Sony Bravia 2010 series
Post Wed Aug 11, 2010 6:01 pm
Re: [Profile] Sony Bravia 2010 series (EX4, EX5, EX6, EX7, HX7)
Do these TVs support subtitles?
bstick
Post Thu Aug 12, 2010 10:50 pm
I assume it does as subtitles can be switched on for normal television viewing.
Or are you asking about something else?
Post Fri Aug 13, 2010 6:36 am
It's something else... they must be supported by DLNA implementation, eg. srt, sub, etc
Post Fri Aug 13, 2010 7:23 am
zip wrote:Do these TVs support subtitles?
Not supported, must be transcoded like PS3 Media server do.
princo
Post Fri Aug 13, 2010 4:14 pm
I tried .srt subtitles on Wild Media Server and it was ok on Sony 40EX500. TV originally does not support subtitles.
It is still not possible with Serviio. I am sure it will be done very soon.
Post Fri Aug 13, 2010 6:24 pm
We those subtitles 'burned' into the video stream (basically transcoding the stream and injesting subtitles into it) or does the TV support subtitles from a separate (.srt) file? If you can change font size, colour, etc in Wild Media Server and it matches what you see on TV then the subtitles are burned in the stream.
Post Fri Aug 13, 2010 6:32 pm
zip wrote:We those subtitles 'burned' into the video stream (basically transcoding the stream and injesting subtitles into it) or does the TV support subtitles from a separate (.srt) file? If you can change font size, colour, etc in Wild Media Server and it matches what you see on TV then the subtitles are burned in the stream.
I think its only "burned" as PS3MS, Bravia TV doesn't support from a separate file.
princo
Post Sat Aug 14, 2010 8:49 pm
I cannot try it again since trial expired, but I am 100% sure that I tried with two separate files. Divx movie and .srt subtitle. There is also menu in WMS Settings called Subtitle where you can set size and color of the subtitle. Everyone from non-English area knows how subtitles are important. But I understand that this project is in progress and I really respect Zip's efforts. So far, Serviio is excellent.
Post Sat Aug 14, 2010 11:44 pm
Exactly, the menu where you can set font etc. - it means it burns the subtitles into the stream - otherwise the player doesn't know your installed fonts etc. It locally styles the text and burn it as bitmaps into he video.
Post Tue Aug 17, 2010 8:39 am
Illico wrote:hum, do you have an idea for the latest http-get line of the EX500 sink file (see first post of the topic), what this?
http-get:*:video/x-mp2t-mphl-188:*
zip wrote:No, but seeing it starts with X usually means it's a non standard. Seems like mpegts, try to use it if it fixes your problem.
with video/x-mp2t-mphl-188, no files were played...
Post Wed Aug 18, 2010 1:25 pm
zip wrote:Those ending with _ISO should use "video/mpeg" the other ones (without suffix and _T) should have "video/vnd.dlna.mpeg-tts".
From DLNA spec:
MPEG2TS can have 3 DLNA Transport Packets. These consist of a 188-byte ISO MPEG2 TS packet, a 192-byte packet consisting of a 188-byte ISO MPEG2 TS packet preceded by a 4-byte timestamp zero-value timestamp field, and a 192-byte packet consisting of a 188-byte ISO MPEG2 TS packet preceded by a 4-byte valid timestamp.
At the moment Serviio doesn't distinguish between them and serves them using the profiles provided above.
It looks like the TV is sensitive to it. It might be that the profile name is really not too important as long as the mime type is correct. Can you post ffmpeg -i on two files, one that works with video/mpeg and one that wotks with video/vnd.dlna.mpeg-tts?
Hi Zip,
I've got two files:
TZ7_BDAV-AVC-HL4.0-1280x720-25fps-AC3-192Kbps-48KHz-Stereo.m2ts comes from my Panasonic TZ7 Cam.corder
ffmpeg.exe -i C:\Sample\BDAV\TZ7_BDAV-AVC-HL4.0-1280x720-25fps-AC3-192Kbps-48KHz-Stereo.m2ts
FFmpeg version SVN-r24623-Sherpya, Copyright (c) 2000-2010 the FFmpeg developers
  built on Jul 31 2010 19:32:53 with gcc 4.2.5 20090330 (prerelease) [Sherpya]
  libavutil     50.23. 0 / 50.23. 0
  libavcore      0. 2. 0 /  0. 2. 0
  libavcodec    52.84. 2 / 52.84. 2
  libavformat   52.77. 0 / 52.77. 0
  libavdevice   52. 2. 0 / 52. 2. 0
  libavfilter    1.27. 0 /  1.27. 0
  libswscale     0.11. 0 /  0.11. 0
  libpostproc   51. 2. 0 / 51. 2. 0
Seems stream 0 codec frame rate differs from container frame rate: 100.00 (100/1) -> 25.00 (25/1)
Input #0, mpegts, from 'C:\Sample\BDAV\TZ7_BDAV-AVC-HL4.0-1280x720-25fps-AC3-192Kbps-48KHz-Stereo.m2ts':
  Duration: 00:00:20.80, start: 0.363244, bitrate: 15430 kb/s
  Program 1
    Stream #0.0[0x1011]: Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 100 tbc
    Stream #0.1[0x1100]: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
GIJoe_MKV-AVC-HL4.0-1280x528-23.97fps-AAC-48KHz-Stereo.mkv comes from here
ffmpeg.exe -i C:\Sample\MKV\GIJoe_MKV-AVC-HL4.0-1280x528-23.97fps-AAC-48KHz-Stereo.mkv
[matroska @ 01a6d110] max_analyze_duration reached
[matroska @ 01a6d110] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska, from 'C:\Sample\MKV\GIJoe_MKV-AVC-HL4.0-1280x528-23.97fps-AAC-48KHz-Stereo.mkv':
    TITLE           : G.I. Joe - The Rise Of Cobra Trailer
    TITLE/URL       : http://www.gijoemovie.com
    COPYRIGHT       : 2009 by PARAMOUNT PICTURES. All rights reserved. G.I. JOE and related characters are trademarks of Hasbro and are used with permission. 2009 Hasbro. All Rights Reserved.
    COMMENT         : Encoded in DivX Plus HD for the DivX Plus Web Player
  Duration: 00:02:14.16, start: 0.000000, bitrate: N/A
    Stream #0.0(eng): Video: h264, yuv420p, 1280x528, PAR 1:1 DAR 80:33, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
      title           : Main title
    Stream #0.1(eng): Audio: aac, 48000 Hz, stereo, s16
      title           : English 2ch Stereo
    Stream #0.2(eng): Subtitle: [0][0][0][0] / 0x0000
      title           : English
    Stream #0.3(fre): Subtitle: [0][0][0][0] / 0x0000
      title           : French
    Stream #0.4(ger): Subtitle: [0][0][0][0] / 0x0000
      title           : German
    Stream #0.5(por): Subtitle: [0][0][0][0] / 0x0000
      title           : Portuguese
    Stream #0.6(spa): Subtitle: [0][0][0][0] / 0x0000
      title           : Spanish
When I used
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_EU">AVC_TS_MP_HD_AC3</MediaFormatProfile>
TZ7 works fine, but not GIJoe movie
and with
<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AC3</MediaFormatProfile>
GIJoe works fine but not TZ7
Post Wed Aug 18, 2010 1:46 pm
so it looks like the transcoded stream (GIJoe) is created by ffmpeg as ISO... I wonder if there are any ffmpeg parameters to make it 'non ISO' so that we could use one mime type for all.
DLNA spec wrote:The MIME type "video/vnd.dlna.mpeg-tts" must be used for Media Format Profiles which utilize a 192-byte DLNA Transport Packet format. The MIME type "video/mpeg" must be used for Media Format Profiles which utilize the 188-byte DLNA Transport Packet format.
DLNA spec wrote:For Media Format Profiles IDs which don't contain an "_ISO" suffix, the 188 byte DLNA Transport Packet specified in this guideline will be preceded by a 32 bit timestamp making a 192 byte DLNA Transport Packet, as described in [46] for Media Format Profiles IDs which don't contain an "_ISO" suffix.
Could you try looking here: http://www.ffmpeg.org/ffmpeg-doc.html
.. and adding some of the parameters into the ffmpeg command serviio usues to remux the mkv? (look for timestamp related, like -copyts ). After that try playing the video natively through Serviio (I presume if you do the same with the current ffmpeg command parameters it'll fail playing with the non-ISO format).
Post Thu Aug 19, 2010 3:32 pm
Illico,
does your profile play SD transcoded files? As you do not rename the format AVC_TS_MP_SD_AC3 to something like MPEG_TS_SD_50_AC3_T for your TV. Transcoding into Mpeg2TS with h264 and AC3 should result in this format.
aeproberts
Post Tue Aug 24, 2010 3:00 pm
Anyone have a profile that would work with my Sony Bravia BDP-S570 Bluray Player?
I believe the Sony BDP-s570, 470 and 370 are all the same.
I have been having a hell of a time getting video to work with other DLNA servers.
Post Tue Aug 24, 2010 4:37 pm
aeproberts wrote:Anyone have a profile that would work with my Sony Bravia BDP-S570 Bluray Player?
viewtopic.php?f=5&t=326
Post Tue Aug 31, 2010 4:00 pm
For information, firmware of Sony Bravia 2010 series upgrade:
http://support.sony-europe.com/tvhc/dow ... DL-46EX501
About this upgrade (24/08/2010)
This file updates your TV set firmware to version PKG4.068EUL-0107, and provides the following benefits:
Improvements in this version
Improve performance & stability of IPTV features.
i-Manual update.
erro
Post Fri Sep 10, 2010 12:11 pm
I've just started using serviio and my DLNA media player with great satisfaction so far.
The only thing is that as mentioned here before my EX505 doesn't support .srt subtitles so the proposed <subs...> won't work.
I need to transcode/remux it using virtualdub/avidemux.
Is it possible to have serviio/ffmpeg remux the .srt during the transcode operation ?
thanks.
Post Fri Sep 10, 2010 12:19 pm
No, because ffmpeg doesn't support it ;-/ I'll try to follow and implement it if they decide to do that in future.
erro
Post Fri Sep 10, 2010 2:16 pm
thanks.
It seems that it is going to be support in the next version:
http://ffmpeg.org/changelog.html
any idea when it is due ?
Post Fri Sep 10, 2010 2:51 pm
I'm actually not sure if that is what we need (srt mux). It's already in their repository, so anybody can build it. If someone manages to burn subs into the stream, let me know.
Users browsing this forum: No registered users and 100 guests
