Panasonic Viera and Serviio
Intel UPNP Tools 'Device Spy' does not show the TV - my wife's PC which is similarly connected by homeplugs through the router shows up. This means I cannot get the TV data that you may want. Any ideas?
trampas wrote:Any thoughts on how I go about getting the info to set up a profile for this TV - or is the generic one okay?
trampas wrote:It seems if the TV is off when Serviio advertises itself (every 15 minutes?) then Serviio is not picked up - stop/start of the service makes it work - which makes sense.
zip wrote:trampas wrote:It seems if the TV is off when Serviio advertises itself (every 15 minutes?) then Serviio is not picked up - stop/start of the service makes it work - which makes sense.
The TV should send search request on its start, so it should still work.
zip wrote:Yes, you'll have to select the profile you want and not autodetect in this case. I'm changing profile management right now for the next version so this should hopefully go away.
<item id="V_F#FOL_R4$F6$MI16" parentID="V_F#FOL_R4$F6" restricted="1">
<dc:title>1x02</dc:title>
<upnp:class>object.item.videoItem</upnp:class>
<dc:date>2006-09-10</dc:date>
<res duration="0:23:01.000"
protocolInfo="http-get:*:video/divx:DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000"
resolution="640x352" size="183433216">http://192.168.200.40:8895/resource/16/MEDIA_ITEM/AVI</res>
<res protocolInfo="http-get:*:text/srt:*">http://192.168.200.40:8895/resource/16/SUBTITLE.srt</res>
</item>
