PS3 Serviio Media Server Error
Below I have attached the serviio.log (debug)
PS3 firmware version - 4.00
Thank you for your help!
2011-12-26 18:50:12,089 DEBUG [VideoDeliveryEngine] Delivering item '3' for client 'IPAddress=/192.168.1.115, Profile=Playstation 3'
2011-12-26 18:50:12,089 DEBUG [VideoDeliveryEngine] Delivering file 'Almost Heroes.mkv' using transcoding
2011-12-26 18:50:12,089 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.115, Profile=Playstation 3'
2011-12-26 18:50:12,089 DEBUG [MediaItemDAOImpl] Getting file of media item 3
2011-12-26 18:50:12,090 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: E:\Almost Heroes.mkv
2011-12-26 18:50:12,090 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -i E:\Almost Heroes.mkv -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-3-MPEG2TS.stf
2011-12-26 18:50:12,132 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2011-12-26 18:50:12,132 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2011-12-26 18:50:12,590 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
at org.serviio.delivery.resource.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:117)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:93)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:121)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:116)
2011-12-26 18:50:12,595 DEBUG [WebServer] Incoming connection from /192.168.1.115:59149
2011-12-26 18:50:12,595 DEBUG [ResourceTransportRequestHandler] GET /resource/3/MEDIA_ITEM/AVC_TS_MP_SD_AC3_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.114:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";,TimeSeekRange.dlna.org: npt=0.000-]]
moltra wrote:
- Code:
Try running the follow command from a windows command prompt and see what happens. Post any errors here.
Cerberus wrote:is the PS3 profile assigned to the device in consoel or the generic profile?
http://wiki.serviio.org/doku.php?id=ser ... _explained
[/quote]will wrote:If the file has spaces then you must use quotes eg
ffmpeg.exe -i "c:\media files\my file.avi"
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Jeff>cd "C:\Program Files (x86)\Serviio\lib"
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i
nfig
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 6. 0 / 53. 6. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 25. 0 / 2. 25. 0
libswscale 2. 0. 0 / 2. 0. 0
ffmpeg.exe: missing argument for option 'i'
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "E:\Almost Heroes.mkv"
nfig
[matroska,webm @ 01848b00] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 180000.00 (18
0000/1) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'E:\Almost Heroes.mkv':
Duration: 01:30:13.15, start: 0.000000, bitrate: N/A
Stream #0.0(eng): Video: h264 (Main), yuv420p, 704x400 [PAR 1:1 DAR 44:25],
23.98 fps, 23.98 tbr, 1k tbn, 180k tbc (default)
Stream #0.1: Audio: aac, 48000 Hz, stereo, s16 (default)
Cerberus wrote:can you run mediainfo on the file aswell please: http://wiki.serviio.org/doku.php?id=mediainfo
Unique ID : 41775935580685000149497901831401882298 (0x1F6DC0A5BCF6D7A274F826DF7BEDC2BA)
Complete name : E:\Almost Heroes.mkv
Format : Matroska
Format version : Version 2
File size : 911 MiB
Duration : 1h 30mn
Overall bit rate : 1 412 Kbps
Writing application : HandBrake 0.9.5
Writing library : libmkv 0.6.4.1
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 30mn
Width : 704 pixels
Height : 400 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 112
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=2 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=0 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1h 30mn
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Default : Yes
Forced : No
