Re: How do I install Serviio on a Zyxel NSA-310 ?
I've been away from for a few days and my internet connection is really poor the past few weeks. I'll try it this evening again.
Dangerousp wrote:I did get FFP to work properly. Did you enable sshd and then maybe disable telnet? If so try to start it again in sshd with /ffp/start/telnetd.sh start
harpoon wrote:Dangerousp wrote:I did get FFP to work properly. Did you enable sshd and then maybe disable telnet? If so try to start it again in sshd with /ffp/start/telnetd.sh start
How do I do this ? I cannot telnet to my NSA-310 after the reboot. My NSA-310 seems to have booted normally and busybox is running.
The only way I got to telnet to my NSA-310 was to use the Zyxel backdoor.
When FFP is working, should I still get the Zyxel WebUI ?
Dangerousp wrote:harpoon wrote:Dangerousp wrote:I did get FFP to work properly. Did you enable sshd and then maybe disable telnet? If so try to start it again in sshd with /ffp/start/telnetd.sh start
Well, I just did what was on the site http://zyxel.nas-central.org/wiki/FFP-stick
Yes, when ffp is working all the functions of the Zyxel are still working as normal.
I allready tried to do what's in this thread, but I get stuck on the readme file in the zip file. I've got two volumes instead of one, so I don't know exactly where the files should be pasted. Also making the requested folders is not possible for me, putty says nothing and I can't see the paths on my stick. In other directories it does work, but the one in the readme doesn't.
I will try the more complex method when I have time!
Dangerousp wrote:to be more specific:
Step 2) I can't put them on volume 1, because that one is to small. I do have a volume 2, but I don't know where to put it. I also can't make the /mnt/HD/HD_a2/tsqueeze folder.. so I'm a bit stuck at this point.
#!/bin/sh
# This file is part of the 'FFP-stick for ZyXEL NSA-nnn'
# http://zyxel.nas-central.org/wiki/FFP-stick
# This program is free software; you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by the
# Free Software Foundation; either version 2, or (at your option) any
# later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# Author: Mijzelf <Mijzelf@live.com>
# This script is supposed to be started by usb_key_func.sh, or by itself
# Run without params for a brief help
SCRIPTVERSION="20110712"
LOGFILE="ffpboot.log"
WHILEBOOTING="while_booting.sh"
AFTERBOOTING="after_booting.sh"
TMPSTICK="/tmp/.ffpstick"
TMPROOT="/tmp/ffproot"
FATFILES="${WHILEBOOTING} \
usb_key_func.sh \
nsa210_check_file md5sum \
nsa220_check_file \
NSA221_check_file salted_md5sum \
nsa310_check_file_C0 salted_md5sum_3x0 "
EXT3FILES="${AFTERBOOTING} rootfs.tgz fun_plug.tgz"
# Filled in by commandline params
USBDEVICE=
NASTYPE=
FIRMWARE=
USELOGFILE=""
PARNERKEY_MP=""
# function SplitPath
# split path in first parameter in path and filename
SPLITTEDPATH="" # Output path
SPLITTEDFILE="" # Output file
SplitPath()
SPLITTEDPATH=""
SPLITTEDFILE=""
IFSBACKUP=${IFS}; IFS=/
for chunk in $1
do
newpath=""
if [ "${SPLITTEDPATH}" = "" ] ; then
newpath="${chunk}"
else
newpath="${SPLITTEDPATH}/${chunk}"
fi
if [ "${newpath}" = "$1" ] ; then
SPLITTEDFILE="${chunk}"
elif [ "/${newpath}" = "$1" ] ; then
SPLITTEDPATH="/${SPLITTEDPATH}"
else
SPLITTEDPATH="${newpath}"
fi
done
IFS=${IFSBACKUP}
if [ "" = "${SPLITTEDPATH}" ] || [ "." = "${SPLITTEDPATH}" ]; then
SPLITTEDPATH=` pwd `
fi
# function GetNasType
# Try to find out the NAS type, and FW
NASTYPE="" # output NAS type
FIRMWARE="" # output FW
# Actually from the viewpoint of the FFP stick there are only 2 types:
# - NSA220 firmware 2.20 or lower, which has a different mountpoint
# - All other NASsen/firmwares
GetNasType()
if [ -x /zyxel/sbin/mrd_model ]; then
model=` /zyxel/sbin/mrd_model -p `
case ${model} in
D401)
NASTYPE="NSA210"
D501)
NASTYPE="NSA220"
DA01)
NASTYPE="NSA310"
DC01)
NASTYPE="NSA221"
DD01)
NASTYPE="NSA320"
esac
fi
if [ "" = "${NASTYPE}" ]; then
case ` uname -r ` in
2.6.18.6*)
NASTYPE="NSA220"
2.6.24.4*)
NASTYPE="NSA210"
NASTYPE="Unknown-${model}"
esac
fi
if [ -r /zyxel/mnt/info/fwversion ] ; then
FIRMWARE=` cat /zyxel/mnt/info/fwversion `
elif [ -r /etc/fwversion ]; then
FIRMWARE=` cat /etc/fwversion `
fi
if [ "" = "${FIRMWARE}" ]; then
FIRMWARE="Undetermined"
fi
# function JumpToRepartition
# copies all needed files to ramdisk,
# and passes execution to script there
JumpToRepartition()
echo Copy files to ramdisk...
mkdir -p ${TMPSTICK}
filelist=${FATFILES}
local copied=""
local notcopied=""
for loop in 1 2 3
do
for file in ${filelist}
do
if [ -r ${SPLITTEDPATH}/${file} ] ; then
if cp ${SPLITTEDPATH}/${file} ${TMPSTICK}/${file}; then
copied="${copied} ${file}"
else
rm ${TMPSTICK}/${file}
notcopied="${notcopied} ${file}"
fi
fi
done
if [ 1 -eq ${loop} ]; then
filelist=${EXT3FILES}
else
filelist=${SPLITTEDFILE}
fi
done
echo "Copied${copied}"
if [ "" != "${notcopied}" ]; then
echo "*Not* copied${notcopied}"
fi
if [ "" != "${USELOGFILE}" ]; then
exec >/dev/null 2>&1
cp -a ${SPLITTEDPATH}/${USELOGFILE} ${TMPSTICK}/${USELOGFILE}
exec >>${TMPSTICK}/${USELOGFILE} 2>&1
sync
fi
exec ${TMPSTICK}/${SPLITTEDFILE} Repartition -m ${PARNERKEY_MP} -d ${USBDEVICE} -l
# function FirstCall
# This is the original call of the script
FirstCall()
echo ffpstick started at ` date `
echo -ne Try to determine NAS type...
GetNasType
echo type ${NASTYPE}, fw ${FIRMWARE}
PARNERKEY_MP="/mnt/parnerkey"
if [ "${NASTYPE}" = "NSA220" ]; then
if cat ${SPLITTEDPATH}/nsa220_check_file | grep -v parnerkey >/dev/null ; then
PARNERKEY_MP="/mnt"
fi
fi
if [ "${PARNERKEY_MP}" != "${SPLITTEDPATH}" ]; then
echo FATAL Wrong mountpoint ${SPLITTEDPATH}, should have been ${PARNERKEY_MP}
echo Cowardly refusing to install/start FFP in an unknown environment
exit 1
fi
if [ -e /tmp/${SPLITTEDFILE} ]; then
echo For some reason this script is called multiple times
exit 1
fi
echo -ne Find the current usb device...
usbdev=`cat /proc/mounts | grep ${SPLITTEDPATH} | grep -v ram | tail -n 1 | awk '{print $1}'`
if [ "${usbdev}" = "" ]; then
echo FATAL Usbdevice not found
exit 1
fi
echo -ne usb device is ${usbdev}
USBDEVICE=` echo ${usbdev} | sed 's/[0-9]*//g' `
if [ "${USBDEVICE}" = "${usbdev}" ] ; then
echo
else
echo " on device ${USBDEVICE}"
fi
if [ -x ${SPLITTEDPATH}/${AFTERBOOTING} ]; then
echo -ne "Check for filesystem..."
filesystem=`cat /proc/mounts | grep ${SPLITTEDPATH} | grep -v ram | tail -n 1 | awk '{print $3}'`
echo Filesystem is ${filesystem}
if [ "${filesystem}" = "vfat" ] ; then
if [ "${USBDEVICE}" = "${usbdev}" ]; then
echo ${usbdev} is not partitioned. Will have to partition it
JumpToRepartition
else
echo -ne "Check ${USBDEVICE} for number of partitions..."
partition_num=`fdisk -l ${USBDEVICE} | grep "^"${USBDEVICE} | wc -l `
echo ${USBDEVICE} has ${partition_num} partitions
if [ ${partition_num} -eq 1 ] ; then
echo Will have to repartition
JumpToRepartition
fi
fi
fi
else
echo No ${AFTERBOOTING} in the root of the ffpstick found
echo This is not the first run, or FFP is supposed to run from a different place
fi
# Execute an eventual '${WHILEBOOTING}' script
if [ "${WHILEBOOTING}" != "" ] && [ -x ${SPLITTEDPATH}/${WHILEBOOTING} ]; then
echo Executing ${WHILEBOOTING}...
cd ${SPLITTEDPATH}
${SPLITTEDPATH}/${WHILEBOOTING} ${usbdev} ${SPLITTEDPATH} ${NASTYPE} "${FIRMWARE}"
fi
echo -ne Copy myself to /tmp...
cp -pf ${SPLITTEDPATH}/${SPLITTEDFILE} ${TMPSTICK}/${SPLITTEDFILE}
if ! [ -x ${TMPSTICK}/${SPLITTEDFILE} ]; then
echo FATAL Failed to copy!
exit 1
fi
COMMAND="${TMPSTICK}/${SPLITTEDFILE} BackgroundPolling -d ${USBDEVICE} -n ${NASTYPE} -f \"${FIRMWARE}\" -l"
echo And execute...
echo "${COMMAND} &"
# Close logfile, maybe it will disturb the unmounting hereafter
sync
fi
cd /tmp
${COMMAND} &
exit 1
# function ReopenLogfile
# Arguments: device mountpoint copy/movecommand
# Mounts device on mountpoint, moves/copies current logfile to mountpoint
# and redirects output
ReopenLogfile()
if [ "" = "${USELOGFILE}" ] ; then
return 0
fi
if ! [ -d $2 ]; then
mkdir -p $2
fi
if ! mount $1 $2 ; then
return 1
fi
$3 ${TMPSTICK}/${USELOGFILE} $2/${USELOGFILE}
exec >>$2/${USELOGFILE} 2>&1
# function ProbeMountPoints
# Check all mountpoints for the existence of
# - usb_key_func.sh (this file) being the ffpstick
# - ffproot/after_booting.sh being the ffproot
# Outputs:
MP_FFPSTICK=""
MP_FFPROOT=""
ProbeMountPoints()
echo Probe all mount points $1 seconds...
mountpoints=`cat /proc/mounts | awk '{print $2}'`
for mp in ${mountpoints}
do
# count number of / in string. We're only interested with 2 or more
slashes=` echo ${mp} | tr -cd / `
if [ ${#slashes} -gt 1 ]; then
echo probe ${mp}...
if [ "" != "${USELOGFILE}" ] && [ "" = "${MP_FFPSTICK}" ] ; then
if cat /proc/mounts | grep ${mp} | grep ${USBDEVICE}1 >/dev/null ; then
MP_FFPSTICK=${mp}
echo "found ffpstick on ${MP_FFPSTICK}, moving logfile"
mv ${SPLITTEDPATH}/${USELOGFILE} ${MP_FFPSTICK}/${USELOGFILE}
exec >>${MP_FFPSTICK}/${USELOGFILE} 2>&1
fi
fi
if [ "" = "${MP_FFPROOT}" ] && [ -x ${mp}/ffproot/${AFTERBOOTING} ] ; then
MP_FFPROOT=${mp}/ffproot
echo found ffproot on ${MP_FFPROOT}
local device=`cat /proc/mounts | grep ${mp} | awk '{print $1}'`
if [ "${device}" = "${USBDEVICE}2" ] ; then
# This is the USB stick. Try to remount it relatime
if ! mount ${device} ${mp} -t ext3 -o remount,relatime 2>/dev/null ; then
# or, if relatime is not supported, noatime
mount ${device} ${mp} -t ext3 -o remount,noatime
fi
fi
fi
fi
done
if [ "" = "${MP_FFPROOT}" ]; then
echo No /anymountpoint/ffproot/${AFTERBOOTING} found
return 1
fi
return 0
# function BackgroundPolling
# function waits until NAS is booted, and has
# mounted the stick partition, and then starts ffp
BackgroundPolling()
echo Wait for the stick to be mounted again by the firmware...
sleep 30
if [ -r ${SPLITTEDPATH}/${SPLITTEDFILE} ]; then
rm ${SPLITTEDPATH}/${SPLITTEDFILE}
fi
local loopteller=0
local waitforstick=0
while [ 900 -gt ${loopteller} ]
do
ProbeMountPoints ${loopteller}
if [ "" != "${MP_FFPROOT}" ] ; then
if [ 3 -gt ${waitforstick} ] && [ "" = "${MP_FFPSTICK}" ] ; then
waitforstick=`expr ${waitforstick} + 1`
else
cd ${MP_FFPROOT}
# telnetd -l /bin/sh
exec ${MP_FFPROOT}/${AFTERBOOTING} ${MP_FFPROOT} ${NASTYPE} "${FIRMWARE}"
exit 0
fi
else
if [ "" = "${MP_FFPSTICK}" ] ; then
waitforstick=0
else
if [ 3 -eq ${waitforstick} ] ; then
# Have a look if we can mount the 2nd partition ourselfs
echo "30 seconds should be enough for anybody ;)"
echo Will try to mount ffproot myself
mkdir -p ${TMPROOT}
mount ${USBDEVICE}2 ${TMPROOT}
fi
fi
fi
loopteller=`expr ${loopteller} + 10`
sleep 10
done
ReopenLogile ${USBDEVICE}1 ${TMPSTICK} mv
echo Final attempt to mount the stick myself
mkdir -p ${TMPROOT}
if mount ${USBDEVICE}2 ${TMPROOT} ; then
MP_FFPROOT=${TMPROOT}/ffproot
if [ -x ${MP_FFPROOT}/${AFTERBOOTING} ] ; then
cd ${MP_FFPROOT}
exit 0
fi
echo FATAL No ${MP_FFPROOT}/${AFTERBOOTING} found
exit 0
fi
echo FATAL Mounting failed
echo "FATAL Timeout & Giving up"
ReopenLogfile ${USBDEVICE}1 ${TMPSTICK} mv
exit 0
# function FatalErrorInRepartitioning
# Is called when repartitioning failed.
# It will try to put the logfile back on the stick
# and collect more info
FatalErrorInRepartitioning()
echo FATAL $1
# Try to get the logfile back on the stick
if ! ReopenLogfile ${USBDEVICE}1 ${PARNERKEY_MP} mv ; then
ReopenLogfile ${USBDEVICE} ${PARNERKEY_MP} mv
fi
for dmp in mounts filesystems partitions
do
echo =================
echo cat /proc/${dmp}
cat /proc/${dmp}
done
echo dmesg:
dmesg
exit 1
TryToMount()
echo -ne Mount $1 on $2...
local counter=0
mount $1 $2 -t $3
while [ 0 -ne $? ];
do
echo
counter=` expr ${counter} + 1 `
if [ ${counter} -gt 5 ]; then
FatalErrorInRepartitioning "Mount $1 on $2 failed"
fi
echo -ne Couldn\'t mount $1 on $2. Will retry in 5 seconds...
sleep 5
mount $1 $2 -t $3
done
echo done
Repartition()
echo Repartition ${USBDEVICE}
echo -ne unmount ${PARNERKEY_MP}...
umount ${PARNERKEY_MP}
echo done
# Clear dmesg, just in case we get a fatal error.
dmesg -c >/dev/null 2>&1
echo Repartitioning...
echo -e "o\nn\np\n1\n\n+16M\nn\np\n2\n\n\nt\n1\n4\nw\n" | fdisk ${USBDEVICE}
if [ "0" != "$?" ]; then
FatalErrorInRepartitioning "Partitioning failed"
fi
echo Done. Creating and mounting filesystems...
echo Create ext3 filesystem on ${USBDEVICE}2 and mount...
if ! mke2fs -L FFPROOT -j ${USBDEVICE}2 ; then
FatalErrorInRepartitioning "Couldn\'t create ext3 fs on ${USBDEVICE}2"
fi
sync
TryToMount ${USBDEVICE}2 ${PARNERKEY_MP} ext3
echo -ne Move files...
mkdir -p ${PARNERKEY_MP}/ffproot
for file in ${EXT3FILES}
do
if [ -r ${TMPSTICK}/${file} ]; then
echo -ne ${file}...
mv ${TMPSTICK}/${file} ${PARNERKEY_MP}/ffproot/
fi
done
chmod 700 ${PARNERKEY_MP}/ffproot/${AFTERBOOTING}
echo done
echo -ne Create dummy symlinks...
cat >${PARNERKEY_MP}/.readme <<_EOF_
zyshd runs "rm \` find /mountpoint/of/stick -type l \`"
after mounting any external device.
This removes all symlinks from the device, rendering FFP useless.
The bunch of symlinks here are added to overflow the commandline,
making rm fail with an "Argument list too long"
instead of deleting all symlinks
_EOF_
# Generate long name (128 characters)
local counter=0
longname=LongName
while [ ${counter} -le 3 ] ; do
longname=${longname}${longname}
done
# Generate 512 symlinks (total filename length = 64k)
counter=0
while [ ${counter} -le 512 ]
do
ln -s ".readme" ${PARNERKEY_MP}/.${counter}${longname}
done
echo done
echo -ne Unmount ${USBDEVICE}2...
echo done
echo -ne Create FAT filesystem on ${USBDEVICE}1 and mount...
if ! mkdosfs -n FFPBOOT ${USBDEVICE}1 ; then
FatalErrorInRepartitioning "Couldn\'t create vfat fs on ${USBDEVICE}1"
fi
sync
TryToMount ${USBDEVICE}1 ${PARNERKEY_MP} vfat
for file in ${FATFILES}
do
echo -ne ${file}...
fi
done
echo -ne ${SPLITTEDFILE}...
cp ${SPLITTEDPATH}/${SPLITTEDFILE} ${PARNERKEY_MP}/
echo done
mv ${TMPSTICK}/${USELOGFILE} ${PARNERKEY_MP}/${USELOGFILE}
exec >>${PARNERKEY_MP}/${USELOGFILE} 2>&1
sync
fi
exec ${PARNERKEY_MP}/${SPLITTEDFILE} FirstCall -l
OpenLogfile()
if [ "" = "${LOGFILE}" ]; then
return 0
fi
USELOGFILE=${LOGFILE}
logfile=${SPLITTEDPATH}/${USELOGFILE}
if [ "$1" = "extended" ] ; then
templog=${SPLITTEDPATH}/templog.log
exec >>${templog} 2>&1
# Try to save older bootlogs
echo Some logfile administration...
oldlog=${logfile}.9.gz
if [ -r ${oldlog} ] ; then
echo rm ${oldlog}
rm ${oldlog}
fi
for nr in 8 7 6 5 4 3 2 1
do
oldlog=${logfile}.${nr}.gz
newnr=`expr $nr + 1`
newlog=${logfile}.${newnr}.gz
echo mv ${oldlog} ${newlog}
fi
done
if [ -r ${logfile} ] ; then
echo "cat ${logfile} | gzip -c >${oldlog}"
rm ${logfile}
fi
mv ${templog} ${logfile}
fi
exec >>${logfile} 2>&1
PrintHelp()
echo Usage: ${SPLITTEDFILE} command arguments
echo " command is one of:"
echo " FirstCall"
echo " Repartition"
echo " BackgroundPolling"
echo " Help"
echo " arguments:"
echo " -f <firmware>"
echo " -n <nastype>"
echo " -d <usbdevice>"
echo " -m <mountpoint> (normally /mnt/parnerkey)"
echo " -l redirect output to logfile"
echo " -ll shift logfiles and redirect output"
ReadParams()
shift
while [ "$1" != "" ] ; do
case $1 in
-f)
FIRMWARE=$2
shift
-n)
NASTYPE=$2
shift
-d)
USBDEVICE=$2
shift
-m)
PARNERKEY_MP=$2
shift
-h)
PrintHelp
-l)
OpenLogfile
-ll)
OpenLogfile extended
echo Unknown option $1
esac
shift
done
# Entrypoint of the script
# Find filename and path
SplitPath $0
# Read the command
COMMAND=$1
# Read params
if [ $# -gt 1 ]; then
ReadParams $@
fi
echo Script ${SPLITTEDFILE} version ${SCRIPTVERSION} running from ${SPLITTEDPATH}
case ${COMMAND} in
FirstCall)
FirstCall
exit 1
Repartition)
Repartition
BackgroundPolling)
BackgroundPolling
Help)
PrintHelp
NSA221Finish)
umount /mnt/parnerkey
rmdir /mnt/parnerkey
if [ -x /tmp/NSA221Finish.sh ]; then
exec /tmp/NSA221Finish.sh
fi
PrintHelp
esac
#!/bin/sh
# later version.
# This script has multiple functions.
# - Download, unpack and start ffp
# - Stop ffp
# - Execute any function outside the ffp chroot
# It is supposed to be started by usb_key_func.sh/fun_plug.sh or by itself.
# Execute the script without params for a brief help
# Options
# Uncomment next line if you want a /ffp symlink
# FFPSYMLINK=1
# Uncomment next line if you don't want to chroot (you'll need the /ffp symlink too).
# NOCHROOT=1
# (The script will chroot anyway if the root is read only, or if you
# didn't enable the /ffp symlink
# Uncomment next line if you want the rootpassword changed, when not chrooting
# CHANGEROOTPASSWORD=1
# Edit the function ChangePasswords() to add your users/passwords/hashes
# End of options
FFPROOT=
NASTYPE=
FIRMWARE=
CHROOTDIR=
HELPERDIR=/tmp/.ffpstick/
HELPERFILE=helper.inc
# environment: current directory changes
SplitPath()
SPLITTEDPATH=""
SPLITTEDFILE=""
for chunk in $1; do
newpath=""
newpath="${chunk}"
else
fi
else
fi
done
IFS=${IFSBACKUP}
if [ "" != "${SPLITTEDPATH}" ]; then
cd ${SPLITTEDPATH}
fi
# function CleanUp
# Delete some unneeded (and possibly dangerous) DNS-323 scripts
CleanUp()
echo -ne Delete some DNS-323 specific stuff...
for file in start/passwd.sh start/rcS.sh start/shells.sh sbin/store-passwd.sh
do
rm -f ffp/${file}
done
echo done
# function Unpack_fun_plug
# Unpack fonz' base package
# 1st argument: filename
Unpack_fun_plug()
echo Unpack ${FFPROOT}/$1...
cd ffp
tar -xzf ../$1
cd ..
rm $1
echo Done
CleanUp
# function CheckForFfpTarball
# Check for a user-provided ffp base package either in /path/to/ffproot
# or it's parent (the ext3 partition of the ffp-stick)
CheckForFfpTarball()
# find ffp tarball
for file in fun_plug.tgz ../fun_plug.tgz
do
if [ -r ${file} ]; then
Unpack_fun_plug ${file}
fi
done
# function TryToDownload
# Downloads ffp base package from inreto.de
TryToDownload()
if ! [ -x wget ]; then
echo No wget found
return 0
fi
echo Will try to download fun_plug.tgz
echo If the script stops here, downloading the tarball from inreto.de failed.
echo You can try to get internet access for the ${NASTYPE},
echo "or copy fun_plug.tgz (case sensitive!) to the share containing ffproot."
echo It should be recognized and installed.
echo It is possible that you have to reboot the box before this share shows up.
echo ping www.inreto.de...
while ! [ -r ffp/bin/busybox ] && ! ping -c 1 www.inreto.de >/dev/null ; do
sleep 10
CheckForFfpTarball
done
if ! [ -r ffp/bin/busybox ]; then
echo www.inreto.de found. Downloading fun_plug.tgz...
cd ffp
../wget -qO- http://www.inreto.de/dns323/fun-plug/0.5/fun_plug.tgz | tar -xz
if [ "$?" != "0" ] ; then
echo Download failed.
else
echo fun_plug.tgz is downloaded
CleanUp
fi
cd ..
fi
# Say hello to the author of this script. This doesn't do anything, (the file doesn't exist, so you'll get
# a 404), except generating a logline on my webserver. (When it's online), Then I know that yet another
# FFP-stick is created. I like that. ;)
# If you want to opt-out, just remove the line below
./wget -qO- http://mijzelf.hopto.org/hello_author.php?nas=${NASTYPE}\&firmware=${FIRMWARE} >/dev/null 2>&1
rm ./wget
# Function added 20101217 to solve the problem that the /i-data/md0
# symlink was not copied right on the NSA-320
CopySymlink()
echo CopySymlink $1 $2
target=` ls -l $1 | awk -F\ '{print $NF}' `
echo ln -s $target $2
ln -s $target $2
# function CopyTree
# Helper function for the NSA3x0.
CopyTree()
echo CopyTree $1 $2 $3
if [ -h $2 ] ; then
# Directory turns out to be a symlink. Just copy it
CopySymlink $2 $3
return 0
fi
mkdir $3
if mountpoint $2 ; then
# Directory is a mountpoint
mount --bind $2 $3
if [ "0" != "$?" ] ; then
return 1
fi
return 0
fi
for file in ` ls $2 `
do
if [ -d $2/${file} ] ; then
# File is a directory
CopyTree $1 $2/${file} $3/${file}
return 1
fi
# Added 2011-03-08; Changed 2011-03-23;
# The NSA-320 has a symlink /etc/exports,
# which points to a non-existing file
# as long as the nfs packet is not installed.
# This frustrated this copy script
elif [ -h $2/${file} ] ; then
# File is a symlink. Just copy it
CopySymlink $2/${file} $3/${file}
else
case $1 in
ln)
ln $2/${file} $3/${file}
cp)
cp -p $2/${file} $3/${file}
esac
return 1
fi
fi
done
return 0
# function NSA320BindAll
# Helper function for the NSA320. Because the firmware directories cannot
# be bind-mounted on the FFP-stick directories, we'll inverse it.
# Basically the rootfs is doubled using hardlinks, and the 2nd copy is
# chrooted, with the FFP-stick bindmounted on /2ndcopy/ffp
NSA320BindAll()
chdir=/tmp/bindroot
mkdir ${chdir}
for dir in bin sbin lib usr i-data e-data dev mnt
do
CopyTree ln /${dir} ${chdir}/${dir}
echo Failed to CopyTree /${dir}
return 1
fi
done
mkdir ${chdir}/tmp
mount -t tmpfs tmfs ${chdir}/tmp
echo Failed to mount tmpfs on ${chdir}/tmp
return 1
fi
echo ` date ` Waiting for fadd to show up...
while ! ps | grep /sbin/fadd >/dev/null ; do
sleep 10
done
echo ` date ` Hello fadd!
CopyTree cp /etc ${chdir}/tmp/.etc
echo Failed to CopyTree /etc
return 1
fi
# Because the files in /etc are bound to be changed by the firmware, we can't just make hardlinks to
# it. We'll just hijack the map...
mount --bind ${chdir}/tmp/.etc /etc
echo Failed to bind ${chdir}/tmp/.etc on /etc
return 1
fi
# Added 20101221 to solve the problem that the 'default' shares were not
# exported, only the user made ones. The mount mtd4 on /etc/zyxel was lost.
echo mount --bind ${chdir}/tmp/.etc/zyxel /etc/zyxel
ln -s ${FFPROOT}/ffp ${chdir}/ffp
ln -s ${FFPROOT}/ffp/etc ${chdir}/etc
ln -s ${FFPROOT}/after_booting.sh ${chdir}/after_booting.sh
mount --bind ${chdir}/tmp/.etc ${chdir}${FFPROOT}/ffp/etc/original
mount --bind ${chdir}/tmp/.etc/zyxel ${chdir}${FFPROOT}/ffp/etc/zyxel
# We'll hijack /var/log to, for the same reason...
ln -s ${FFPROOT}/var ${chdir}/var
CopyTree cp /var/log ${chdir}/tmp/.log
mount --bind ${chdir}/tmp/.log /var/log
mount --bind ${chdir}/tmp/.log ${chdir}${FFPROOT}/var/log
if ! [ -d ${chdir}/dev/pts ]; then
mkdir ${chdir}/dev/pts
fi
mount -t devpts devpts ${chdir}/dev/pts
mkdir ${chdir}/proc
mount -t proc proc ${chdir}/proc
mkdir ${chdir}/sys
mount -t sysfs sys ${chdir}/sys
mkdir ${chdir}/home
mount --bind ${FFPROOT}/home ${chdir}/home
# Restart Samba because it has gone mad about the etc exchange
/etc/init.d/samba.sh restart
CHROOTDIR=${chdir}
return 0
# function ClassicBindAll
# All firmware root directories are bind mounted on ffproot
ClassicBindAll()
# mount directories for chroot
tomount="e-data i-data"
for arg in rbind bind
do
for tm in ${tomount}
do
mount --${arg} /${tm} ${tm}
return 1
fi
done
tomount="dev var tmp bin sbin lib usr"
done
mount --bind /etc ffp/etc/original
mount --bind /etc/zyxel ffp/etc/zyxel
mount -t proc none proc
mount -t sysfs none sys
CHROOTDIR=${FFPROOT}
return 0
# function FinalBindAll
# 'poor man's chroot'
# FFP is chrooted with hardly any connection to the firmware
FinalBindAll()
CopyTree cp /dev ${FFPROOT}/dev
if ! [ -d ${FFPROOT}/dev/pts ] ; then
mkdir ${FFPROOT}/dev/pts
fi
mount -t devpts devpts ${FFPROOT}/dev/pts
for dir in i-data e-data
do
mkdir ${FFPROOT}/${dir}
CopyTree cp /${dir} ${FFPROOT}/${dir}
done
mount -t proc proc proc
mount -t sysfs sys sys
WriteParams()
echo NASTYPE=${NASTYPE} >$1
echo FIRMWARE=${FIRMWARE} >>$1
echo FFPROOT=${FFPROOT} >>$1
echo CHROOTDIR=${CHROOTDIR} >>$1
# function ChangePasswords()
# Changes the default password for root (the default is 'disabled')
# and adds users and password if you like
ChangePasswords()
echo -ne Adding/changing passwords...
# You can add your own users here:
for name in user root
do
if ! cat /etc/passwd | grep ^${name} ; then
# User doesn't exist yet, so add it
adduser -G nobody -s /ffp/bin/sh ${name}
fi
# Delete password, so the shadow entry starts with name::
passwd -d ${name}
old=${name}::
hash=""
password=""
# You can specify the password per user, or specify the hash value,
# which is safer. Don't forget to escape your $
case ${name} in
user)
password=user
root)
# password=root
hash=\$1\$\$oCLuEVgI1iAqOA8pwkzAg1
password=${name}
esac
if [ "" = "${hash}" ]; then
# If hash is empty, create it:
tempfile=/tmp/$$` date +%s `.tmp
makepwd ${password} | sed -e 's/\//\\\//g' >${tempfile}
hash=` cat ${tempfile} `
rm ${tempfile}
fi
new=${name}:${hash}:
mv /etc/shadow /tmp/shadow.bak
sed 's|'${old}'|'${new}'|' </tmp/shadow.bak >/etc/shadow
rm /tmp/shadow.bak
done
echo done
# function StartFFP()
# main function. Will download ffp if necessary
# create an environment for chrooting,
# chroot ffp
StartFFP()
# create rootdirectory
if [ -r rootfs.tgz ]; then
echo -ne Extract rootfs.tgz...
tar -xzf rootfs.tgz
rm rootfs.tgz
echo Done
fi
CheckForFfpTarball
if ! [ -r ffp/bin/busybox ] ; then
TryToDownload
fi
echo Could not download fun_plug.tgz for some reason
echo Will start polling for the existance forever in the share containing ffproot...
while ! [ -r ffp/bin/busybox ]; do
sleep 10
CheckForFfpTarball
done
fi
if [ "${FFPSYMLINK:-notset}" != "notset" ] ; then
echo -ne Try to create a /ffp symlink...
ln -s ${FFPROOT}/ffp /ffp
if [ -x /ffp/bin/busybox ]; then
echo done
else
echo "Failed. (Read only rootfs?)"
fi
fi
if [ "${NOCHROOT:-notset}" != "notset" ] ; then
if [ -x /ffp/bin/busybox ] ; then
NOCHROOT=1
if [ "${CHANGEROOTPASSWORD:-notset}" != "notset" ] ; then
ChangePasswords
fi
else
echo Cannot answer to the 'nochroot' request. There is no /ffp symlink
NOCHROOT=0
fi
else
NOCHROOT=0
fi
if [ ${NOCHROOT} -eq 0 ] ; then
ClassicBindAll
if [ "$?" != "0" ]; then
echo "Bummer! Cannot bind directories. Will try the NSA320 hack to get it going"
NSA320BindAll
echo "The NSA320 hack doesn't work either. Will do the best I can to get it working"
echo Possibilities are limited.
FinalBindAll
fi
fi
echo Will chroot ffp on ${CHROOTDIR}
else
CHROOTDIR=""
fi
# Generate helper file
hf=${CHROOTDIR}${HELPERDIR}
echo -ne Generate helper file ${hf}...
mkdir -p ${hf}
chmod 755 ${hf}
WriteParams ${hf}${HELPERFILE}
echo done
# start helper
echo Start execute_outside_chroot Helper...
$0 InvokeHelper -c ${CHROOTDIR} &
sleep 1
echo done
# Copy /i-data/md0 symlink to /mnt/HD_a2 to make the ZyXEL more compatible with the DNS-323
if [ -h /i-data/md0 ] ; then
CopySymlink /i-data/md0 ${CHROOTDIR}/mnt/HD_a2
fi
# run fun_plug local, if present
if [ -x ${CHROOTDIR}/ffp/etc/fun_plug.local ]; then
chroot ${CHROOTDIR} /ffp/etc/fun_plug.local
fi
# start services
if [ -x ${CHROOTDIR}/ffp/etc/rc ]; then
exec chroot ${CHROOTDIR} /ffp/etc/rc
fi
else
CopySymlink /i-data/md0 /mnt/HD_a2
fi
if [ -x /ffp/etc/fun_plug.local ]; then
fi
# start services
if [ -x /ffp/etc/rc ]; then
exec /ffp/etc/rc
fi
fi
exit 0
# function StopFFP()
# terminates all ffp processes,
# unmounts all ffp mounts
StopFFP()
if [ "${CHROOTDIR}" = "" ]; then
echo /ffp/etc/rc stop
/ffp/etc/rc stop
fi
else
cd /
# stop services
chroot ${CHROOTDIR} /ffp/etc/rc stop
fi
fi
sleep 1
message="Try to kill all remaining chrooted processes"
for killtype in SIGTERM SIGKILL
do
# List of all programs pid
tokill=` ps | awk '{print $1}' `
for pf in $tokill
do
if [ -f /proc/$pf/maps ]; then
if grep ${CHROOTDIR}/ffp/lib /proc/$pf/maps >/dev/null ; then
# Program has some chrooted libraries loaded
if [ "${message}" != "" ] ; then
echo ${message} ; message=""
fi
echo " " ` cat /proc/$pf/cmdline `
kill -${killtype} $pf
fi
fi
done
sleep 1
message="Try a bit harder"
done
if [ "${CHROOTDIR}" = "" ] ; then
exit 0
fi
echo Unmount all FFP mounts...
tounmount=` cat /proc/mounts | grep ${CHROOTDIR} | awk '{print $2}' 2>/dev/null `
while [ "${tounmount}" != "" ]; do
# While loop because mounts are nested.
for unmount in ${tounmount} ; do
if umount $unmount 2>/dev/null ; then
echo " " $unmount
fi
done
done
echo done
exit 0
# function InvokeHelper()
# Helperfunction to be able to run programs outside the chroot.
# It will sleep until it's woken up by a SIGCONT,
# then in will execute scripts in HELPERDIR
InvokeHelper()
hd=${FFPROOT}${HELPERDIR}
hf=${hd}${HELPERFILE}
mv ${hf} ${hf}.tmp
cat ${hf}.tmp | grep -v HELPERPID >${hf}
rm ${hf}.tmp
if [ "$1" = "stop" ]; then
exit 0
fi
echo HELPERPID=$$ >>${hf}
while [ true ]; do
trap "InvokeHelper stop" SIGTERM
if [ ! -d ${hd} ] ; then
trap "echo Helper terminated" SIGTERM
exit 0
fi
local scripts=` ls ${hd} | grep helper | grep .sh `
if [ "${scripts}" != "" ] ; then
for script in ${scripts}
do
tmpfile=/tmp/$$` date +%s `
mv ${hd}${script} ${tmpfile}
chmod a+x ${tmpfile}
${tmpfile}
rm ${tmpfile}
done
else
kill -SIGSTOP $$
fi
done
PrintHelp()
echo Usage: $0 command arguments
echo " StartFFP"
echo " StopFFP"
echo " InvokeHelper"
echo " Help"
echo " arguments:"
echo " -f firmware"
echo " -n nastype"
echo " -r ffproot"
echo " -c chrootdir"
ReadParams()
shift
case $1 in
-f)
FIRMWARE=$2
shift
-n)
NASTYPE=$2
shift
-h)
PrintHelp
shift
-r)
FFPROOT=$2
shift
-c)
CHROOTDIR=$2
shift
esac
shift
done
if [ "" = "${CHROOTDIR}" ]; then
fi
hf=${CHROOTDIR}${HELPERDIR}${HELPERFILE}
if [ -r ${hf} ]; then
. ${hf}
fi
echo Starting $0 version ${SCRIPTVERSION} at ` date `...
SplitPath $0
FFPROOT=${SPLITTEDPATH}
if [ $# -eq 0 ]; then
PrintHelp
exit 0
fi
case $1 in
StartFFP)
ReadParams $@
StartFFP
StopFFP)
ReadParams $@
StopFFP
InvokeHelper)
ReadParams $@
InvokeHelper
Test)
ReadParams $@
tmpfile=/tmp/` date +%s%N `
WriteParams ${tmpfile}
cat ${tmpfile}
rm ${tmpfile}
if [ $# -eq 3 ]; then
# Assume this is an 'old style' call
FFPROOT=$1
NASTYPE=$2
FIRMWARE=$3
StartFFP
else
PrintHelp
fi
esac
#!/bin/sh
# Root DISK1
export DISK1=/mnt/HD/HD_a2
export DISTDIR=tsqueeze
cd $DISK1
mount --bind $DISK1 $DISTDIR$DISK1
mount --bind / $DISTDIR/mnt/root
mount --bind /dev $DISTDIR/dev
mount --bind /sys $DISTDIR/sys
mount --bind /proc $DISTDIR/proc
cp -f /proc/mounts $DISTDIR/etc/mtab
rm -f $DISTDIR/etc/fstab
touch $DISTDIR/etc/fstab
cp -f /etc/resolv.conf $DISTDIR/etc
hostname >$DISTDIR/etc/hostname
cp -f /etc/hosts $DISTDIR/etc
$DISK1/$DISTDIR/boot/chroot $DISK1/$DISTDIR /boot/linuxrc
tihob wrote:Hi,
I'll try to help since I have already some experience on how to install "serviio" on processors ARM5![]()
First, have you root access ?
if Yes, Zip is right, the first things to do, is to check if java is installed, or if you can install it.
if not, find a way to become root![]()
I don't know this linux version is a debian ? Do you have aptitude ?
What is your knowledge of Linux environments ?
Dangerousp wrote:I can't get it to extract.. when I reboot, nothing happens.
marght wrote:Hi.
I suggest to try this: http://openrouter.info/forum/viewtopic. ... 790#p15790
It works perfectly, but topic is in polish. I use is for 1 month without any problems.
First, you have to upgrade your NSA310 firmware to v. 4.40, next get 2 files: nsa310-ali.zip from http://www.2shared.com/file/fEXqAAxM/nsa310-ali.html and linux.tgz from http://www.2shared.com/file/sIHKCw8M/linux.html.
First file has to be extracted to flashdrive (with FAT filesystem !!!), then and copy second file to flashdrive as it is.
Reboot nas with flashdrive installed, after several minutes nas will turn off. Remove flashdrive and turn it on.
Debian will start with sshd, ip address from DHCP, user/pass: root/root
