OpenIndiana
DetlefSc
Post Tue Dec 20, 2011 10:50 pm
OpenIndiana
Hi all,
I installed Serviio 0.6.0.1 on my nas running under oi151 with zfs and activated mb server.
Serviio seems to run fine, I can see the server on my Sony-TV, my Win7-PC and my WDTV Live. But.....as soon as I go to my video folder , i get the message, that there are no files in the folder... but there some and i can watch them using smb.
Any idea, where my fault could be ???
BR
Detlef
WildRushSykes
Post Tue Dec 20, 2011 11:06 pm
Re: OpenIndiana
Have you added files to your library? Also have you got a compiled ffmpeg build?
DetlefSc
Post Tue Dec 20, 2011 11:19 pm
Re: OpenIndiana
yep, i added /data/movies to my lib and i can go there.
The ffmpeg i am using is from sfe-encumbered with version 0.8.5 (build 5.11-0.151.1)
WildRushSykes
Post Wed Dec 21, 2011 12:40 am
Re: OpenIndiana
Could you attatch a detailed log
Ill try and get someone else to help on this that knows nas as i use windows exclusively :D
patters
Post Wed Dec 21, 2011 10:22 am
Re: OpenIndiana
Does the user account that Serviio is running as have read access to the files/folders containing the media?
Failing that you'll need to check the Serviio log at log/serviio.log.
DetlefSc
Post Wed Dec 21, 2011 4:05 pm
Re: OpenIndiana
Hi Patters,
in the moment, i am testing as root. I verified with vlc, whether i have access and the file is readable and not corrupted. It works fine.
WildRushSykes asked for logfiles... I browsed thru the log and saw, that ffmpeg tries to read my video file, to place it in a libraray. (ffmpeg -i /data/movies/test1.avi). I used the same command in a command shell and got some errors.
ffmpeg was installed with package manager from sfe-encumbered.
first error was a missing lib called libass.so.4. I found this lib in the repos. It was not installed, so i did it. Now i am stucking with the next error:
**** start copy&paste
DetlefSc@Compi:~$ ffmpeg -i /data/movies/test1.ts ld.so.1: ffmpeg: fatal: libopenal.so.1: open failed: No such file or directory
ld.so.1: ffmpeg: fatal: relocation error: file /usr/lib/libavdevice.so.53: symbol alcCaptureStop: referenced symbol not found
ld.so.1: ffmpeg: fatal: relocation error: file /usr/bin/ffmpeg: symbol avdevice_register_all: referenced symbol not found
Killed
**** end copy&paste ****
Now I am lost.. Here in the forum, I saw some messages that serviio is running with openeindiana... my big question for today : what must i do ??
regards from cold Switzerland
Detlef
patters
Post Thu Dec 22, 2011 8:47 pm
Re: OpenIndiana
Looks like your FFmpeg is the problem. Serviio runs ffmpeg -i on each file to get its attributes to add it to the library. Until you can run ffmpeg without it crashing like that, you won't be able to use Serviio.
Is it asking for another library, libopenal?
Post Thu Dec 22, 2011 10:45 pm
Re: OpenIndiana
patters wrote:Looks like your FFmpeg is the problem. Serviio runs ffmpeg -i on each file to get its attributes to add it to the library. Until you can run ffmpeg without it crashing like that, you won't be able to use Serviio.
look to me like ffmpeg is not compiled with correct libs, so will need to be reinstalled/compiled.
http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux
