Samsung Youtube HD problem
fxandrei
Post Mon Dec 05, 2011 8:23 am
So i have a samsung UE37D5000 .
I got the youtube plugin and entered some online feed in the gui, something like http://gdata.youtube.com/feeds/api/stan ... /top_rated .
The thing is that everything works fine if the quality is set to medium, but if i set it to High my samsung tv shows a "codec not supported" message.
I did a little search and i saw that there is a modified plugin version that limits the resolution (i thought that this was the problem) but i got the same message.
So i dont know what i can do .
Can someone pls give me some dirrection, or what to check ?
By the way.
Great software.
I cannot believe that this software does the stuff it does for free.
Post Mon Dec 05, 2011 6:32 pm
Re: Samsung Youtube HD problem
leave it as medium the samsung cant cope with the high setting.
Post Mon Dec 05, 2011 6:48 pm
Actuallly the Samsung can handle the high setting (up to 1080P) just fine. Problem is the groovy is accepting formats that Serviio and ffmpeg do not support.
Try this groovy which corrects the problem for me.
Youtube.groovy
(6.34 KiB) Downloaded 857 times
fxandrei
Post Tue Dec 06, 2011 6:10 am
The samsung care surely cope with 1080 resolution.
So i used that plugin but still , it does not work, i still get the "codec not supported" message.
Post Tue Dec 06, 2011 8:15 am
i wasnt talking about resolution i was talking from the point of view of bitrate.
fxandrei
Post Tue Dec 06, 2011 8:41 am
Well, im not sure about exact numbers, but i can stream wirelessly hd youtube from my acer iconia a500 via beam browser (i think its called tvonky).
And i saw even 1080p movies from another streaming server(i think it was mezzmo).
Like i said, im not sure about the bitrate but it looked ok.
Post Tue Dec 06, 2011 6:57 pm
I stream my desktop to my Samsung at 20,000 kbps without any problem so I don't understand how the claim can be made that the Samsung cannot handle high bitrates. It would be helpful if some supporting information accompanied these types of posts so we can all build an accurate knowledge base, rather than having to correct unsubstantiated assertions.
Since 3000-4000kbps is the typical rate for Youtube 1920x1080 avc videos there should be no problem.
I don't know why this groovy does not work for you since it eliminates all the codecs that Serviio does not support, but without knowing the video you are trying to play I cannot diagnose it for you.
It is possible that you have selected a video for which there is only a low quality h263 version, and the bug reported as https://bitbucket.org/xnejp03/serviio/issue/429/samsung-d-series-tv-wont-play-transcoded applicable to D series TV's
means you will get the codec error. The fix for me was to add a maxVBitrate=30000 parameter to the transcoding rule as attached to the bug report.
fxandrei
Post Tue Dec 06, 2011 10:19 pm
So i have this in my online sources list :
http://gdata.youtube.com/feeds/api/user ... ft/uploads
Try to play any video.
They are all 1080p.
I always get "video codec not supported" if i set the video quality to high.
Post Wed Dec 07, 2011 5:28 am
I have no idea what your problem is.. using your link, with my youtube.groovy and quality set to high on release 6.0.1 and they all play fine at 1920x1072. I even tested the standard groovy and it works fine too.
I can only guess that you are using low quality and encountering the bug I previously mentioned.
fxandrei
Post Wed Dec 07, 2011 6:35 am
well then, could u post ur groovy ?
and i am sure that the quality is set to high.
Post Wed Dec 07, 2011 5:14 pm
fxandrei wrote:well then, could u post ur groovy ?
It was posted above and you said you used it. But regardless the normal groovy works fine too. You have to set the quality in the console and restart Serviio for it to take effect.
Why don't you post your log with debug on.
fxandrei
Post Wed Dec 07, 2011 7:39 pm
how do i turn debug on ?
cuz im seeing that serviio.log isnt updated after i try to view something on my tv.
so how do i do this ?
Post Thu Dec 08, 2011 12:10 am
look thru or search the forum
Post Thu Dec 08, 2011 1:40 pm
fxandrei wrote:how do i turn debug on ?
Did you notice the big READ BEFORE POSTING !!! topic in this forum?
fxandrei
Post Thu Dec 08, 2011 4:59 pm
SORRY :D
So i turned debug on .
Deleted all the contents of serviio.log and restarted the service.
Then i went to my tv and tryied to play some stuff.
I have the file atached.
serviio.zip
(53.58 KiB) Downloaded 596 times
Post Thu Dec 08, 2011 5:18 pm
Ok, that looks fine. All the files are transcoded to mpeg2. You might have to update your profile to limit the bitrate, jhb50 has a profile that does it - see if that helps.
fxandrei
Post Thu Dec 08, 2011 8:12 pm
So i searched around and i found this :
viewtopic.php?f=23&t=3279&start=60
that lead me to
https://bitbucket.org/xnejp03/serviio/i ... ranscoding
So i tried to edit my profile , and i added
<OnlineTranscoding>
   <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" maxVBitrate="30000">
      <Matches container="mp4"/>
   <Audio targetContainer="mp3">
      <Matches container="flv"/>
   </Audio>
</OnlineTranscoding>
just before </Profile> for samsung.
But still no luck.
I must be doing something wrong.
What exactly and where should i modify my profile ?
Post Thu Dec 08, 2011 10:15 pm
That should have worked, but the correct fix is the change posted in the bitbucket 432 that you referenced. Its only purpose is to override the transcoding specified in profile #2 which #7 inherited.
fxandrei
Post Fri Dec 09, 2011 7:12 am
Im kinda confused.
I thought that i modified what i was supposed to.
I'm not really what and where should i modify.
Could u please assist me a bit ?
Post Fri Dec 09, 2011 5:25 pm
I'll say it again.. use the fix as posted in 432. Add it in front of /profile like you did before. Works for me. If it doesn't work for you you will have to analyse the log, look at your transcoding .stf result and test it as a file by renaming to .mpg and change your transcoding rules accordingly until the TV plays it.
Users browsing this forum: Google [Bot] and 6 guests
