Panasonic Viera and Serviio
cynalan
Post Mon Dec 19, 2011 10:18 pm
Re: Problem Knowing How to Get Serviio to Recognize Files
Marinerguy wrote:My TV does recognize that it is on my computer and lists various generic folders, e.g. Videos. However, when I click on those folders, nothing is there - no videos, no music, no photographs. I looked for a spot on the Serviio Console for a place where I could indicate which videos, photos, and music files I wanted uploaded (right word?) so that I could access them from the TV.
I'm a newbie as well. I had this problem too. The simple fix is to ensure that you've identified the file paths to your media collection. Don't forget to "save" them after identifying the paths and media types.
Now if I could only figure out how to play AVI files on my Viera 65".
Post Mon Dec 19, 2011 10:31 pm
Re: Panasonic Viera and Serviio
It looks like there are 2 series of Viera TVs, one that can play AVI/DivX natively, the other cannot. So maybe we need 2 profiles? Anyone knows what are the models that support it and that don't? We would need automatic detection settings as well.
Post Tue Dec 20, 2011 1:05 pm
zip wrote: So maybe we need 2 profiles?
Yes, I confirm according to GetProtocolInfo result :http://wiki.serviio.org/doku.php?id=devices_format_support#panasonic
zip wrote: Anyone knows what are the models that support it and that don't? We would need automatic detection settings as well.
No but with devices that supports GetProtocolInfo sink result, we could add them, for other, users have to do some testing.
Post Tue Dec 20, 2011 1:40 pm
cool. Do you know where to find info of what needs to be done? Anyone can have a shot at this?
Post Tue Dec 20, 2011 2:19 pm
zip wrote:Do you know where to find info of what needs to be done?
I don't know where to find a Panasonic GetProtocolInfo database.
- only serviio wiki and UpnpDatabase, but nothing about panasonic devices
zip wrote:Anyone can have a shot at this?
Need Panasonic users volunteers.
BDM
Post Tue Dec 27, 2011 12:32 pm
Hi ZIP & IlliCO,
I'm a newbie but more than willing to be a volenteer for Viera (TX - P 54 Z1) tweaking and set-up testing! :geek:
Need some good setup myself ;)
Cheers!
Panasonic Viera TX-P54Z1 (2.403) WIRED - Profile: "Toshiba REGZA" | Play Station 3 (4.0) WIRELESS - Profile: "Playstation 3" | OSX LION (10.7.2) | Serviio (0.6.1)
jesenriq
Post Tue Dec 27, 2011 3:09 pm
I'm able to test it as well, with a VIERA TC-L32X30, which the native software does not play AVis
Please let me know what are the next steps for the experiments.
Regards
voodooo
Post Tue Jan 10, 2012 4:15 pm
Hi All.
Thank you for developing this simple and powerful piece of software. I have a Panasonic TX-L42E30(E) and if you need me to run some tests, please ask.
I can successfully play 1080p / 720p .MKV files through DLNA but no SRT available.. To view SRT i have to remux it in MKV file and then, everything plays OK.
I've tested .AVI without SRT and it's ok, will now test with SRT.
EDIT: All these tests were made without transcoding.
So if you need something in order to create a new profile for Panasonic 2011 viera, please buy. :mrgreen:
voodooo
Post Wed Jan 11, 2012 1:24 pm
UPDATE:
All my tests were made with transcoding disabled.
- MKV 1080/720p playing nice. In order to get subtitles e have to remux the MKV files and add the SRT. (works with mkvtoolnix v3.4.0).
- AVI playing nice with external SRT.
- Attached protocol info of my Viera TX-L42E30E, hope it helps.
Panasonic.TX-L42E30E.dlna.zip
Panasonic.TX-L42E30E.protocol.info.dlna
(633 Bytes) Downloaded 1158 times
PMI
Post Thu Jan 12, 2012 1:27 am
voodooo wrote:UPDATE:
- MKV 1080/720p playing nice...
@voodoo: can you post what kind of MKV pls?
My Viera E-series (e-series being TCL32E3 in my case) can play MKV files encoded w. H264 video, and AC3 audio, ONLY). MKV files produced by programs like MakeMKV are encoded w. mpeg2video, and have to be transcoded to play. Unfortunately so far, the profile I am using seems to work only with some them. If you could post what kind of MKVs you are using/playing it might help (thanks).
And, for completeness, I can play (without transcoding):
MKVs encoded w. H264/AC3 (tested). H264/PCM should play, but I have NOT tested it
MP4 encoded w. H264/AC3 (tested). H264/LPCM should play, NOT tested
AVIs, transcoded to Mpeg2-TS (tested)
AAC audio, transcoded to AC3 (tested)
WTV files (from Windows Media Center), transcoded to Mpeg2-PS and AC3 (tested)
Peter
voodooo
Post Thu Jan 12, 2012 12:02 pm
I've testes about 15 mkv files with MKV1 format below, and 3 with MKV2 format below:
MKV1: V_MPEG4/ISO/AVC
A_DTS
Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1080, SAR 1:1 DAR 16:9, 23.98 fps, 48 tbr, 1k tbn, 47.95 tbc
Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), s16, 1536 kb/s
Stream #0:2: Subtitle: text (default)
MKV2: V_MPEG4/ISO/AVC
A_AC3
Stream #0:0(fre): Video: h264 (High), yuv420p, 1280x544 [SAR 1:1 DAR 40:17], 23.98 fps, 48 tbr, 1k tbn, 47.95 tbc (forced)
Stream #0:1(por): Audio: ac3, 48000 Hz, 5.1(side), s16, 384 kb/s
- Transcoding disabled.
Regards.
voodooo
Post Fri Jan 20, 2012 6:45 pm
Hello.
This specific mkv dont play well on my TV (, the image freezes for 2 secs, then play 2 secs, then freezes again and so on.. (audio is good).
On VLC plays nice. Can anyone point something here ?
MediaInfo:
Unique ID                        : 230562314025190346082625892124840813854 (0xAD74AFBC0738796D85EE34837121E51E)
Complete name                    : C:\xxxx\The.Double.720p.BluRay.x264.DTS.mkv
Format                           : Matroska
Format version                   : Version 2
File size                        : 4.37 GiB
Duration                         : 1h 38mn
Overall bit rate                 : 6 362 Kbps
Encoded date                     : UTC 2012-01-14 12:53:44
Writing application              : mkvmerge v4.9.1 ('Ich will') 编译于 Jul 11 2011 23:53:15
Writing library                  : libebml v1.2.1 + libmatroska v1.1.1
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 11 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 1h 38mn
Bit rate                         : 4 851 Kbps
Width                            : 1 280 pixels
Height                           : 546 pixels
Display aspect ratio             : 2.35:1
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.290
Stream size                      : 3.25 GiB (74%)
Writing library                  : x264 core 116 r2074 2641b9e
Encoding settings                : cabac=1 / ref=11 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=4851 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / nal_hrd=none / ip_ratio=1.50 / aq=1:1.00
Language                         : English
Default                          : Yes
Forced                           : No
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 1h 38mn
Bit rate                         : 1 510 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 1.04 GiB (24%)
Default                          : Yes
Forced                           : No
PMI
Post Sat Jan 21, 2012 1:39 am
I have some of that too. The file plays for a second, then stops, then plays for another second, and stops again. Basically starts, stops, and continues like that. Plays fine on my PC.
The CPU usage is fairly low, transcoding is turned off in Serviio, and the video is compatible with the Viera E-series.
From MediaInfo:
Unique ID : 177332162903787086350096717352672065482 (0x8568EEA8D96BE497698FB4A3E91A77CA)
Complete name : I:\Test_Video\Montserrat2_8_480AC3.mkv
Format : Matroska
File size : 200 MiB
Duration : 15mn 1s
Overall bit rate : 1 863 Kbps
Writing application : Lavf52.32.0
Writing library : Lavf52.32.0
Format : AVC
Format profile : Baseline@L3.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=12
Duration : 15mn 1s
Bit rate : 1 506 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 30.000 fps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.145
Stream size : 162 MiB (81%)
Language : English / English
Default : Yes
Forced : No
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 15mn 1s
Bit rate : 320 Kbps
Bit depth : 16 bits
Stream size : 34.4 MiB (17%)
Default : Yes
Forced : No
Peter
Post Sat Jan 21, 2012 8:20 am
test with 0.6.2 when it releases and i suspect these files will then play.
voodooo
Post Sat Jan 21, 2012 12:15 pm
Cerberus wrote:test with 0.6.2 when it releases and i suspect these files will then play.
Any prediction on when it will be released ?
Post Sat Jan 21, 2012 1:41 pm
when its past testing with beta team.
voodooo
Post Sat Jan 21, 2012 8:44 pm
Any chance on testing it to ? 8-)
Post Sun Jan 22, 2012 8:12 am
we are so close to release, more tester are not needed by if you still want to test for future release im sure zip can add you to tester team then :) although ZIP has final say on this as its his project.
rendalf
Post Fri Feb 17, 2012 6:52 am
So the only way, how to play MKV with subtitles via Serviio on Viera TVs is to mutex subtitles into mkv and disable transcoding? Thanks for reply.
Post Fri Feb 17, 2012 9:39 am
rendalf wrote:So the only way, how to play MKV with subtitles via Serviio on Viera TVs is to mutex subtitles into mkv and disable transcoding? Thanks for reply.
no that's. not what I said
Return to Panasonic
