API Documentation - JSON
Post Tue Dec 06, 2011 5:02 pm
Just a quick thing, could you update the API Documentation "Section 2.1 XML or JSON" to note that you need to add the header "Accept: application/json" if you want serviio to respond with json. You noted that you need to set Content-Type so I did that and I then spent 20 min wondering why the response was xml. Mostly my fault as its my first attempt at writing anything that uses webservices, but hopefully it will save someone else some time.
Post Tue Dec 06, 2011 5:26 pm
Re: API Documentation - JSON
will do thanks
kairoh
Post Tue Dec 06, 2011 9:42 pm
To use json you can either :
- Set HTTP header "Accept: application/json" to your requests.
- Add "media=json" to your request parameters (in URL or in submitted forms).
For example :
http://localhost:23423/rest/application => get XML response
http://localhost:23423/rest/application?media=json => get JSON response
Or use both...
Serviio WebUI console developer : New Homepage | Support | Project | Issues
Samsung UA32C6600 | WinXP / Ubuntu 11.10 | Samsung Galaxy S | Freebox v6
Post Wed Dec 07, 2011 11:43 am
kairoh wrote:http://localhost:23423/rest/application?media=json => get JSON response
Thanks, that will be useful for testing things out quickly without using CURL.
