[OLD] Android Console
This thread documents the development work towards a version of the console for android. This first post will get updated with the most important info.
zip wrote:looking good, mate. A question: how do you link to the API URL? Do you do a UPnP search for Serviio and get the IP from there or is it a field in settings somewhere?
Xmantium wrote:This is brilliant!! I have few Android devices I can test this on, even running the latest Ice Cream Sandwich.
I was thinking the other day, zip provides easy api access that no ones come up with an iOS or Android app.
Any plans to make this an open source project?
Cerberus wrote:make it in a better colour and i would use itperect for a headless server and then control from an android tablet.
i can do sopme look and feel images if you require so once you get it work you can style it nicely to for table and high end adroid devicesgingerbread and up
Cerberus wrote:i cant program but i can do you a design drawing if you like ?
Xmantium wrote:Are you planning to release this as free app on Android Market when it's ready?
Would be cool if a windows phone 7 version is made as it looks like it's got metro style swipe interface.
Zip/Cerberus can you put this post on top of the section near the php/Ajax console, didn't know this post existed till today, so many sticky tools posts to skip to come to this post.
Cerberus wrote:1. it has to be free or it breachs serviio licence
will1987 wrote:Re WP7, again I don't have one so although I imagine they have emulators its not really the same and I have enough work/programing to do through my job and doctorate that I won't have the time for a while.
Re Market. Not sure yet, had a quick look. It costs $25 for an account even if you want to release free apps (to keep out the real crap entires).
kairoh wrote:If an android app is made, it will be in java ("android java"). WP7 or Iphone don't support java app.
There won't be any conversion possible, maybe someone will redevelop app for these phones.
Android market is absolutely free, you only require a free google account (not like App store ...).
You also can diffuse your app on any website (but this will not allow multiple version and search inside the market app).
will1987 wrote:Zip, did you see my earlier post re: making the 10 or so last added items aviablable via the API (filename + fetched metadata name)? I would really like to open up the app and view the last added files without having to turn on a device and browse the repository.
will1987 wrote:What I found said you have to pay. Got a link that says otherwise?
