I miss XBMC
SydneyGuy
Post Sat Nov 12, 2011 10:35 pm
I miss XBMC
I've just replaced an aging 60" RPTV and XBOX1/XBMC combination with a 64" Samsung plasma. It has made a huge difference to the picture quality but I had to retire the XBOX. I've got a couple of Apple TVs running XBMC on other TVs around the house but getting another seemed like a waste when the new TV had built-in streaming capabilities. I did some searching and came across Serviio (much better than Samsung's AllShare server software) and it is working very well but the UI on the TV leaves a lot to be desired, especially when compared to XBMC.
Should I just buy another Apple TV and install XMBC and be done with it or are there ways to improve the UI on the TV? I doubt I can do anything about the built-in software but perhaps there is better client software available? XBMC for the Samsung plasma would be the go but I know that doesn't exist :cry:
SydneyGuy
Post Sun Dec 18, 2011 3:07 am
Re: I miss XBMC
I know it is poor form to reply to your own post but I thought I should at least put in an update as to what I decided.
Another Apple TV won the race. While there is definitely nothing wrong with the Serviio software, I found that the client side software on my PS64D8000 was absolute rubbish. It was well worth spending another $100 on the Apple TV and run XBMC on it. Now if only there was a way to run XBMC on the TV itself so the additional box wasn't needed ....
kairoh
Post Sun Dec 18, 2011 9:44 am
Re: I miss XBMC
SydneyGuy wrote:Now if only there was a way to run XBMC on the TV itself so the additional box wasn't needed ....
XBMC requires too many CPU and disk space for a TV... TV just run a firmware and are not a complete computer.
It's like asking to play to Xbox directly on TV without the console!
Either you use the poor TV client UI, or you use an additional box / computer with richer (but useless) good looking UI.
Serviio WebUI console developer : New Homepage | Support | Project | Issues
Samsung UA32C6600 | WinXP / Ubuntu 11.10 | Samsung Galaxy S | Freebox v6
turnig56
Post Sun Dec 18, 2011 11:53 am
I miss XBMC
Apple TV + XBMC won't play 1080p,
right?
SydneyGuy
Post Mon Dec 19, 2011 8:23 pm
Re: I miss XBMC
turnig56 wrote:Apple TV + XBMC won't play 1080p,
right?
It will play it but it will only output it in 720p. It still looks very good on my 64" plasma.
turnig56
Post Tue Dec 20, 2011 6:41 pm
I miss XBMC
right?
