Sony Bravia 2011 - Another video not available
soundcheck
Post Thu Dec 22, 2011 12:46 pm
Hi folks.
I just tried to play a new movie on my Bravia HX 925 ( 2011) profile.
The m2ts file is not shown in the STREAM folder by the TV.
Other movies are accessable.
It works on the Sony BluRay player though.
The debug log looked OK to me.
Here is the ffmpeg output:
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-mingw32- --pkg-config=pkg-config
Input #0, mpegts, from 'D:\video\YYYY\BDMV\STREAM\00000.m2ts':
  Duration: 02:00:00.00, start: 4198.000000, bitrate: 25852 kb/s
  Program 1
    Stream #0.0[0x1011]: Video: vc1 (Advanced), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbc
    Stream #0.1[0x1100]: Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
Might be a profile issue !?!? VC-1 Advanced Profile 3 ( that's what media-info says) is that covered in the Bravia 2011 profile?
Any help is appreciated.
Cheers
Post Thu Dec 22, 2011 1:17 pm
Re: Sony Bravia 2011 - Another video not available
MOving to Sony forum
Post Fri Dec 23, 2011 4:33 pm
soundcheck wrote:Input #0, mpegts, from 'D:\video\YYYY\BDMV\STREAM\00000.m2ts':
Program 1
[/code]
Not covered in the Bravia profiles, this format is supported in natvie format with Sony BDP.
Could you insert this in the second <video> ...</video> element section of the Sony Bravia 2011 definition:
<Matches container="mpegts" vCodec="vc1" />
soundcheck
Post Sat Dec 24, 2011 8:12 am
Could you please describe where to put it t exactly!?!? There are several target format definitions in the 2011 profile.
What do I have to do after editing the file to activate the change and to refresh (reinitialise?) the database.
Sorry for my ignorance. I'm pretty new to all of this.
Cheers
soundcheck
Post Sat Dec 24, 2011 8:50 am
I got another video which doesn't show up:
Mediainfo:
1920*1080, 23.976 fps, AVC(NTSC)(High@L4.1)(Cabac/4 Ref Frames)
First Audio stream:
Unknown/640kpbs, 48khz, 16, 6, AC-3 (stream extension) (True-HD/Core)
Database parsing doesn't seem to cause errors.
Audio issue? AC-3 True HD ???
Any hints are welcome.
Thx
Post Sat Dec 24, 2011 9:36 am
soundcheck wrote:I got another video which doesn't show up:
Please, could you provide complete MediaInfo result (in text format)?
That could be due to header compression used...
Post Sat Dec 24, 2011 9:39 am
soundcheck wrote:Could you please describe where to put it t exactly!?!? There are several target format definitions in the 2011 profile.
- Open profiles.xml
- Find the section starting with <Profile id="19" name="Sony Bravia TV 2011" extendsProfileId="9">
- Edit the video section like this:
         <!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
         <!-- expected profile MPEG_TS_SD_EU/MPEG_TS_SD_NA/MPEG_TS_SD_KO -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384">
            <Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.1" />
            <Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.1" />
            <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.1" />
            <Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.1" />
            <Matches container="mp4" vCodec="h264" profile="high" levelGreaterThan="4.1" />
            <Matches container="mp4" vCodec="h264" profile="main" levelGreaterThan="4.1" />
soundcheck
Post Sat Dec 24, 2011 10:22 am
Here we go.
<Mediainfo version="0.7.51">
<File>
<track type="General">
<ID_String>0 (0x0)</ID_String>
<CompleteName>F:\video\TEST\BDMV\STREAM\00000.m2ts</CompleteName>
<Format>BDAV</Format>
<Format_Info>Blu-ray Video</Format_Info>
<FileSize_String>24.5 GiB</FileSize_String>
<Duration_String>2h 2mn</Duration_String>
<OverallBitRate_Mode_String>Variable</OverallBitRate_Mode_String>
<OverallBitRate_String>28.6 Mbps</OverallBitRate_String>
<OverallBitRate_Maximum_String>48.0 Mbps</OverallBitRate_Maximum_String>
</track>
<track type="Video">
<ID_String>4113 (0x1011)</ID_String>
<MenuID_String>1 (0x1)</MenuID_String>
<Format>AVC</Format>
<Format_Info>Advanced Video Codec</Format_Info>
<Format_Profile>High@L4.1</Format_Profile>
<Format_Settings_CABAC_String>Yes</Format_Settings_CABAC_String>
<Format_Settings_RefFrames_String>4 frames</Format_Settings_RefFrames_String>
<CodecID>27</CodecID>
<BitRate_Mode_String>Variable</BitRate_Mode_String>
<BitRate_Maximum_String>35.0 Mbps</BitRate_Maximum_String>
<Width_String>1 920 pixels</Width_String>
<Height_String>1 080 pixels</Height_String>
<DisplayAspectRatio_String>16:9</DisplayAspectRatio_String>
<FrameRate_String>23.976 fps</FrameRate_String>
<Standard>NTSC</Standard>
<ColorSpace>YUV</ColorSpace>
<ChromaSubsampling>4:2:0</ChromaSubsampling>
<BitDepth_String>8 bits</BitDepth_String>
<ScanType_String>Progressive</ScanType_String>
<Color_primaries>BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177</Color_primaries>
<Transfer_characteristics>BT.709-5, BT.1361</Transfer_characteristics>
<Matrix_coefficients>BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177</Matrix_coefficients>
</track>
<track type="Audio">
<ID_String>4352 (0x1100)</ID_String>
<Format>AC-3</Format>
<Format_Info>Audio Coding 3</Format_Info>
<Format_Profile>TrueHD / Core</Format_Profile>
<Format_Settings_ModeExtension>CM (complete main)</Format_Settings_ModeExtension>
<MuxingMode>Stream extension</MuxingMode>
<CodecID>131</CodecID>
<BitRate_Mode_String>Variable / Constant</BitRate_Mode_String>
<BitRate_String>Unknown / 640 Kbps</BitRate_String>
<BitRate_Maximum_String>2 970 Kbps / 640 Kbps</BitRate_Maximum_String>
<Channel_s__String>6 channels</Channel_s__String>
<ChannelPositions>Front: L C R, Side: L R, LFE</ChannelPositions>
<SamplingRate_String>48.0 KHz</SamplingRate_String>
<BitDepth_String>16 bits</BitDepth_String>
<Compression_Mode_String>Lossless / Lossy</Compression_Mode_String>
</track>
</File>
</Mediainfo>
soundcheck
Post Sat Dec 24, 2011 10:28 am
- Open profiles.xml
Done that. And restarted the server. No change.
Do I have to remove the database to do a new scan? (I've removed and reinstalled Serviio 20 times at least -- that's more than annoying - I really would like to see a function "reinitialize database)
soundcheck
Post Sat Dec 24, 2011 10:46 am
Hmmh, just read that:
AC-3 TrueHd is a DRMed format. Correct!?!?
patters
Post Sat Dec 24, 2011 11:49 am
soundcheck wrote:Do I have to remove the database to do a new scan? (I've removed and reinstalled Serviio 20 times at least -- that's more than annoying - I really would like to see a function "reinitialize database)
When you edit the profile, you only need to stop and restart the Serviio service. The database doesn't take the device profile into account so there's no need to keep wiping that.
soundcheck
Post Sat Dec 24, 2011 12:05 pm
THX. I didn't know if the transcode strategy/parameters gets assigned on a per video basis to each record during the initial scan. I'd assumed that without wiping the db a mismatch of
database and profile would exist. Obviously that's not the case. Thx again.
soundcheck
Post Mon Dec 26, 2011 4:55 pm
I tried the VC-1 thing. It didn't work. "No file avaliable" it says on the Sony side.
Post Mon Dec 26, 2011 5:03 pm
soundcheck wrote:AC-3 TrueHd is a DRMed format. Correct!?!?
not DRMed.
But finally, the audio track will be transcode to AC3.
Could you enable detailed logging (see signature link) and check for that file ?
