The Daily Show
jcace
Post Fri Nov 04, 2011 6:57 pm
The Daily Show
I love Serviio. In fact I use it so much, I've stopped my cable subscription. Netflix, Amazon Prime and Serviio keep my Sony Blu ray pretty busy.
What I really miss is The Daily Show. I do watch it online, but would love to be able to do so via Serviio. I've found this source: http://feeds.feedburner.com/the-daily-show. Does this needs a plugin?
Thank you in advance.
jcace
Post Mon Nov 07, 2011 3:38 pm
Re: The Daily Show
Strafer
Post Tue Nov 29, 2011 7:50 pm
Re: The Daily Show
I second the request for www.thedailyshow.com
and also add www.colbertnation.com show.
dfreadhoff
Post Tue Dec 06, 2011 2:03 am
Re: The Daily Show
This should be grouped under a Comedy Central Feed. I have looked into Comedy Central Feeds they do have RSS feeds for their shows. The RSS can be found at http://www.comedycentral.com/rss/tdsvideos.jhtml. Unfortunately, the videos are rmtpe multi segment videos. From what I have read, serviio doesn't have a way to string these together. Others are having this problem with Discover.com also. I started on the plugin but hit a wall with this. If a new version is release with example plugin for rmtp, I will try and finish up what I started.
Post Tue Dec 06, 2011 9:41 am
Re: The Daily Show
can you post in the plugin dev forum with what your problem is?
Return to Plugin requests
