D7000 TV Doesn't found Servio
tweesty
Post Sun Dec 18, 2011 2:04 pm
Hi all!
First, sorry for my english which is bad....
I bought a D7000 and I install on my pc Servio"s server.
Into the console, i see the tv and its ip adress. But on my TV, it doesn't found my server.
Here a screenshot: http://imageshack.us/photo/my-images/808/79346316.png/
Thank you for listening.
Best regards.
PS: I switch off my firewall ;)
A French ;)
Post Sun Dec 18, 2011 2:15 pm
Re: D7000 TV Doesn't found Servio
Are you sure your serviio pc is at 1.11? Try leaving the bind address blank so the default is used.
tweesty
Post Sun Dec 18, 2011 3:03 pm
Yeah, i'm sure. It doesn't work too with ip default :(
Post Sun Dec 18, 2011 3:39 pm
OK, then you need to set the log to DEBUG and post it here so we can see what is happening.
tweesty
Post Sun Dec 18, 2011 4:01 pm
Here the log.
(62.54 KiB) Downloaded 707 times
Post Sun Dec 18, 2011 4:24 pm
Not sure what you have done.
You need to set the log to DEBUG for more info. Serach for how.
It looks like you did not setup any folders to add to the library, but then after a couple of hours you did and Serviio started to add them but you quit in the middle of that and then an hour later it looks like you added All-Share and then the log stops.
Have you read the install documentation? Click on the SERVIIO logo above and then the support tab. Might give you a clue.
tweesty
Post Sun Dec 18, 2011 8:37 pm
Hi!
When i am on allshare, i see my serviio
Post Sun Dec 18, 2011 8:45 pm
Not sure what that means but glad its working for you.
tweesty
Post Sun Dec 18, 2011 8:53 pm
I see it on allshare on my pc but i don't see it on my tv ;D
Post Sun Dec 18, 2011 9:55 pm
OK lets see the debug log, and the details of your pc and network.
I trust we are taking about the Samsung All-Share server.
If you don't see All-Share on the TV either then your problem is probably not with Serviio, but with your pc/network setup. Were there no clues in the faq?
tweesty
Post Mon Dec 19, 2011 11:37 am
Hi!
My tv sees AllShare without problem :(
tweesty
Post Mon Dec 19, 2011 12:52 pm
Hi!
I put servio on my linux, and my tv sees servio's server.
But when I launch a movie, TV prints "filetype not recognize". However with allshare, it works.
What is the problem?
PS: I disable "transcoding".
Post Mon Dec 19, 2011 2:15 pm
make sure the Samsung C/D series profile is selected in the console
Post Thu Dec 22, 2011 10:17 pm
tweesty wrote:Hi!
well if you disable transcoding it not gunna work ;)
Post Sat Dec 24, 2011 1:53 pm
Cerberus wrote:
tweesty wrote:Hi!
AllShare doesnt transcode so it should work without it
