LG BD660 Blu Ray Player, srt subtitles not working!
brianh
Post Tue Dec 27, 2011 6:22 pm
I have an LG BD660 Blu Ray player, it does support srt subtitles, but when playing a movie from serviio the subtitles are not shown/detected.
The subtitle file is named correctly (same as movie file but with srt extension), and if I copy the movie and subtitle files to a USB stick and plug it into the player it plays fine and the subtitles work as expected.
I initially selected the "LG TV / player" profile, but when this did not work I then tried adding a new minimal profile as mentioned in another post:
<Profile id="21" name="LG Test" extendsProfileId="1">
This didn't work either. :(
I turned on DEBUG mode and tried to play "The Da Vinci Code" with subtitles, and I have attached the log file produced.
Any help would be much appreciated.
Brian
UPDATE: I have installed Nero MediaHome 4 Essentials (it came with the player) and the subtitles work when the movie is played from this server, so the files must be OK.
serviio.zip
(217.42 KiB) Downloaded 748 times
Post Tue Dec 27, 2011 8:19 pm
Re: LG BD660 Blu Ray Player, srt subtitles not working!
brianh
Post Tue Dec 27, 2011 11:47 pm
Hi Cerberus,
I made the change to the profile mentioned in the post you linked to, but it didn't help. I even downloaded the modified 'profiles.xml' file and tried that, in case I had made a mistake copying the changes, but it was just the same - the movie still plays OK, but no subtitles, doesn't matter if I browse to it via Movies or Folders. :(
Post Wed Dec 28, 2011 9:39 am
did you restart Serviio / your PC after you made the change?
brianh
Post Wed Dec 28, 2011 11:22 am
Hi Zip,
Yes, I restarted the windows service, and also the DLNA server via the Serviio console, and since then I have also restarted the PC, but still no subtitles. :(
Post Wed Dec 28, 2011 11:37 am
did you try an AVI file?
brianh
Post Sat Dec 31, 2011 9:43 pm
Yes, the movies I have tried are all AVI files.
Return to LG
