="Media Player";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Media Player"; mv="2.0";])
2011-12-07 15:53:16,281 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2011-12-07 15:53:16,281 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4:8895,Date: Wed, 07 Dec 2011 23:53:15 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="Media Player";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Media Player"; mv="2.0";]
2011-12-07 15:53:16,906 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023183935347 from address /192.168.1.8:49153
2011-12-07 15:53:17,468 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth1 (MAC Bridge Miniport - Packet Scheduler Miniport) and address 192.168.0.1, timeout = 0
2011-12-07 15:53:17,468 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 204683ed-9f48-3c47-b70d-0da4ab7276fa
2011-12-07 15:53:18,906 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023167494287 from address /192.168.1.8:49153
2011-12-07 15:53:19,453 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-12-07 15:53:20,046 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'DirecTV HD-DVR'
2011-12-07 15:53:20,062 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'DirecTV HD-DVR'
2011-12-07 15:53:20,078 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'DirecTV HD-DVR'
2011-12-07 15:53:20,078 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-12-07 15:53:20,093 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony SMP-N100'
2011-12-07 15:53:20,093 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'DirecTV HD-DVR'
2011-12-07 15:53:20,109 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'DirecTV HD-DVR'
2011-12-07 15:53:20,125 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'DirecTV HD-DVR'
2011-12-07 15:53:20,140 DEBUG [WebServer] Incoming connection from /192.168.1.3:54106
2011-12-07 15:53:20,156 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2011-12-07 15:53:20,203 DEBUG [WebServer] Incoming connection from /192.168.1.6:63782
2011-12-07 15:53:20,296 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-12-07 15:53:20,312 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:20,546 DEBUG [WebServer] Incoming connection from /192.168.1.6:63783
2011-12-07 15:53:20,640 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-12-07 15:53:20,671 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:20,968 DEBUG [WebServer] Incoming connection from /192.168.1.6:63784
2011-12-07 15:53:21,078 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.6:
2011-12-07 15:53:21,078 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2011-12-07 15:53:26,515 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023183935347 from address /192.168.1.10:49153
2011-12-07 15:53:27,453 INFO [FeedUpdaterThread] Started looking for information about online feeds
2011-12-07 15:53:27,468 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023183935347 from address /192.168.1.11:49153
2011-12-07 15:53:27,765 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023183935347 from address /192.168.1.7:49153
2011-12-07 15:53:27,828 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-12-07 15:53:28,640 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-12-07 15:53:28,718 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023167494287 from address /192.168.1.10:49153
2011-12-07 15:53:28,765 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023167494287 from address /192.168.1.7:49153
2011-12-07 15:53:28,812 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2011-12-07 15:53:28,875 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-12-07 15:53:29,468 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Intel(R) PRO/100 VE Network Connection - Packet Scheduler Miniport) and address 192.168.1.4, timeout = 0
2011-12-07 15:53:29,484 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 204683ed-9f48-3c47-b70d-0da4ab7276fa
2011-12-07 15:53:29,546 DEBUG [WebServer] Incoming connection from /192.168.1.8:35387
2011-12-07 15:53:29,562 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.8 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:25 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0])
2011-12-07 15:53:29,562 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2011-12-07 15:53:29,562 DEBUG [WebServer] Incoming connection from /192.168.1.7:33927
2011-12-07 15:53:29,562 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.7 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:25 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0])
2011-12-07 15:53:29,562 DEBUG [WebServer] Incoming connection from /192.168.1.8:35388
2011-12-07 15:53:29,562 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.8 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:25 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1])
2011-12-07 15:53:29,578 DEBUG [WebServer] Incoming connection from /192.168.1.7:33928
2011-12-07 15:53:29,578 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.7 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:25 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1])
2011-12-07 15:53:29,578 DEBUG [WebServer] Incoming connection from /192.168.1.11:33163
2011-12-07 15:53:29,578 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.11 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:25 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1])
2011-12-07 15:53:29,578 DEBUG [WebServer] Incoming connection from /192.168.1.11:33164
2011-12-07 15:53:29,578 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.11 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:25 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0])
2011-12-07 15:53:29,593 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:25 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0]
2011-12-07 15:53:29,593 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2011-12-07 15:53:29,593 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'DirecTV HD-DVR'
2011-12-07 15:53:29,593 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.7
2011-12-07 15:53:29,609 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'DirecTV HD-DVR'
2011-12-07 15:53:29,609 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-12-07 15:53:29,609 DEBUG [WebServer] Incoming connection from /192.168.1.10:35404
2011-12-07 15:53:29,609 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.10 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:25 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1])
2011-12-07 15:53:29,609 DEBUG [WebServer] Incoming connection from /192.168.1.10:35405
2011-12-07 15:53:29,609 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from 192.168.1.10 (headers = [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:25 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0])
2011-12-07 15:53:29,625 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:25 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0]
2011-12-07 15:53:29,625 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-12-07 15:53:29,625 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:25 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1]
2011-12-07 15:53:29,625 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'DirecTV HD-DVR'
2011-12-07 15:53:29,625 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.7
2011-12-07 15:53:29,640 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:25 2011,User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1]
2011-12-07 15:53:29,640 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2011-12-07 15:53:29,656 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'DirecTV HD-DVR'
2011-12-07 15:53:29,656 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2011-12-07 15:53:29,656 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.7
2011-12-07 15:53:29,671 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'DirecTV HD-DVR'
2011-12-07 15:53:29,671 DEBUG [WebServer] Incoming connection from /192.168.1.7:33929
2011-12-07 15:53:29,671 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-12-07 15:53:29,671 DEBUG [WebServer] Incoming connection from /192.168.1.8:35389
2011-12-07 15:53:29,671 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:29,671 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-12-07 15:53:29,671 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:25 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0]
2011-12-07 15:53:29,671 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:DIRECTV2PC-Media-Server1_0-RID-023167494287 from address /192.168.1.11:49153
2011-12-07 15:53:29,671 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2011-12-07 15:53:29,687 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.4,Date: Wed, Dec 7 15:53:25 2011,User-Agent: Linux/2.4.29-uclibc-brcm, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1]
2011-12-07 15:53:29,687 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2011-12-07 15:53:29,687 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'DirecTV HD-DVR'
2011-12-07 15:53:29,703 DEBUG [WebServer] Incoming connection from /192.168.1.11:33165
2011-12-07 15:53:29,703 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-12-07 15:53:29,703 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:29,703 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'DirecTV HD-DVR'
2011-12-07 15:53:29,734 DEBUG [WebServer] Incoming connection from /192.168.1.8:35390
2011-12-07 15:53:29,734 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-12-07 15:53:29,734 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:29,734 DEBUG [WebServer] Incoming connection from /192.168.1.8:35391
2011-12-07 15:53:29,734 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-12-07 15:53:29,734 DEBUG [WebServer] Incoming connection from /192.168.1.7:33930
2011-12-07 15:53:29,765 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:29,781 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:29,781 DEBUG [WebServer] Incoming connection from /192.168.1.7:33931
2011-12-07 15:53:29,781 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-12-07 15:53:29,796 DEBUG [WebServer] Incoming connection from /192.168.1.11:33166
2011-12-07 15:53:29,796 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-12-07 15:53:29,796 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:29,796 DEBUG [WebServer] Incoming connection from /192.168.1.11:33167
2011-12-07 15:53:29,796 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-12-07 15:53:29,828 DEBUG [WebServer] Incoming connection from /192.168.1.10:35406
2011-12-07 15:53:29,828 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-12-07 15:53:29,828 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:29,843 DEBUG [WebServer] Incoming connection from /192.168.1.7:33932
2011-12-07 15:53:29,843 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2011-12-07 15:53:29,859 DEBUG [WebServer] Incoming connection from /192.168.1.10:35407
2011-12-07 15:53:29,859 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-12-07 15:53:29,859 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:29,859 DEBUG [WebServer] Incoming connection from /192.168.1.8:35393
2011-12-07 15:53:29,859 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-12-07 15:53:29,859 DEBUG [WebServer] Incoming connection from /192.168.1.8:35392
2011-12-07 15:53:29,859 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2011-12-07 15:53:29,875 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:29,875 DEBUG [WebServer] Incoming connection from /192.168.1.7:33933
2011-12-07 15:53:29,875 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-12-07 15:53:29,890 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:29,906 DEBUG [WebServer] Incoming connection from /192.168.1.11:33169
2011-12-07 15:53:29,906 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2011-12-07 15:53:29,906 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:29,906 DEBUG [WebServer] Incoming connection from /192.168.1.11:33168
2011-12-07 15:53:29,906 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-12-07 15:53:29,953 DEBUG [WebServer] Incoming connection from /192.168.1.8:35394
2011-12-07 15:53:29,953 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2011-12-07 15:53:29,953 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:29,953 DEBUG [WebServer] Incoming connection from /192.168.1.10:35409
2011-12-07 15:53:29,953 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-12-07 15:53:29,953 DEBUG [WebServer] Incoming connection from /192.168.1.10:35408
2011-12-07 15:53:29,968 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-12-07 15:53:29,968 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:29,968 DEBUG [WebServer] Incoming connection from /192.168.1.7:33934
2011-12-07 15:53:29,968 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2011-12-07 15:53:30,015 DEBUG [WebServer] Incoming connection from /192.168.1.11:33170
2011-12-07 15:53:30,015 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2011-12-07 15:53:30,015 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:30,031 DEBUG [WebServer] Incoming connection from /192.168.1.8:35395
2011-12-07 15:53:30,031 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSearchCapabilities"' from 192.168.1.8:
2011-12-07 15:53:30,031 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2011-12-07 15:53:30,031 DEBUG [WebServer] Incoming connection from /192.168.1.8:35396
2011-12-07 15:53:30,031 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.8:
2011-12-07 15:53:30,046 DEBUG [WebServer] Incoming connection from /192.168.1.10:35410
2011-12-07 15:53:30,062 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2011-12-07 15:53:30,062 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-12-07 15:53:30,062 DEBUG [WebServer] Incoming connection from /192.168.1.7:33935
2011-12-07 15:53:30,062 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSearchCapabilities"' from 192.168.1.7:
2011-12-07 15:53:30,062 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.7
2011-12-07 15:53:30,062 DEBUG [WebServer] Incoming connection from /192.168.1.7:33936
2011-12-07 15:53:30,062 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.7:
2011-12-07 15:53:30,062 DEBUG [WebServer] Incoming connection from /192.168.1.10:35411
2011-12-07 15:53:30,234 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: F:\classics
2011-12-07 15:53:30,250 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: F:\classics
2011-12-07 15:53:30,312 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 2)
2011-12-07 15:53:30,546 DEBUG [WebServer] Incoming connection from /192.168.1.11:33171
2011-12-07 15:53:30,546 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSearchCapabilities"' from 192.168.1.11:
2011-12-07 15:53:30,546 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2011-12-07 15:53:30,546 DEBUG [WebServer] Incoming connection from /192.168.1.11:33172
2011-12-07 15:53:30,546 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.11:
2011-12-07 15:53:30,625 DEBUG [WebServer] Incoming connection from /192.168.1.10:35412
2011-12-07 15:53:30,625 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSearchCapabilities"' from 192.168.1.10:
2011-12-07 15:53:30,625 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2011-12-07 15:53:30,625 DEBUG [WebServer] Incoming connection from /192.168.1.10:35413
2011-12-07 15:53:30,640 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.10:
2011-12-07 15:53:30,640 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2011-12-07 15:53:31,109 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-12-07 15:53:31,125 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2011-12-07 15:53:31,296 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: F:\classics\1000612894_-_Zoolander_(2001)
2011-12-07 15:53:31,328 DEBUG [LibraryAdditionsCheckerThread] Found file 'mtn-zoolander-cd1.avi', checking if it's already in the Library
2011-12-07 15:53:31,328 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item mtn-zoolander-cd1.avi
2011-12-07 15:53:31,453 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth1 (MAC Bridge Miniport - Packet Scheduler Miniport) and address 192.168.0.1, timeout = 0
2011-12-07 15:53:31,453 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 204683ed-9f48-3c47
jbfarin
Post Thu Dec 08, 2011 12:07 am
Re: ffmpeg.exe encoutered a problem
boy I hope that was it.....had to split it in two....
jbfarin
Post Thu Dec 08, 2011 6:35 pm
did that work?
