Web UI in PHP
Xmantium
Post Sat Dec 24, 2011 8:27 pm
Re: Web UI in PHP
Has there been progress with 0.6.1 release?
I do prefer this as the web UI of choice for my Linux server
mpemberton5
Post Sat Jan 07, 2012 10:40 pm
Re: Web UI in PHP
Xmantium wrote:Has there been progress with 0.6.1 release?
I'll be posting an update from AcidumIrae's base code shortly.
Hope all is well!
Xmantium
Post Sat Jan 07, 2012 10:53 pm
Re: Web UI in PHP
welcome back mark, hope u enjoyed your long vacation
looking forward to your release :D
pilothaz
Post Tue Jan 10, 2012 5:41 pm
Re: Web UI in PHP
waiting in anticipation.... Have 6.0.1 installed just waiting on the UI now :)
Xmantium
Post Tue Jan 10, 2012 6:29 pm
Re: Web UI in PHP
Me TOO!! :P
Little bird told me it may be out today!
mpemberton5
Post Wed Jan 11, 2012 6:27 am
Re: Web UI in PHP
As promised, here's the update to the base code of Web UI.
http://dl.dropbox.com/u/42061/serviio-webUI-0.6.1%20r1.zip
The changes are mostly to adhere to updated REST specs. I think you'll enjoy the update. I'm not perfect, so please inform me of any issues.
There are a couple changes that still need to be done:
1) add an enable/disable box on the online sources. They should default to enabled for now.
2) add an edit option to the online resources.
3) specifying source type of online source
4) basically refine how the online source list works. It needs work. :)
5) use the other cool features that zip has added to the REST featureset. Very nice updates to come.
Anyway, this should get you running. Expect more updates very soon. I'm going to work at being more diligent to provide updates.
Cheers,
Post Wed Jan 11, 2012 9:28 am
Re: Web UI in PHP
Great Mark. Will it also work with the future 0.6.2 (no API changes, just in case you do some version matching)
Xmantium
Post Wed Jan 11, 2012 11:34 am
Re: Web UI in PHP
Thankyou Mark for your efforts! :)
Very quick turnaround. Looking forward to the updates
@zip, theres a config.php file that you can edit the Serviio version otherwise its going to say "could not find server version 0.6.1 but found 0.6.2"
Post Wed Jan 11, 2012 12:31 pm
Re: Web UI in PHP
maybe it should include a list of compatible versions, ie 0.6.1, 0.6.2
mpemberton5
Post Wed Jan 11, 2012 2:39 pm
Re: Web UI in PHP
The version validation is definitely a point of interest and have it on my radar to change. I like the option of stating a
Release range that webUI will work with (ie 0.6.1 thru 0.6.5). It isn't foolproof, but a good start. I'm certainly open to other ideas. I think a more active role of myself in testing beta versions will help. :)
mpemberton5
Post Wed Jan 11, 2012 2:53 pm
Re: Web UI in PHP
Just noticed that the 0.6.2 release is a bug fix release and Zip wants to release it ASAP so I'll set my priorities accordingly.
Xmantium
Post Wed Jan 18, 2012 12:12 pm
Re: Web UI in PHP
How are the updates coming along?
mpemberton5
Post Sat Jan 21, 2012 5:48 am
Re: Web UI in PHP
Hoping that my testing goes well, I should have a release ready this weekend.
Cheers,
Xmantium
Post Sat Jan 21, 2012 3:09 pm
Re: Web UI in PHP
Thats brilliant!
Are going to make it work for both 0.6.1 and 0.6.2?
mpemberton5
Post Sat Jan 21, 2012 3:19 pm
Re: Web UI in PHP
Xmantium wrote:Are going to make it work for both 0.6.1 and 0.6.2?
First thing I did. The "solution" isn't necessarily what I want, but it doesn't add new requirements. Need to discuss with users if it would be acceptable to require SQLite (with option to use MySQL instead). This would give me some additional options.
Xmantium
Post Sat Jan 21, 2012 5:04 pm
Re: Web UI in PHP
Adding MySQL/SQLite can be messy for novice users. Most NAS service like mine has web server set up but not for SQL.
Why not make it for 0.6.2(should be out very soon), and advise users to change in config.php file for 0.6.1 users
Post Sat Jan 21, 2012 5:58 pm
Re: Web UI in PHP
or use derby db
mpemberton5
Post Sat Jan 21, 2012 7:55 pm
Re: Web UI in PHP
Cerberus wrote:or use derby db
Good question. I've done some pretty extensive research and it appears there is no way for PHP to connect to Derby without loading the full DB2 client. Granted, I may be missing something and will be gladly accept correction if there is a way to do it without the requirement of the DB2 client. SQLite and MySQL drivers are included in standard Apache installations and wouldn't require someone to load additional software. With that said, I can't be 100% positive because QNAP users may have a mildly different Apache configuration. Before I took off in one direction, I wanted to do some due diligence and query everyone so as to not reduce the user base.
Your comments are much appreciated! Cheers,
Xmantium
Post Sat Jan 21, 2012 8:20 pm
Re: Web UI in PHP
My vote: keep it simple and faithful to original like you did with 0.6/0.6.0.1
so no to MySQL
mpemberton5
Post Sat Jan 21, 2012 8:23 pm
Re: Web UI in PHP
Xmantium wrote:My vote: keep it simple and faithful to original like you did with 0.6/0.6.0.1
so no to MySQL
Noted. Thanks for your input!
