[CLOSED] MKV True HD Codec Not Supported Problem on Samsung
Sammy51
Post Thu Dec 15, 2011 5:09 pm
First off, just want to start by saying how amazing Serviio is...thank you to the developers of this great software!
Backgroud on my setup:
TV: Samsung PS51D8000
AV Receiver: Yamaha v467 connected to TV via HDMI v1.4a
PC: Windows 7 64bit
LAN: Wired
Problem File: Dark Night BD MKV
Profile Used: Samsung TV / player (C/D-series)
Problem:
- Started by backing up my BD of Dark Night using DVDFab (8.1.3.2). Did a 'Blu Ray Copy' Main Movie and selected both audio AC3 and TrueHD as BD50. Did not select 'Remove HD Audio' as I want to keep the True HD Audio.
- Once the movie was on my harddrive, I then used DVDfab to compress down to BD25, again selecting both audio AC3 and TrueHD and making sure 'Remove HD Audio' was not selected.
- Once I had my BD25 copy of Dark Night, I used MakeMKV (1.6.16) to place in MKV container and again made sure I selected both audio's.
- Once this completed I played the file in VLC and was able to play the MKV no problems and was also able to switch between AC3 and TrueHD.
- I then added the MKV to the serviio library and atempted to play the MKV on my TV but I could hear no sound and got the error 'unsupported codec'. I was able to switch to AC3 and that worked fine and my AVR displayed Dolby Digital.
As the MKV plays perfectly in VLC with both audio, I think the problem maybe with either serviio or the TV ?
I have gathered some information and hope someone can take a look and point me in the right direction. Many thanks in advanced.
ffmpeg.exe -i...:
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "E:\My Videos\MKV Blu Rays\The
Dark Night.mkv"
nfig
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 6. 0 / 53. 6. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 25. 0 / 2. 25. 0
libswscale 2. 0. 0 / 2. 0. 0
[matroska,webm @ 012a8b00] Estimating duration from bitrate, this may be inaccur
ate
Input #0, matroska,webm, from 'E:\My Videos\MKV Blu Rays\The Dark Night.mkv':
title : THE DARK KNIGHT.Title0.BlurayRip
Duration: 02:32:11.20, start: 0.000000, bitrate: 640 kb/s
Chapter #0.0: start 0.000000, end 383.966000
title : (01)00:00:00:000
Chapter #0.1: start 383.966000, end 636.260000
title : (02)00:06:23:966
Chapter #0.2: start 636.260000, end 832.581000
title : (03)00:10:36:260
Chapter #0.3: start 832.581000, end 1074.198000
title : (04)00:13:52:581
Chapter #0.4: start 1074.198000, end 1299.339000
title : (05)00:17:54:198
Chapter #0.5: start 1299.339000, end 1570.026000
title : (06)00:21:39:339
Chapter #0.6: start 1570.026000, end 1776.274000
title : (07)00:26:10:026
Chapter #0.7: start 1776.274000, end 1902.483000
title : (08)00:29:36:274
Chapter #0.8: start 1902.483000, end 2269.058000
title : (09)00:31:42:483
Chapter #0.9: start 2269.058000, end 2614.069000
title : (10)00:37:49:058
Chapter #0.10: start 2614.069000, end 2799.546000
title : (11)00:43:34:069
Chapter #0.11: start 2799.546000, end 2937.768000
title : (12)00:46:39:546
Chapter #0.12: start 2937.768000, end 3199.446000
title : (13)00:48:57:768
Chapter #0.13: start 3199.446000, end 3435.640000
title : (14)00:53:19:446
Chapter #0.14: start 3435.640000, end 3566.354000
title : (15)00:57:15:640
Chapter #0.15: start 3566.354000, end 3839.627000
title : (16)00:59:26:354
Chapter #0.16: start 3839.627000, end 4103.557000
title : (17)01:03:59:627
Chapter #0.17: start 4103.557000, end 4248.327000
title : (18)01:08:23:557
Chapter #0.18: start 4248.327000, end 4464.918000
title : (19)01:10:48:327
Chapter #0.19: start 4464.918000, end 4685.639000
title : (20)01:14:24:918
Chapter #0.20: start 4685.639000, end 4942.437000
title : (21)01:18:05:639
Chapter #0.21: start 4942.437000, end 5088.583000
title : (22)01:22:22:437
Chapter #0.22: start 5088.583000, end 5448.443000
title : (23)01:24:48:583
Chapter #0.23: start 5448.443000, end 5644.972000
title : (24)01:30:48:443
Chapter #0.24: start 5644.972000, end 5997.783000
title : (25)01:34:04:972
Chapter #0.25: start 5997.783000, end 6125.494000
title : (26)01:39:57:783
Chapter #0.26: start 6125.494000, end 6299.918000
title : (27)01:42:05:494
Chapter #0.27: start 6299.918000, end 6420.872000
title : (28)01:44:59:918
Chapter #0.28: start 6420.872000, end 6669.913000
title : (29)01:47:00:872
Chapter #0.29: start 6669.913000, end 6854.639000
title : (30)01:51:09:913
Chapter #0.30: start 6854.639000, end 7024.017000
title : (31)01:54:14:639
Chapter #0.31: start 7024.017000, end 7214.248000
title : (32)01:57:04:017
Chapter #0.32: start 7214.248000, end 7417.576000
title : (33)02:00:14:248
Chapter #0.33: start 7417.576000, end 7747.614000
title : (34)02:03:37:576
Chapter #0.34: start 7747.614000, end 7947.314000
title : (35)02:09:07:614
Chapter #0.35: start 7947.314000, end 8122.781000
title : (36)02:12:27:314
Chapter #0.36: start 8122.781000, end 8398.681000
title : (37)02:15:22:781
Chapter #0.37: start 8398.681000, end 8666.658000
title : (38)02:19:58:681
Chapter #0.38: start 8666.658000, end 9131.200003
title : (39)02:24:26:658
Chapter #0.39: start 9133.207000, end 9131.200003
title : (40)02:32:13:207
Stream #0.0: Video: h264 (High), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 23.9
8 fps, 23.98 tbr, 48003.07 tbn, 47.95 tbc (default)
Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s (default)
Stream #0.2(eng): Audio: truehd, 48000 Hz, 5.1, s32
MediaInfo:
Unique ID : 237727046567496600442424672656872814136 (0xB2D89052697BF91BB72716141C61B638)
Complete name : E:\My Videos\MKV Blu Rays\The Dark Night.mkv
Format : Matroska
Format version : Version 2
File size : 18.8 GiB
Duration : 2h 32mn
Overall bit rate : 17.7 Mbps
Movie name : THE DARK KNIGHT.Title0.BlurayRip
Encoded date : UTC 2011-12-11 16:34:34
Writing application : DVDFab
Writing library : libebml v0.7.8 + libmatroska v0.8.1
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 32mn
Bit rate mode : Variable
Maximum bit rate : 35.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core
Default : Yes
Forced : No
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 2h 32mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 697 MiB (4%)
Language : English
Default : Yes
Forced : No
Audio #2
Format : TrueHD
Codec ID : A_TRUEHD
Duration : 2h 32mn
Maximum bit rate : 3 267 Kbps
Compression mode : Lossless
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:(01)00:00:00:000
00:06:23.966 : en:(02)00:06:23:966
00:10:36.260 : en:(03)00:10:36:260
00:13:52.581 : en:(04)00:13:52:581
00:17:54.198 : en:(05)00:17:54:198
00:21:39.339 : en:(06)00:21:39:339
00:26:10.026 : en:(07)00:26:10:026
00:29:36.274 : en:(08)00:29:36:274
00:31:42.483 : en:(09)00:31:42:483
00:37:49.058 : en:(10)00:37:49:058
00:43:34.069 : en:(11)00:43:34:069
00:46:39.546 : en:(12)00:46:39:546
00:48:57.768 : en:(13)00:48:57:768
00:53:19.446 : en:(14)00:53:19:446
00:57:15.640 : en:(15)00:57:15:640
00:59:26.354 : en:(16)00:59:26:354
01:03:59.627 : en:(17)01:03:59:627
01:08:23.557 : en:(18)01:08:23:557
01:10:48.327 : en:(19)01:10:48:327
01:14:24.918 : en:(20)01:14:24:918
01:18:05.639 : en:(21)01:18:05:639
01:22:22.437 : en:(22)01:22:22:437
01:24:48.583 : en:(23)01:24:48:583
01:30:48.443 : en:(24)01:30:48:443
01:34:04.972 : en:(25)01:34:04:972
01:39:57.783 : en:(26)01:39:57:783
01:42:05.494 : en:(27)01:42:05:494
01:44:59.918 : en:(28)01:44:59:918
01:47:00.872 : en:(29)01:47:00:872
01:51:09.913 : en:(30)01:51:09:913
01:54:14.639 : en:(31)01:54:14:639
01:57:04.017 : en:(32)01:57:04:017
02:00:14.248 : en:(33)02:00:14:248
02:03:37.576 : en:(34)02:03:37:576
02:09:07.614 : en:(35)02:09:07:614
02:12:27.314 : en:(36)02:12:27:314
02:15:22.781 : en:(37)02:15:22:781
02:19:58.681 : en:(38)02:19:58:681
02:24:26.658 : en:(39)02:24:26:658
02:32:13.207 : en:(40)02:32:13:207
Debug:
2011-12-15 16:39:32,336 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2011-12-15 16:39:32,352 INFO [MediaServer] ------------------------------------------------------------------------
2011-12-15 16:39:32,352 INFO [MediaServer] Serviio DLNA media streaming server v 0.6 (rev. a369baa35bfe)
2011-12-15 16:39:32,352 INFO [MediaServer] Petr Nejedly 2009-2011
2011-12-15 16:39:32,352 INFO [MediaServer] http://www.serviio.org
2011-12-15 16:39:32,352 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-12-15 16:39:32,352 INFO [MediaServer] OS Windows 7 amd64 6.1
2011-12-15 16:39:32,352 INFO [MediaServer] File encoding: windows-1252
2011-12-15 16:39:32,352 INFO [MediaServer] Headless mode enabled: true
2011-12-15 16:39:32,508 INFO [RestletServer] Starting Restlet server exposed on port 23423
2011-12-15 16:39:32,555 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-12-15 16:39:32,555 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2011-12-15 16:39:34,380 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2011-12-15 16:39:34,380 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2011-12-15 16:39:34,380 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2011-12-15 16:39:34,380 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2011-12-15 16:39:34,380 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2011-12-15 16:39:34,380 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2011-12-15 16:39:34,380 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2011-12-15 16:39:34,380 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2011-12-15 16:39:34,380 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2011-12-15 16:39:34,957 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-12-15 16:39:34,988 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2011-12-15 16:39:35,472 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-12-15 16:39:35,472 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2011-12-15 16:39:35,737 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-12-15 16:39:35,753 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2011-12-15 16:39:35,893 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-12-15 16:39:35,893 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2011-12-15 16:39:36,033 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-12-15 16:39:36,033 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2011-12-15 16:39:36,158 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-12-15 16:39:36,158 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2011-12-15 16:39:36,267 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-12-15 16:39:36,267 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2011-12-15 16:39:36,548 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-12-15 16:39:36,548 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2011-12-15 16:39:36,595 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2011-12-15 16:39:36,595 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2011-12-15 16:39:36,891 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-12-15 16:39:36,891 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2011-12-15 16:39:37,375 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-12-15 16:39:37,375 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2011-12-15 16:39:37,562 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-12-15 16:39:37,562 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2011-12-15 16:39:37,718 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2011-12-15 16:39:37,718 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2011-12-15 16:39:37,765 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2011-12-15 16:39:37,765 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2011-12-15 16:39:37,781 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2011-12-15 16:39:37,781 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2011-12-15 16:39:37,859 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2011-12-15 16:39:37,859 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2011-12-15 16:39:37,905 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2011-12-15 16:39:37,905 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2011-12-15 16:39:37,983 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2011-12-15 16:39:37,983 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 19
2011-12-15 16:39:38,249 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV 2011' (id=19)
2011-12-15 16:39:38,249 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2011-12-15 16:39:38,498 INFO [ProfilesDefinitionParser] Added profile 'Sony SMP-N100' (id=20)
2011-12-15 16:39:38,498 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-12-15 16:39:38,514 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize =
[4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-12-15 16:39:38,514 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-12-15 16:39:38,514 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-12-15 16:39:38,514 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100,
maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-15 16:39:38,514 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-12-15 16:39:38,514 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true,
MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1323967178514, LastAccessTime = 1323967178514, getTimeToLiveSeconds() = -1, createTime = 1323967178514 ]
2011-12-15 16:39:38,529 INFO [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
2011-12-15 16:39:38,529 INFO [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs =
1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-15 16:39:38,529 INFO [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
2011-12-15 16:39:38,529 INFO [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs =
2011-12-15 16:39:38,529 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-12-15 16:39:38,529 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-12-15 16:39:38,529 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs =
2011-12-15 16:39:38,529 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default
class.
2011-12-15 16:39:38,529 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-12-15 16:39:38,529 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true,
maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-15 16:39:38,529 INFO [CompositeCacheConfigurator] Parsed regions [thumbnails, online_feeds, local_default, local_resetafterplay]
2011-12-15 16:39:38,529 INFO [CompositeCacheConfigurator] Finished configuration in 15 ms.
2011-12-15 16:39:38,529 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2011-12-15 16:39:38,732 INFO [WebServer] Socket buffer set to 65535 bytes
2011-12-15 16:39:38,732 INFO [Device] Created UPnP Device with UUID: 5085bec6-9261-31b0-af2a-d6ac387fdc84, bound address: 192.168.1.7
2011-12-15 16:39:38,763 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files (x86)\Serviio\bin\..\plugins
2011-12-15 16:39:38,763 INFO [PluginCompilerThread] Started looking for plugins
2011-12-15 16:39:38,763 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe
2011-12-15 16:39:38,763 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe
2011-12-15 16:39:38,826 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-12-15 16:39:38,857 INFO [WebServer] WebServer starting on port 8895
2011-12-15 16:39:38,857 DEBUG [DiscoveryManager] UPNP device 5085bec6-9261-31b0-af2a-d6ac387fdc84 (192.168.1.7) is available
2011-12-15 16:39:38,857 INFO [RendererSearchSender] Searching for Renderer devices
2011-12-15 16:39:38,873 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-12-15 16:39:38,873 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-12-15 16:39:38,873 INFO [EventDispatcher] Starting EventDispatcher
2011-12-15 16:39:38,873 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-12-15 16:39:38,888 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC
(NDIS 6.20)) and address 192.168.1.7, timeout = 0
2011-12-15 16:39:39,100 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth3 (Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)) and
2011-12-15 16:39:39,100 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-12-15 16:39:39,115 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address
/192.168.1.7:49475
/192.168.1.7:49475
/192.168.1.7:49475
2011-12-15 16:39:39,162 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS
2011-12-15 16:39:39,162 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 5085bec6-9261-31b0-af2a-d6ac387fdc84
2011-12-15 16:39:39,817 DEBUG [WebServer] Incoming connection from /192.168.1.5:39446
2011-12-15 16:39:39,833 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.5:52235/dmr/SamsungMRDesc.xml, st: urn:schemas-upnp-
2011-12-15 16:39:39,833 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 25ff9f39-5eb7-2a93-9523-4c27e3e62738 from address /192.168.1.5:60196
2011-12-15 16:39:39,833 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 5085bec6-9261-31b0-af2a-d6ac387fdc84 from 192.168.1.5 (headers =
[HOST: 192.168.1.7:8895,USER-AGENT: SEC_HHP_[TV]PS51D8000/1.0,ACCEPT-LANGUAGE: en-us])
2011-12-15 16:39:39,833 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2011-12-15 16:39:39,849 DEBUG [RendererManager] Adding renderer Renderer [uuid=25ff9f39-5eb7-2a93-9523-4c27e3e62738, ipAddress=192.168.1.5, name=PS51D8000, profileId=7,
manuallyAdded=false] to list of active renderers
2011-12-15 16:39:39,849 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.7:8895,USER-AGENT: SEC_HHP_[TV]PS51D8000/1.0,ACCEPT-LANGUAGE:
en-us]
2011-12-15 16:39:39,849 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2011-12-15 16:39:39,927 DEBUG [WebServer] Incoming connection from /192.168.1.5:51675
2011-12-15 16:39:39,927 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 5085bec6-9261-31b0-af2a-d6ac387fdc84 from 192.168.1.5 (headers =
2011-12-15 16:39:39,927 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2011-12-15 16:39:39,927 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.7:8895,USER-AGENT: SEC_HHP_[TV]PS51D8000/1.0,ACCEPT-LANGUAGE:
en-us]
2011-12-15 16:39:39,989 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (C/D-series)'
2011-12-15 16:39:40,083 DEBUG [WebServer] Incoming connection from /192.168.1.5:36029
2011-12-15 16:39:40,083 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2011-12-15 16:39:40,831 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.5:52235/dmr/SamsungMRDesc.xml, st: urn:schemas-upnp-
2011-12-15 16:39:40,831 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 25ff9f39-5eb7-2a93-9523-4c27e3e62738 from address /192.168.1.5:60196
2011-12-15 16:39:41,128 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-12-15 16:39:41,830 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.5:52235/dmr/SamsungMRDesc.xml, st: urn:schemas-upnp-
2011-12-15 16:39:41,830 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 25ff9f39-5eb7-2a93-9523-4c27e3e62738 from address /192.168.1.5:60196
2011-12-15 16:39:45,121 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2011-12-15 16:39:51,315 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS
2011-12-15 16:39:51,315 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 5085bec6-9261-31b0-af2a-d6ac387fdc84
2011-12-15 16:39:53,280 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-12-15 16:40:03,467 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS
2011-12-15 16:40:03,467 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 5085bec6-9261-31b0-af2a-d6ac387fdc84
2011-12-15 16:40:05,136 INFO [FeedUpdaterThread] Started looking for information about online feeds
2011-12-15 16:40:05,136 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2011-12-15 16:40:05,136 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-12-15 16:40:05,152 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-12-15 16:40:05,152 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-12-15 16:40:05,199 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: E:\My Videos\MKV DVDs
2011-12-15 16:40:05,199 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\My Videos\MKV DVDs
2011-12-15 16:43:04,268 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Dark Night.mkv', checking if it's already in the Library
2011-12-15 16:43:04,268 DEBUG [MediaItemDAOImpl] Getting file of media item 10285
2011-12-15 16:43:04,268 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Dark Night.mkv
2011-12-15 16:43:04,268 DEBUG [MediaItemDAOImpl] Media item The Dark Night.mkv already exists in DB
2011-12-15 16:43:04,268 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10285) and extractor EMBEDDED
Post Thu Dec 15, 2011 5:21 pm
Re: Help: BD MKV True HD Codec Not Supported Problem on Sams
The TV - it won't play trueHD via DLNA. Serviio only sees the first (ac3) track, decides it doen't have to transcode and copies the file as-is to the TV.
Sammy51
Post Thu Dec 15, 2011 5:33 pm
Thanks for your very quick reply !
Ok, so basically this seems to be a DLNA limitation with my Samsung TV? Oh well...
DTS MA plays fine or I think it does but my AVR only shows DTS and not DTS HD. Is this because the TV does not support DTS MA via DLNA too and so it uses the core DTS instead ?
Is there no way to stream HD audio (DTS MA or DTS TrueHD) to my TV via DLNA?
Post Thu Dec 15, 2011 5:42 pm
I'd ask at the Samsung forum for what audio codecs they support.
Sammy51
Post Thu Dec 15, 2011 5:46 pm
OK thanks again. I guess this thread can be closed.
Post Fri Dec 16, 2011 3:54 pm
Re: [CLOSED] MKV True HD Codec Not Supported Problem on Sams
Just for future reference, the Samsung D series supports MP3, AC3, LCPM, ADPCM, DTS Core and AAC audio streams within MKV files.
Other audio streams used with avc video streams, including flac, vorbis and truehd are transcoded by the Serrviio C/D Profile to AC3.
Users browsing this forum: No registered users and 154 guests
