AVC problem
pain666
Post Wed Dec 21, 2011 5:17 am
AVC problem
Hi Guys,
I have this AVC movie, which was playing on my Sony Bravia through TVMobili just fine. But then I have decided to update TVMobili and the file could not be played anymore, the TV says it's 0h 0m length. After trying this and that I've removed TVMobili and decided to Switch to Servio.
The file is visible, the length is stated correctly, but the TV says movie cannot be played. Please advise, should I stay away from AVC?
Post Wed Dec 21, 2011 7:54 am
Re: AVC problem
can you post the informartion about the video, see signature on how.
Also can you post your renderers and the profiles that are selected in the serviio console for them.
pain666
Post Sat Dec 24, 2011 5:34 pm
Re: AVI problem
Sorry for misinformation, it is actually XVID with AC3 sound:
Input #0, avi, from '/Users/pain/Desktop/Movies/Chugyeogja.avi':
encoder : AVI-Mux GUI 1.17.8, Aug 30 2008 12:36:58
JUNK :
Duration: 01:59:56.52, start: 0.000000, bitrate: 1801 kb/s
Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 720x304 [SAR 1:1 DAR 45:19], 25 tbr, 25 tbn, 25 tbc
Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.1(side), s16, 448 kb/s
title : AVO ######
I can provide the .torrent file if you need the exact video for dissection.
Post Sat Dec 24, 2011 7:43 pm
Re: AVC problem
try renaming teh fiel to .mp4 and then adding it to library. :) i have found this works on some files but sadly not all.
pain666
Post Sun Dec 25, 2011 2:48 am
Re: AVC problem
Nope, didn't help. Playback not available.
NX3
Post Sun Dec 25, 2011 9:41 am
Re: AVC problem
What Sony have you got ?
What profile are you using in Serviio ?
Can you post the full list of data from media info, I'm interested in what created the file mainly ?
pain666
Post Sun Dec 25, 2011 9:49 am
Re: AVC problem
I have a Sony KDL-46CX520, everything ffmpeg -i reported I have posted before the screenshot from VLC. Profile is Sony Bravia TV 2011:
ffmpeg -i output again:
    JUNK            :
      title           : AVO ######
NX3
Post Sun Dec 25, 2011 10:25 am
Re: AVC problem
Get mediainfo at http://mediainfo.sourceforge.net/en it will get a lot more detail about the file. Select 'text' from the 'view' menu and then paste that into a 'code' block so its readable.
The problem I had was with "Writing application : transcode-1.0.6" which I posted about in the Sony forum. No work around as yet unless you change the profile to 2010 profile manually then then are transcoded to mpeg2 so will play. Nothing is wrong with the file as such, just Sony firmware doesn't like it. All other details were fine, same as other files that did play and form the 50 lines of details about the file that was the only constant between those that did and didn't play.
pain666
Post Sun Dec 25, 2011 12:45 pm
Re: AVC problem
Wow, thanks! After changing profile to "Sony Bravia TV" it worked! Here is the MediaInfo output:
Complete name                            : /Users/pain/Desktop/Movies/Chugyeogja.avi
Format                                   : AVI
Format/Info                              : Audio Video Interleave
Format profile                           : OpenDML
Format settings                          : rec
File size                                : 1.51 GiB
Duration                                 : 1h 59mn
Overall bit rate                         : 1 801 Kbps
Writing application                      : AVI-Mux GUI 1.17.8, Aug 30 2008  12:36:58
Format                                   : MPEG-4 Visual
Format profile                           : Advanced Simple@L5
Format settings, BVOP                    : 1
Format settings, QPel                    : No
Format settings, GMC                     : No warppoints
Format settings, Matrix                  : Default (H.263)
Codec ID                                 : XVID
Codec ID/Hint                            : XviD
Duration                                 : 1h 59mn
Bit rate                                 : 1 348 Kbps
Width                                    : 720 pixels
Height                                   : 304 pixels
Display aspect ratio                     : 2.35:1
Frame rate                               : 25.000 fps
Bits/(Pixel*Frame)                       : 0.246
Stream size                              : 1.13 GiB (75%)
Writing library                          : XviD 1.2.1 (UTC 2008-12-04)
Codec ID                                 : 2000
Duration                                 : 1h 59mn
Bit rate                                 : 448 Kbps
Stream size                              : 384 MiB (25%)
Alignment                                : Aligned on interleaves
Interleave, duration                     : 64 ms (1.60 video frames)
Interleave, preload duration             : 192 ms
Title                                    : AVO Ñåðáèí
NX3
Post Sun Dec 25, 2011 2:37 pm
Re: AVC problem
it might be cause its a opendml file...can't see why else it won't play native
Post Sun Dec 25, 2011 8:27 pm
Re: AVC problem
For this specific avi file, you can change and select "Sony 2010 profile" for your CX520 model, it will be transcode to mpeg2video.
Users browsing this forum: Bing [Bot] and 10 guests
