[D5700] DLNA via LAN is OK but via WLAN is not
maniootek
Post Thu Dec 22, 2011 8:02 pm
I would like to ask what could be wrong when my DLNA Serviio server works good when my laptop is wired connected to my Wireless Router but when I connect to this Router via wireless connection it doesn't working (my TV could not see it). My Laptop WIFI Interface IP address is 192.168.0.88 and LAN Interface IP address is 192.168.0.100. My router address is 192.168.0.1 and TV LAN Interface IP address is 192.168.0.82. Any idea?
Added:
I just installed Serviio on another laptop and via Wireless everything working good. I don't know what is wrong with my laptop.
(19.59 KiB) Downloaded 712 times
YTMY
Post Thu Dec 22, 2011 8:20 pm
Re: [D5700] DLNA via LAN is OK but via WLAN is not
Serviio bounds to first available ip on startup (if not bounded specifically). If You switch from LAN to WLAN and want for server to appear without computer restart You have to restart the serviio server. If LAN is disconnected it will bound to WLAN. Or You can enter Your WLAN IP in serviio console (bound IP adress), this way it will only work on WLAN. It cannot work for both interfaces at the same time. ;)
Also I noticed that 192.168.0.88 is for Your LAN:
2011-12-22 19:50:08,144 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Marvell Yukon 88E8059 Family PCI-E Gigabit Ethernet Controller) and address 192.168.0.88, timeout = 0
If You try to bound to 192.168.0.88 then it is not WLAN in Your case.
| Samsung UE32C6500 LED | Windows 7 x64 | 5Ghz wi-fi N 300Mbps setup |
Post Thu Dec 22, 2011 10:38 pm
if you want it to work on the wireless interface then bind serviio in console to : 192.168.0.88
if you want it to work on the wired interface then bind serviio in console to : 192.168.0.100
it will either work on one or the other not both.
maniootek
Post Fri Dec 23, 2011 2:01 pm
Thank you for reply, but it still doesn't working.
Edited: Sorry, my fault. Everything is fine now, thank you guys !
Post Fri Dec 23, 2011 4:57 pm
I was able to work out a way to seamlessly switch my laptop between wired and wireless, without any restart of Serviio, Windows or my router. One click does it all. See http://wiki.serviio.org/doku.php?id=how_to_switch_a_laptop_seamlessly_from_wireless_to_wired_and_back_again
Post Fri Dec 23, 2011 5:10 pm
jhb50 wrote:I was able to work out a way to seamlessly switch my laptop between wired and wireless, without any restart of Serviio, Windows or my router. One click does it all. See http://wiki.serviio.org/doku.php?id=how_to_switch_a_laptop_seamlessly_from_wireless_to_wired_and_back_again
yer it easy its call bridged connections, none of that messing about but average user wouldnt understand this.
Post Fri Dec 23, 2011 5:35 pm
True, I dont understand it either but I think there is enough there that anyone with average intelligence can make it work too. Feel free to add anything that would facilitate that.
Post Fri Dec 23, 2011 5:38 pm
jhb50 wrote:True, I dont understand it either but I think there is enough there that anyone with average intelligence can make it work too. Feel free to add anything that would facilitate that.
will do :)
Post Fri Dec 23, 2011 5:41 pm
Be real nice if you can fix the DNS problem too..I've posted on the web but none of the suggestions have fixed the problem. Its easy to restart my router but it would be nice to not have to.
Post Fri Dec 23, 2011 8:34 pm
jhb50 wrote:Be real nice if you can fix the DNS problem too..I've posted on the web but none of the suggestions have fixed the problem. Its easy to restart my router but it would be nice to not have to.
drop me a pm with the exact details and will have a look when i get a moment, but might have to wait till im at home to do.
Users browsing this forum: Google [Bot] and 15 guests
