The MOST frustrating software I have EVER used
Euromancer
Post Sun Dec 25, 2011 2:29 pm
I have been trying to get Serviio working reliably for a long time now.
I have been looking for a way to stream content held on my computer to my DNLA TV an LG LD490, which has an ethernet port built into the set.
My 1st attempt almost 4 month ago worked for a short time, Serviio would pick and choose which files it would accept to play, mostly returning Audio no supported. After some playing about i uninstalled and though little more of it tbh. I found other DNLA streaming programs such as TVMobili which worked but I had the same audio problems. Both systems seems to offer transcoding out of the box however both JUST don't do it. TVmobili worked well but after a certain amount of content watched you have to wait until the next month or pay per month which is BS since it is my own content.
So I thought I would try Serviio once more, I installed it, I followed the some what loose even sparse instructions on the website considering how much seemingly goes wrong from reading these forums. i diligently read through the FAQ and searched the forums. Serviio still will not work. The best I have got it to work is as follows:
It will show up on the TV list, I can select it as a service I can see the root/top directory but when I try and look in that folder nothing happens, at best the TV reports that the folder is empty at worse the tv will throw an error that the folder is not reachable. So I search for an answer.
I have changed the security setting since i do not log on/in into Windows 7 64 bit to reflect user privileges
I have delayed the started of the Serviio service
I have bound the IP into the console with what seems no effect as serviio still see's two devices 1of the ip's belonging to the computer and the LG tv both with an orange light. (How can it see the IP that it is bound to as a service?)
Transcoding just doesn't seem to do anything at all, I have trailed the LG section of the site and looked at others XML config and played about with them with no joy.
I am to be honest totally frustrated with this software and would find is very hard to recommend it to anyone other than serious terminal/DOS box geeks.
Post Sun Dec 25, 2011 3:49 pm
Re: The MOST frustrating software I have EVER used
In the latest beta, I know a few people have been streaming their desktop via serviio. Wait for the next release, which should be soon and try it again.
Post Sun Dec 25, 2011 6:23 pm
Sorry for your inconvenience.
But with a simple installation that works perfectly with my Sony devices and Windows XP over DLNA.
Serviio try to be 100% DLNA compliant with some specific mods (Samsung,Xbox,etc).
But it seems that LG devices are not really DLNA compliant but "compatible".
I suggest to read topics on LG section:http://forum.serviio.org/viewforum.php?f=12
Post Sun Dec 25, 2011 8:27 pm
Thanks for the feedback. Unfortunately DLNA streaming may not be as straightforward as other software. It depends on functionality provided by other IT components, mostly networking, DLNA devices, security, etc. So although it might work out of the box for most, others might have to find the right settings of their environment.
I'm sure if you post in the support section someone will help you to get it working.
Euromancer
Post Sun Dec 25, 2011 9:26 pm
Thanks for the replies especially on such a day as today, I have re-read what i put and i hope it doesn't come over as "bashing" serviio, but more utter frustration that it doesn't work unless you have an "ology" to get it to behave. I must 100% support you, that you are at the mercy of the actual manufacture as to how they have implemented the tech, middleware etc...
I will be posting in the next few days in the LG forum and hope I will get it working so that I might contribute to the community from a "noobs" prescriptive.
Post Sun Dec 25, 2011 9:56 pm
cool
Post Mon Dec 26, 2011 2:23 am
Glad you are giving Serviio a chance. We will be here to support you.
NX3
Post Tue Dec 27, 2011 10:45 am
Euromancer wrote:Serviio would pick and choose which files it would accept to play, mostly returning Audio no supported.
This is most likely caused by serviio passing the raw DTS sound to your tv and your tv not understanding it. LG historically didn't licences DTS (big thread on avforums about lack of support on LG). In serviio setting audio to 'downmix to stereo' should get around the problem as any tv can cope with stereo sound.
Per other issues, as others have said it mostly works out the box but some setups are different and LG support might not be a strong as other manufactures e.g Sony / Samsung. If you feedback in the LG forum hopefully you can get it working and help make serviio better support LG.
Return to User experiences
