Sony 2010 TV A/V Sync Issues
NX3
Post Sat Nov 26, 2011 11:39 am
In the last release full transcoding off mkv was switch off so they play as AVC. I posted about it and it did seem to work but extensive testing, the majority of the time the video and audio go out of sync. If you press stop and then restart sync is reattained but thats not that useful every 15-20 minutes (usual time period of sync issues). To confirm this is on a 2010 Sony Bravia 32EX503 and others reported this in the beta. I'm running wired giga ether and have plenty of bandwidth, the serviio PC is mostly idle and not getting bogged down. It appears to be a limitation of the set, imo. Also I've noticed when playing 1080p MKV as AVC the tv becomes very laggy and can't respond to commands from the remote. The only way to gain control is to turn the set off.
Given the other reports at the beta stage it would seem for the 2010 profile, it would be best to revert to full transcoding of mkv to avoid sync or tv lag issues.
NX3
Post Sun Dec 18, 2011 9:21 pm
Re: Sony 2010 TV Sync Issues
Ticket 485.
illco helped me edit the profile back to transcode mkv / avc and problem sorted. It seems to be a issue with the tv cpu not being able to keep up with the decoding.
Post Mon Dec 19, 2011 2:11 pm
I've commented on the ticket.
Miggo
Post Fri Dec 23, 2011 3:16 pm
I'm also experiencing this sync issue on my Sony NX710.
Is there a beta available where this issue is solved? or is there a workaround for the current serviio release?
Thanks!
BR
/Miggo
NX3
Post Sat Dec 24, 2011 9:50 am
I changed the Sony profile for 2010 so the files get transcoded to mpeg2 so you need a reasonable processor to do this but it stops a/v sync issues.
    <Profile id="9" name="Sony Bravia TV" extendsProfileId="1">
          <!-- All models *except* 2011 series which need a separate profile -->
          <Detection>
             <UPnPSearch>
                <!-- 2009 models known to support UPnPSearch, and all 2010 models -->
                <FriendlyName>BRAVIA KDL-\d{2}(WE5|(E53|E55|V55|V56|W55|W57|Z55|Z57)\d0|[EHLNPB]X\d[01]\d) *</FriendlyName>
             </UPnPSearch>
             <HttpHeaders>
                <!-- 2008 models, and possibly older or different region 2009 firmwares which may not support UPnPSearch -->
                <X-AV-Client-Info>.*BRAVIA KDL-\d{2}(([A-Z](1|5|E1|R1|BR45|BR9|[1357]0\d{2}|4\d{3}))|(S55|S57|W51|Z51|Z58)\d0) *</X-AV-Client-Info>
             </HttpHeaders>
          </Detection>
          <DeviceDescription>
             <!-- act as WMP so that the TV doesn't show root categories -->
             <ModelName>Windows Media Player Sharing</ModelName>
             <ModelNumber>3.0</ModelNumber>
             <Manufacturer>Microsoft Corporation</Manufacturer>
          </DeviceDescription>
          <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SonyDLNAMessageBuilder</ContentDirectoryMessageBuilder>
          <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.WMPContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
          <MediaFormatProfiles>
             <!-- rename native mpeg2ts with h264/ac3 ac3 formats to those supported by the tv -->
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AC3</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AC3</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
             <!-- rename transcoded mpeg2ts with h264 to one of the TV's supported profiles -->
             <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
             <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
             <!--<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile> -->
             <!--<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile> -->
          </MediaFormatProfiles>
             <!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems -->
             <Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true">
                <Matches container="asf" vCodec="mpeg2video" />
             <!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
             <!-- expected profile MPEG_TS_SD_EU/MPEG_TS_SD_NA/MPEG_TS_SD_KO -->
             <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384">
                <Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.1" />
                <Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.1" />
                <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.1" />
                <Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.1" />
                <Matches container="mp4" vCodec="h264" profile="high" levelGreaterThan="4.1" />
                <Matches container="mp4" vCodec="h264" profile="main" levelGreaterThan="4.1" />
             <!-- Remux h264 video with AC3 audio to MPEG-TS stream without transcoding -->
             <!-- expected profile AVC_TS_MP_HD_AC3_ISO -->
                <Matches container="avi" vCodec="h264" aCodec="ac3" />
                <Matches container="mp4" vCodec="h264" aCodec="ac3" />
                <!-- <Matches container="matroska" vCodec="h264" aCodec="ac3" />  -->
             <!-- Remux all other h264 video to MPEG-TS stream with ac3 audio transcoding -->
                <!-- <Matches container="matroska" vCodec="h264" /> -->
                <!-- if audio different to ac3, must be transcoded -->
                <Matches container="mpegts" aCodec="aac" />
                <Matches container="mpegts" aCodec="mp3" />
                <Matches container="mpegts" aCodec="dca" />
                <Matches container="mpegts" aCodec="lpcm" />
                <Matches container="mpeg" aCodec="dca" />
                <Matches container="ogg" vCodec="mpeg4" />
             <!-- All Others video/audio codec will be transcoded into mpeg2ts, mpeg2video and ac3 audio -->
             <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="192">
                <Matches container="asf" />
                <Matches container="avi" />
                <Matches container="mp4" />
                <Matches container="flv" />
                <Matches container="wtv" />
                <Matches container="ogg" />
                <!-- To allow "pause" then "resume" functions and album art for TVs that support it - transcode to mp3 instead -->
                <Matches container="flac" />
             </Audio>
Users browsing this forum: Baidu [Spider] and 19 guests
