HOWTO: Use MediaInfo to provide details of a file
NX3
Post Wed Dec 28, 2011 10:30 am
Below is the link on how to get details of a file using FFMPEG but sometimes its useful to get additional information using MediaInfo (see below)
HOWTO: Provide details of a video file that doesn't play
viewtopic.php?f=5&t=1123
1, Download and install Mediainfo from http://mediainfo.sourceforge.net/en
2, Run MediaInfo and use it to 'Open' the file you want to inspect;
3, Switch view from MediaInfo menu, select 'View' then from the drop down list select 'Text'. This will provide a simple but detailed list view as per this screenshot.
6, You can select the text in MediaInfo and then copy and paste then your posting. Remember to use the 'Code' option and paste the text into the code box on your posting so that it's more readable.
Post Wed Dec 28, 2011 6:12 pm
Re: HOWTO: Use MediaInfo to provide details of a file
this was already availible from the wiki: http://wiki.serviio.org/doku.php?id=mediainfo
Post Sat Oct 21, 2017 5:50 am
Media Info Lite can also be downloaded from http://codecguide.com/download_other.htm. Its for Windows users.
Once installed allows you right-click on a media file from Windows Explorer and get MediaInfo information from the context menu.
sekaijin
Post Sun Jun 03, 2018 3:56 pm
HI
you can use https://mediaarea.net/MediaInfoOnline to read media info.
It's purely local.
No media is transmitted over the internet.
It uses a compiled library for WASM.
Bye
Users browsing this forum: Google [Bot] and 69 guests
