Remote Console
- When using the windows console as a remote console for an instance running on another computer it is FAR to easy to select "Exit Serviio" vs "Exit Console" and stop the server all together..
- I think it would be nice if the console would open regardless of the server status and if there was an option in the console interface to select the server, instead of editing the config file.
