Samsung TV-55C6500 and Serviio 6.0.1 not working
Romulus76
Post Thu Dec 15, 2011 10:28 pm
Hi all,
I'm trying to wath my media on mt Samsung 55" C6500 series in DNLA with Serviio 6.0.1 but without success, it seems my TV can't recognise the server.
I'm working on my notebook with Windows7, wired lan with cross-cable, no firewall activated and "Public network" setting. Serviio has all parameters just set correctly, and some folders contains media.
Ip was configured as:
- PC = 192.168.1.1, 255.255.255.0
- TV = 192.168.1.10, 255.255.255.0 (no gateway, no DNS)
When I open Serviio Console I can see the server recognise TV as "C series" (in the log file I can see profile 7), but on my TV nothing appears inside "AllShare" program... not devices founds.
Some ideas??
My Serviio log file
(12.65 KiB) Downloaded 734 times
Post Thu Dec 15, 2011 11:39 pm
Re: Samsung TV-55C6500 and Serviio 6.0.1 not working
This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console or pass system variable serviio.boundAddr including the IP address when starting the server.
Also make sure that TCP port 8895 and UDP 1900 are open in your firewall.
Romulus76
Post Fri Dec 16, 2011 2:15 pm
Thanks for the tips... I'll try this evening when come back home!! :mrgreen:
I'll give you a report of "bound" test...
Post Fri Dec 16, 2011 3:00 pm
Looks like according to the log there are 4 different renderers recognized using multiple names and Serviio gets confused and shuts down. Try starting with just the TV available and see what happens.
Post Fri Dec 16, 2011 8:48 pm
Romulus76 wrote:Thanks for the tips... I'll try this evening when come back home!! :mrgreen:
You might also want to set prefered ip address's for all of your devices (on your router) just to be on safe side but most of teh time this isnt required.
jhb50 wrote:Looks like according to the log there are 4 different renderers recognized using multiple names.
Thats normal and expected.
Romulus76
Post Sun Dec 18, 2011 7:46 pm
Thanks all, it works.... after enter bound IP.
Post Mon Dec 19, 2011 12:04 pm
Could you run this program and post the result back? It'll help me detect the IP better in fututre without entering buond address.
viewtopic.php?f=3&t=3923#p26629
Users browsing this forum: Baidu [Spider] and 23 guests
