strange address 192.168.3.107 in a log file
jOkEr
Post Thu Dec 22, 2011 7:35 pm
while trying to fix a trouble with no video content found (see Samsung D6000 No Devices Found in Allshare) I have found a strange message in a serviio.log file rom a stange IP:
serviio.log.2:2011-12-22 19:13:11,145 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.3.107:4747
serviio.log.2:2011-12-22 19:13:11,146 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.3.107:4747
serviio.log.2:2011-12-22 19:13:11,147 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.3.107:4747
netstat -a on the same device can't find anything from 192.168.3.0/24 network - all my devices on the 192.168.0.0/24
the router also do not know any 192.168.3.0 device (checked with "show arp -a")
what device this IP belongs to?
Post Thu Dec 22, 2011 10:33 pm
Re: strange address 192.168.3.107 in a log file
please provide a IPconfig output for your server.
jOkEr
Post Fri Dec 23, 2011 7:04 am
Linux version 2.6.32.12 (root@build2) (gcc version 4.2.1) #1955 Sat Nov 26 14:50
:54 CST 2011
> ifconfig
eth0 Link encap:Ethernet HWaddr 00:11:32:0A:1E:C8
inet addr:192.168.0.2 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::211:32ff:fe0a:1ec8/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:3228932 errors:0 dropped:0 overruns:0 frame:0
TX packets:6036107 errors:0 dropped:1 overruns:0 carrier:0
collisions:0 txqueuelen:532
RX bytes:497127515 (474.0 MiB) TX bytes:1546853594 (1.4 GiB)
Interrupt:11
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:256177 errors:0 dropped:0 overruns:0 frame:0
TX packets:256177 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:67999938 (64.8 MiB) TX bytes:67999938 (64.8 MiB)
> route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.0.0 * 255.255.255.0 U 0 0 0 eth0
default 192.168.0.1 0.0.0.0 UG 0 0 0 eth0
> netstat -a
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:49152 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:9091 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:21926 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:mysql 0.0.0.0:* LISTEN
tcp 0 0 Synology:44331 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:ssh 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:ipp 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:postgres 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:8895 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:23423 0.0.0.0:* LISTEN
tcp 0 0 Synology:ssh 192.168.0.1:60930 ESTABLISHED
tcp 0 0 Synology:ssh 192.168.0.12:52804 ESTABLISHED
tcp 0 0 Synology:8895 192.168.0.12:53886 ESTABLISHED
tcp 0 0 ::%2:printer ::%3200899292:* LISTEN
tcp 0 0 ::%3:21926 ::%3200899292:* LISTEN
tcp 0 0 ::%4:5000 ::%3200899292:* LISTEN
tcp 0 0 ::%5:3240 ::%3200899292:* LISTEN
tcp 0 0 ::%6:5001 ::%3200899292:* LISTEN
tcp 0 0 ::%7:netbios-ssn ::%3200899292:* LISTEN
tcp 0 0 ::%8:http ::%3200899292:* LISTEN
tcp 0 0 ::%9:ssh ::%3200899292:* LISTEN
tcp 0 0 ::%10:ipp ::%3200899292:* LISTEN
tcp 0 0 ::%11:postgres ::%3200899292:* LISTEN
tcp 0 0 ::%12:https ::%3200899292:* LISTEN
tcp 0 0 ::%13:microsoft-ds ::%3200899292:* LISTEN
tcp 0 0 Synology:microsoft-ds ::ffff:192.168.0.98%3200899292:48142 ESTABLISHED
udp 0 0 0.0.0.0:syslog 0.0.0.0:*
udp 0 0 Synology:netbios-ns 0.0.0.0:*
udp 0 0 0.0.0.0:netbios-ns 0.0.0.0:*
udp 0 0 Synology:netbios-dgm 0.0.0.0:*
udp 0 0 0.0.0.0:netbios-dgm 0.0.0.0:*
udp 0 0 0.0.0.0:9997 0.0.0.0:*
udp 0 0 0.0.0.0:9998 0.0.0.0:*
udp 0 0 0.0.0.0:9999 0.0.0.0:*
udp 0 0 0.0.0.0:55572 0.0.0.0:*
udp 0 0 0.0.0.0:21926 0.0.0.0:*
udp 0 0 localhost:57402 0.0.0.0:*
udp 0 0 Synology:55900 0.0.0.0:*
udp 0 0 0.0.0.0:5353 0.0.0.0:*
udp 1840 0 0.0.0.0:1900 0.0.0.0:*
udp 0 0 0.0.0.0:1900 0.0.0.0:*
udp 0 0 Synology:41328 192.168.0.1:5351 ESTABLISHED
udp 0 0 239.192.152.143:6771 0.0.0.0:*
in /proc/arp no 192.168.3.0/24 addresses
Post Fri Dec 23, 2011 7:08 am
ah ok your running on linux NAS so this is one for Patters.
mods: can we move this to Nas section please.
Post Sat Dec 24, 2011 1:55 pm
might be a virtual interface?
