Problems with MKV / H.264 on Sony BDP-S370 Bluray-Player
Lowlander
Post Thu Sep 02, 2010 7:44 am
Re: Problems with MKV / H.264 on Sony BDP-S370 Bluray-Player
zip,
I did quite a few tests, mostly with HD stuff from trailershows and showcases and some avc files. My results are a bit lengthy, so I include them a as a file. At least I'd like to, but txt is not allowed as an attachment type. I chose a PM as a quick workaround.
CU back on the forum,
Low
Post Thu Sep 02, 2010 12:03 pm
Posting your reply here, thanks a lot, it's very detailed.
-- Player error: "Audioformat not supported" (eventually just one still picture is played
-- or video stops after a few frames. Silent video plays fine from flashdrive)
video/divx:DLNA.ORG_PN=WMVHIGH_PRO;
Input #0, asf, from 'E:\daten\mm2\TEST\Clips\Amazing_Caves_1080.wmv':
WM/ParentalRating:
WMFSDKVersion : 9.00.00.2980
WMFSDKNeeded : 0.0.0.0000
IsVBR : 0
title :
author :
copyright :
comment :
Duration: 00:01:25.49, start: 3.000000, bitrate: 8295 kb/s
Stream #0.0(eng): Audio: wmapro, 48000 Hz, 5.1, flt, 384 kb/s
Stream #0.1(eng): Video: wmv3, yuv420p, 1440x1080, 8000 kb/s, PAR 4:3 DAR 1
:9, 24 tbr, 1k tbn, 1k tbc
video/divx:DLNA.ORG_PN=VC1_ASF_AP_L3_WMA;
Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000
/1) -> 23.98 (24000/1001)
Input #0, asf, from 'E:\daten\mm2\TEST\Clips\Trailer\DKTRL3_1080.wmv':
WMFSDKVersion : 11.0.5721.5145
IsVBR : 0
Duration: 00:02:31.19, start: 10.000000, bitrate: 7579 kb/s
Stream #0.0(eng): Audio: wmapro, 96000 Hz, stereo, flt, 440 kb/s
Stream #0.1(eng): Video: vc1, yuv420p, 1920x816, 8000 kb/s, 23.98 tbr, 1k tb
n, 1k tbc
-- Jerky, slow motion play, stuttering sound
video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;
[mpeg @ 010fd0a0]Invalid timestamps stream=0, pts=0, dts=8589931589, size=2015
[mpeg @ 010fd0a0]MAX_READ_SIZE:5000000 reached
Input #0, mpeg, from 'E:\daten\mm2\TEST\Clips\crawford.mpg':
Duration: 00:00:29.39, start: 0.000000, bitrate: 31158 kb/s
Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9]
, 30000 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
video/divx:DLNA.ORG_PN=WMVHIGH_FULL;
[wmv3 @ 010febf0]Extra data: 8 bits left, value: 0
/1) -> 29.97 (30000/1001)
Input #0, asf, from 'E:\daten\mm2\TEST\Clips\NASA\exp13HD_720p.wmv':
SfOriginalFPS : 299
WMFSDKVersion : 11.0.5358.4827
IsVBR : 0
Duration: 00:04:28.32, start: 8.000000, bitrate: 6645 kb/s
Stream #0.0(eng): Audio: wmav2, 44100 Hz, 2 channels, s16, 128 kb/s
Stream #0.1(eng): Video: wmv3, yuv420p, 1280x720, 8260 kb/s, 29.97 tbr, 1k t
bn, 1k tbc
video/divx:DLNA.ORG_PN=AVC_MP4_MP_HD_720p_AAC;
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'E:\daten\mm2\TEST\Clips\NASA\HUHD_020_C
asA.m4v':
major_brand : M4VH
minor_version : 1
compatible_brands: M4VHM4A mp42isom
Duration: 00:05:11.70, start: 0.000000, bitrate: 3985 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 1280x720, 3851 kb/s, 23.98 fps, 23.9
8 tbr, 2997 tbn, 5994 tbc
Stream #0.1(eng): Audio: aac, 44100 Hz, stereo, s16, 127 kb/s
video/divx:DLNA.ORG_PN=AVC_MP4_MP_HD_1080i_AAC;
[mov,mp4,m4a,3gp,3g2,mj2 @ 010fd0a0]max_analyze_duration reached
Seems stream 0 codec frame rate differs from container frame rate: 4800.00 (4800
/1) -> 24.00 (24/1)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'E:\daten\mm2\TEST\Clips\Trailer\DKTRL3_
1080.mov':
major_brand : qt
minor_version : 537199360
compatible_brands: qt
Duration: 00:02:30.18, start: 0.000000, bitrate: 11548 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 1920x818, 10922 kb/s, 24 fps, 24 tbr
, 2400 tbn, 4800 tbc
Stream #0.1(eng): Audio: aac, 48000 Hz, stereo, s16, 116 kb/s
Stream #0.2(eng): Data: tmcd / 0x64636D74
Stream #0.3(eng): Data: rtp / 0x20707472, 9 kb/s
Stream #0.4(eng): Data: rtp / 0x20707472, 494 kb/s
[aac @ 029841f0]channel element 3.0 is not allocated
Last message repeated 236 times
[mov,mp4,m4a,3gp,3g2,mj2 @ 010fd0b0]max_analyze_duration reached
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (200000
00/417083) -> 23.98 (24000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'E:\daten\mm2\TEST\Clips\Trailer\I Am Le
gend - Trailer.mp4':
major_brand : isom
minor_version : 1
compatible_brands: isom
encoder : MeGUI
Duration: 00:02:03.24, start: 0.000000, bitrate: 8145 kb/s
Stream #0.0(und): Video: h264, yuv420p, 1920x816 [PAR 1:1 DAR 40:17], 7887 k
b/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
Stream #0.1(und): Audio: aac, 5.1, s16, 258 kb/s
video/divx:DLNA.ORG_PN=WMVMED_FULL;
[asf @ 010fd0a0]max_analyze_duration reached
Seems stream 2 codec frame rate differs from container frame rate: 1000.00 (1000
/1) -> 25.00 (25/1)
Input #0, asf, from 'E:\daten\mm2\TEST\Serviio\asf_with_chapters.wmv':
WMFSDKVersion : 10.00.00.3802
VBR Peak : 476
IsVBR : 1
WM/ParentalRating: 10
title : ASF chapters test
author : Window Media File Editor
copyright : none
comment : asf test file with chapters
Duration: 00:00:28.08, start: 3.057000, bitrate: 4667 kb/s
Chapter #0.0: start 3.000000, end 13.000000
title : The boring start
Chapter #0.1: start 13.000000, end 23.000000
title : 10s into the clip
Chapter #0.2: start 23.000000, end 28.000000
title : Still a boring clip
Chapter #0.3: start 28.000000, end 31.139000
title : Is it over soon?
Stream #0.0(ger): Audio: wmav2, 44100 Hz, 2 channels, s16, 105 kb/s
Stream #0.1(eng): Audio: wmav2, 44100 Hz, 2 channels, s16, 105 kb/s
Stream #0.2(eng): Video: wmv3, yuv420p, 320x200, 4450 kb/s, PAR 4:3 DAR 32:1
5, 25 tbr, 1k tbn, 1k tbc
-- This file is in the library, but not in the player's list. It doesn't
-- have any resource entry in AV media controller either. It plays from USB though.
(no entry)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'E:\daten\mm2\TEST\no_avidemux\ARD Ratge
ber Heim und Garten vom_08.08.2010 (avc - aac).mp4':
major_brand : isom
minor_version : 512
compatible_brands: isomiso2mp41
encoder : Lavf52.61.0
Duration: 00:29:32.03, start: 0.000000, bitrate: 2167 kb/s
Stream #0.0(und): Video: mpeg4, yuv420p, 960x544 [PAR 136:135 DAR 16:9], 199
7 kb/s, PAR 967:960 DAR 967:544, 25 fps, 29 tbr, 29 tbn, 29 tbc
Stream #0.1(und): Audio: aac, 48000 Hz, stereo, s16, 165 kb/s
-- Player error: "File corrupt or unsupported"
video/divx:DLNA.ORG_PN=AVI;
Input #0, avi, from 'E:\daten\mm2\TEST\Clips\Begehbarer Schrank.avi':
Duration: 00:00:32.20, start: 0.000000, bitrate: 934 kb/s
Stream #0.0: Video: msmpeg4v2, yuv420p, 480x266, 24.94 tbr, 24.94 tbn, 24.94
tbc
Stream #0.1: Audio: mp3, 44100 Hz, 2 channels, s16, 64 kb/s
[mov,mp4,m4a,3gp,3g2,mj2 @ 010fd0b0]MAX_READ_SIZE:5000000 reached
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'E:\daten\mm2\TEST\Clips\NASA\ksc_062707
_sts117_launch_1080p.mp4':
major_brand : mp42
minor_version : 0
compatible_brands: mp42avc1
Duration: 00:00:34.81, start: 0.033367, bitrate: 31996 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 1920x1080 [PAR 100:100 DAR 16:9], 31
878 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 59.94 tbc
Stream #0.1(eng): Audio: aac, stereo, s16, 157 kb/s
/1) -> 30.00 (30/1)
Input #0, asf, from 'E:\daten\mm2\TEST\Serviio\wmv2_new_vlc-issue1637.wmv':
WMFSDKVersion : 9.00.00.4506
IsVBR : 0
Duration: 00:05:21.82, start: 10.000000, bitrate: 1530 kb/s
Stream #0.0(eng): Audio: wmav2, 16000 Hz, 1 channels, s16, 16 kb/s
Stream #0.1(eng): Video: wmv2, yuv420p, 640x360, 1500 kb/s, 30 tbr, 1k tbn,
1k tbc
-- jerky play after over a minute of black screen, think this one is faulty
Input #0, mpeg, from 'E:\daten\mm2\TEST\Clips\NASA\shuttle Start HDTV.mpg':
Duration: 26:33:22.15, start: 0.018789, bitrate: 34 kb/s
, 20000 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
Stream #0.1[0x80]: Audio: ac3, 48000 Hz, stereo, s16, 384 kb/s
-- Those Files play fine
video/divx:DLNA.ORG_PN=MATROSKA;
[matroska @ 010fd0b0]Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 23.98 (48000/2002)
Input #0, matroska, from 'E:\daten\mm2\TEST\Clips\SevenPoundsTrailer[DivX7].mkv'
COMMENT : Encoded in DivX 7
Duration: 00:02:27.47, start: 0.000000, bitrate: N/A
Stream #0.0(eng): Video: h264, yuv420p, 1920x912, PAR 1:1 DAR 40:19, 24.39 f
ps, 23.98 tbr, 1k tbn, 47.95 tbc
title : Main title
title : English Stereo
video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;
[mpeg2video @ 010ff720]mpeg_decode_postinit() failure
Last message repeated 9 times
[mpegts @ 010fd0a0]MAX_READ_SIZE:5000000 reached
Input #0, mpegts, from 'E:\daten\mm2\TEST\Clips\NASA\endevour.mpg':
Duration: 00:05:49.85, start: 2303.478778, bitrate: 19046 kb/s
Program 2
Stream #0.0[0x21]: Video: mpeg2video, yuv420p, 1280x720 [PAR 1:1 DAR 16:9],
45000 kb/s, 63.96 fps, 59.94 tbr, 90k tbn, 119.88 tbc
Stream #0.1[0x24]: Audio: mp2, 48000 Hz, 2 channels, s16, 192 kb/s
[matroska @ 010fd0b0]max_analyze_duration reached
Input #0, matroska, from 'E:\daten\mm2\TEST\Serviio\GIJoeTheRiseOfCobraTrailer-D
ivXPlusHD.mkv':
TITLE : G.I. Joe - The Rise Of Cobra Trailer
TITLE/URL : http://www.gijoemovie.com
COPYRIGHT : 2009 by PARAMOUNT PICTURES. All rights reserved. G.I. JOE
and related characters are trademarks of Hasbro and are used with permission. 20
09 Hasbro. All Rights Reserved.
COMMENT : Encoded in DivX Plus HD for the DivX Plus Web Player
Duration: 00:02:14.16, start: 0.000000, bitrate: N/A
Stream #0.0(eng): Video: h264, yuv420p, 1280x528, PAR 1:1 DAR 80:33, 24.39 f
title : Main title
title : English 2ch Stereo
Stream #0.2(eng): Subtitle: 0x0000
title : English
Stream #0.3(fre): Subtitle: 0x0000
title : French
Stream #0.4(ger): Subtitle: 0x0000
title : German
Stream #0.5(por): Subtitle: 0x0000
title : Portuguese
Stream #0.6(spa): Subtitle: 0x0000
title : Spanish
[matroska @ 010fd0a0]Unknown entry 0xC6
[matroska @ 010fd0a0]Unknown entry 0xEA
[matroska @ 010fd0a0]Unknown entry 0x53B8
[matroska @ 010fd0a0]Unknown entry 0x2AD1D3
[matroska @ 010fd0a0]Estimating duration from bitrate, this may be inaccurate
Input #0, matroska, from 'E:\daten\mm2\TEST\Serviio\Iron_Man_2-DivXPlusHD.mkv':
Duration: 00:02:30.51, start: 0.000000, bitrate: N/A
Stream #0.0(eng): Video: h264, yuv420p, 1920x800 [PAR 1:1 DAR 12:5], 24.39 f
video/divx:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;
[aac @ 02970280]Transition from an ONLY_LONG or LONG_STOP to an EIGHT_SHORT sequ
ence detected. If you heard an audible artifact, please submit the sample to the
FFmpeg developers.
Last message repeated 1 times
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'E:\daten\mm2\TEST\Service Reisen - Wien
_entdecken (24min - AVC - AAC).mp4':
major_brand : mp42
minor_version : 0
compatible_brands: isommp42
Duration: 00:24:49.47, start: 0.000000, bitrate: 894 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 512x288 [PAR 1:1 DAR 16:9], 766 kb/s
, 25 fps, 25 tbr, 25k tbn, 50 tbc
Stream #0.1(eng): Audio: aac, 48000 Hz, stereo, s16, 125 kb/s
video/divx:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'E:\daten\mm2\TEST\c_t_magazin_vom_21.08
.2010 (avs - mp4-1800 - aac).mp4':
major_brand : mp42
minor_version : 0
compatible_brands: mp42isom
Duration: 00:04:34.88, start: 0.000000, bitrate: 1989 kb/s
Stream #0.0(eng): Video: mpeg4, yuv420p, 512x288 [PAR 1:1 DAR 16:9], 1795 kb
/s, 25 fps, 25 tbr, 1k tbn, 25 tbc
Stream #0.1(eng): Audio: aac, 48000 Hz, stereo, s16, 189 kb/s
Lowlander
Post Sat Oct 09, 2010 11:06 am
Hi all,
as this thread has long ago left the subject of MKV playback and became the official Sony BDP-x70 thread, here's a MPEG2 question:
I just dumped the idea of consolidating my collection of self-made DVDs (mainly DVB recordings) onto BD-R and bought a 2TB HD for my trusted Serviio server. Now is the time to make those DVDs known to the library. The easiest way by far is just whack the DVD into the PC and extract each title as a single VOB. DVDdecrypter does this quite nicely.
Problem is now that there are 4:3 videos among those DVDs, and the aspect ratio seems to get lost in the chain VOB (still 4:3) -> Serviio library -> Serviio server -> Sony BDP -> TV. With real DVDs there is no aspect ratio issue between Player and TV, so I suspect that a/r is either not passed on (or not detected in the first place) by Serviio or not recognized by the Sony.
Anyone found a way around this?
[b]UPDATE: Found that 4:3 aspect ratio is correctly displayed if VOB or MPG is remuxed to TS or M2TS first.[/b]
And the Sony still seems to play any DLNA file in 1080/60p. I think I vaguely remember the Sony switching to 1080/50p for just one file it got through serviio, but I can't think of the format now, maybe it was some kind of divx.
Is there ANY way to trick it into 1080/50p?
Have a nice one,
Low
patters
Post Sat Oct 09, 2010 4:07 pm
I've tried the last few releases of Serviio, along with many other DLNA servers and I reckon that Serviio is well on the way to supremacy. The source to PS3MS has a lot of hacky workarounds and it seems (at least from what I've read on here) that Serviio is adhering much more rigidly to the actual DLNA spec, which can only be a good thing. However, there are a few things that are not quite right yet. I'll list my feedback below:
The media library is very neat, and I like the movie box art and additional metadata. Shame the Sony BDP devices only seem to be able to show thumbnails for Photo objects for the time being. My 2009 Bravia TV does show them. The generation of thumbnails using FFMPEG seems quite slow though, so I turned that off. I have a suggestion - please could the alphabetical listing of people's names (actors, directors) be sorted by surname, and not by first name? I also noticed that on the Mac the "library status" line in Serviio Console tells you what library activity is happening, but on the Windows version that is not displayed.
I noticed that on Serviio, as well as PS3 Media Server, FFWD/REW does not work for MP4 container files with the Sony BDP. I guess these files ought to be remuxed to M2TS. I'll test this later, but clearly this is a simple profile adjustment.
Playback of HD content (in the chunked mode the Sony BDP requests) works properly thanks presumably to a stateful HTTP handler (something PS3MS lacks). However, there is a problem - files play perfectly smoothly until you FFWD/REW. Once you search in the stream like this the output becomes stuttery and will not recover. This doesn't happen for M2TS files (I discovered from debugging PS3MS that the player does not request M2TS files in chunked mode). There's nothing to compare this post-seek stuttering behaviour to though, since the only two other DLNA servers I've had working with the Sony BDP are PS3MS which cannot FFWD/REW in transcoded/remuxed file - chunked mode HD content stutters during normal playback - and Mezzmo which seems to remux everything to M2TS and won't allow FFWD/REW. EDIT - I see this is a known problem in the issue tracker, along with some general buffer choking issue.
As a feature request - would it be possible to have the Mac version parse the iPhoto Library, showing stuff by events etc.? AFAIK it should be pretty simple - the events are themselves just folders inside the 'Library' which is actually just a folder. I tried adding it manually ('add path' instead of 'add local') but the results were unpredictable (it seemed to really hammer the computer). Those photos that were added seemed to be low res versions for some reason. Photo browsing worked perfectly when running Serviio on the PC however.
patters
Post Sat Oct 09, 2010 8:57 pm
I have noticed, as discussed here that .MTS files do not seem to be parsed by Serviio. EDIT - I see in the issue tracker this is fixed in the upcoming version 0.5.0.
It seems that VC-1 playback over DLNA on the Sony BDP is as problematic with Serviio as with PS3MS. It seems to play the first couple of seconds of WMV test clips then freeze using either server, so my guess is that it won't ever work satisfactorily, and that looks to be the player's fault. The same clips play fine off USB.
That said, I noticed that I could put to use the tricks I had discovered using PS3MS, namely that it's not only the mime-type that's significant to the player: I can get the player to list the appropriate files and use the M2TS and MPEG icons by forcing the DLNA media type name field instead. I had wanted to do this before version 0.4.2 but I assumed Zip would have to extensively modify the code, so when I saw the 2010 Bravia TV profile in 0.4.2 I realised it was possible.Those same substitutions for the Bravia TVs don't work with the Sony BDP incidentally (the _HD_50 ones). I also added a few DLNA media types that were missing, fixed detection of M2TS files, and fixed up the media type for remuxed M2TS H.264 files - something that would not have worked at all until now. Here are my MediaFormatProfiles values for European models:
<MediaFormatProfile mime-type="audio/mpeg" name="MP3">WMA_BASE</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/mpeg" name="MP3">WMA_FULL</MediaFormatProfile>
<MediaFormatProfile mime-type="video/divx">MATROSKA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">AVC_MP4_LPCM</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_PAL">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/divx">WMVMED_BASE</MediaFormatProfile>
<MediaFormatProfile mime-type="video/divx">WMVMED_FULL</MediaFormatProfile>
<MediaFormatProfile mime-type="video/divx">WMVHIGH_FULL</MediaFormatProfile>
<MediaFormatProfile mime-type="video/divx">WMVMED_PRO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/divx">WMVHIGH_PRO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/divx">VC1_ASF_AP_L1_WMA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/divx">VC1_ASF_AP_L2_WMA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/divx">VC1_ASF_AP_L3_WMA</MediaFormatProfile>
<!-- rename remuxed mpeg2ts with h264 to one of the player's supported profiles -->
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
Substitute MPEG_TS_SD_EU for MPEG_TS_SD_NA or MPEG_TS_SD_JP depending on your region, and replace MPEG_PS_PAL with MPEG_PS_NTSC of course. I have no idea about the Japanese players, but I remember from the PS3MS forum that North American BDP owners cannot use the DivX mime-type hack to play MKV and AVI content, but must instead use MPEG. So the following ought to work for North America - though they lose some of the cooler features of the player's native MKV support (subtitles, multiple selectable audio streams):
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_NTSC">MATROSKA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_NTSC">AVI</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_NTSC">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_NTSC">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_NTSC">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_NTSC">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_NTSC">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_NTSC">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_NTSC">AVC_MP4_LPCM</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_NTSC">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_NTSC">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4" name="MPEG_PS_NTSC">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
I have found a problem with .m2ts files taken directly off an unencrypted Bluray disc (well AVCHD really - I used the free x264 encoder showcase disc). The footage of the tall ship on that disc is probably the most detailed bit of H.264 I have seen. These files will play fine with PS3MS, and off USB too.
I get this in the log:
2010-10-09 21:15:47,184 WARN [VideoDeliveryEngine] Cannot resolve DLNA format profile of the original file: Big Buck Bunny.m2ts
Here's the FFMPEG info using the version included with Serviio:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "g:\video\Trailers and samples\Big Bu
ck Bunny.m2ts"
FFmpeg version SVN-r23012, Copyright (c) 2000-2010 the FFmpeg developers
  built on May  3 2010 19:05:24 with gcc 3.4.5 (mingw-vista special r3)
erver --enable-memalign-hack --enable-libmp3lame --enable-w32threads --extra-ldf
lags=-L/static/lib --extra-cflags=-I/static/include
  libavutil     50.15. 0 / 50.15. 0
  libavcodec    52.66. 0 / 52.66. 0
  libavformat   52.62. 0 / 52.62. 0
  libavdevice   52. 2. 0 / 52. 2. 0
  libswscale     0.10. 0 /  0.10. 0
[mpegts @ 00eeb970]MAX_READ_SIZE:5000000 reached
Input #0, mpegts, from 'g:\video\Trailers and samples\Big Buck Bunny.m2ts':
  Duration: 00:09:56.50, start: 599.958356, bitrate: 10613 kb/s
  Program 1
    Stream #0.0[0x1011]: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 24
fps, 24 tbr, 90k tbn, 48 tbc
    Stream #0.1[0x1100](eng): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
Any idea why this might be a problem file?
EDIT - hang on, I see it's the DTS audio which I see is also a known issue in the tracker.
patters
Post Sun Oct 10, 2010 10:48 am
I should say - I have edited the last two posts quite a lot so Zip, if you read them earlier you may need to take another look.
Transcoding MP4 container H.264 files seems by and large to work very well - the resulting MPEG2 Transport Streams allow seeking. The added bonus is that .MOV container H.264 files play back smoothly (they stutter when the player tackles them natively). However I'm getting "unsupported audio codec" for some files. This is with the transcode options set to preserve original number of channels. If I set the transcode preferences to downmix to 2 channels then I get a file corrupt error at the player.
Here are my transcode settings:
   <!-- remux MP4 container files to allow seeking (AVC_TS_MP_HD_AC3_ISO or AVC_TS_MP_SD_AC3_ISO) -->
      <Matches container="mp4" vCodec="h264"
   <!-- unsupported codecs will be transcoded into mpeg2ts, mpeg2video and ac3 audio (MPEG_TS_SD_EU). -->
      <Matches container="asf" />
I notice that I can't specify to leave the audio completely untouched like say just: <Video targetContainer="mpegts">
Is there a way?
Here's the output from FFMPEG for the problem file:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "g:\video\Ratatouille.2007.mp4"
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'g:\video\Ratatouille.2007.mp4'
    major_brand     : isom
    minor_version   : 1
  Duration: 01:50:33.41, start: 0.000000, bitrate: 1880 kb/s
    Stream #0.0(und): Video: h264, yuv420p, 1280x544 [PAR 1:1 DAR 40:17], 1675 k
    Stream #0.1(und): Audio: aac, 48000 Hz, 5.1, s16, 201 kb/s
AAC audio should transcode ok shouldn't it?
Post Mon Oct 11, 2010 10:50 am
Good job Patters!
I also use a Sony BDP-S373 Bluray-Player with my Sony Bravia EX501 TV.
For the moment, I only use my Bravia TV with DLNA Serviio, but I could check your profile with the BDP...
For testing, I suggest to use the same Samples files, for example: viewtopic.php?f=5&t=608#p3046
MKV-H264/AVC-AAC
G.I Joe Trailer- Download
Iron Man 2 Trailer - Download
ElephantsDream - Download
BigBuckBunny - Download
Sintel - Download or Trailer
MPEG2TS - MPEG2
HBO HD Sample MPEG1L2 - Download
HBO SD Sample MPEG1L2 - Download
HBO HD Sample AC3 - Download
MP4 - H264/AVC- AAC
BigBuckDanny Trailer - Download
Sintel Trailer - Download
Post Mon Oct 11, 2010 7:25 pm
OK, I suggest the following profile for BDP-S370 (European)
    <Profile id="10" name="Sony BD Player" extendsProfileId="1">
        <Detection>
            <X-AV-Client-Info>.*Blu-ray Disc Player.*</X-AV-Client-Info>
        </Detection>
        <MediaFormatProfiles>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU_T">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg"                 name="MPEG_TS_SD_EU_ISO">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU_T">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg"                 name="MPEG_TS_SD_EU_ISO">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU_T">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg"                 name="MPEG_TS_SD_EU_ISO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU_T">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg"                 name="MPEG_TS_SD_EU_ISO">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU_T">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg"                 name="MPEG_TS_SD_EU_ISO">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU_T">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg"                 name="MPEG_TS_SD_EU_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU_T">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
        </MediaFormatProfiles>
              <Matches container="mp4" vCodec="h264"/>
Modify some mime-type, added _ISO, etc...
Work fine
patters
Post Mon Oct 11, 2010 8:02 pm
You only need the _ISO types for AVC in MPEGTS container which we're forcing modifications on - the others which are MPEGPS (like DVD VOBs etc.) will be inherited from the default profile and work unmodified, which is why I left them out.
patters
Post Tue Oct 12, 2010 8:42 am
I have removed the VC-1 media types since the player chokes on them natively (ASF containers are set to transcode to MPEG2). Although the player will play non-VC-1 WMV files we cannot filter them in the transcode settings - all ASF container files are caught by that - so no point in declaring WMV at all in the device profile. I also think we need the AutoImageRotation setting. I don't have a camera to hand, but I remember it certainly autorotates images from USB so I guess it would for DLNA too. I guess we need to investigate the audio side of things now. Judging from my testing with PS3MS the BDP doesn't play much - MP3, WMA & WAV (and all of those needed forcing to mime type audio/mpeg) - everything else needed transcoding including M4A and AAC (non-DRM) which it's advertised as being able to play.
      <!-- European models -->
      <Detection>
      </Detection>
I have found another DLNA media type Serviio can't identify:
2010-10-12 08:45:09,965 WARN [VideoDeliveryEngine] Cannot resolve DLNA format profile of the original file: Sintel.mp4
File is available here. It's the full resolution MP4 with surround sound - from the torrent link.
Here's the info from FFMPEG:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "g:\video\Trailers and samples\Sintel
.mp4"
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'g:\video\Trailers and samples\Sintel.mp
4':
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
title : Sintel
encoder : Lavf52.78.5
copyright : (c) Copyright 2010 Blender Foundation, all rights reserved
description : Sintel open movie project
Duration: 00:14:48.06, start: 0.000000, bitrate: 4174 kb/s
Stream #0.0(und): Video: h264, yuv420p, 2048x872, 3727 kb/s, 24 fps, 24 tbr,
24 tbn, 48 tbc
Stream #0.1(eng): Audio: aac, 48000 Hz, 5.1, s16, 440 kb/s
Is the problem that its width is greater than 1920 pixels?
Post Tue Oct 12, 2010 6:34 pm
For me, Sintel-2048.mp4 works fine:
C:\Serviio\lib>C:\Serviio\bin\\..\lib/ffmpeg.exe -i C:\Sample\MP4\sintel-2048.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'C:\Sample\MP4\sintel-2048.mp4':
    major_brand     : isom
    minor_version   : 512
    title           : Sintel
    copyright       : (c) copyright Blender Foundation | durian.blender.org
  Duration: 00:14:48.06, start: 0.000000, bitrate: 2798 kb/s
    Stream #0.0(und): Video: h264, yuv420p, 2048x872 [PAR 1:1 DAR 256:109], 2352 kb/s, 24 fps, 24 tbr, 24 tbn, 48 tbc
Stream #0.0(und) line seems to be different to yours.
This is the debug log:
2010-10-12 20:40:33,000 DEBUG [ProcessExecutor] Starting C:\Serviio\bin\\..\lib/ffmpeg.exe -i C:\Sample\MP4\sintel-2048.mp4 -y -vcodec copy -copyts -acodec ac3 -ab 192k -vbsf h264_mp4toannexb -sn -f mpegts C:\WINDOWS\TEMP\Serviio\transcoding-temp-1071-MPEG2TS.stf
2010-10-12 20:40:33,500 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file sintel-2048.mp4: AVC_TS_MP_HD_AC3_ISO
patters
Post Tue Oct 12, 2010 9:16 pm
That's strange. I got mine from the torrent (totally legit obv.) - was yours from the direct download links?
I have been testing audio - MP3 works fine for European players (how about US?).
I can get WMA audio playing (Microsoft test clip here) by forcing mime and DLNA media type to MP3:
WAV files won't detect, even by forcing the LPCM types to MP3 in the same way (is WAV even supported by Serviio?)
FLAC files won't detect (not supported by Serviio AFAIK), though FFMPEG can ID it fine, so presumably could be made to transcode to LPCM.
thejudge
Post Wed Oct 13, 2010 9:01 pm
Does anyone know how to play FLAC files on the 370?
I assume adding some kind of transcoding header to convert the said FLAC files into LPCM?
Ive no idea how to start ( ive read the brief How to guide but im none the wiser).
Thx in advance
Post Thu Oct 14, 2010 8:49 am
thejudge wrote:Does anyone know how to play FLAC files on the 370?
I assume adding some kind of transcoding header to convert the said FLAC files into LPCM?...
With 0.4.2 Serviio version, for the moment FLAC is not supported.
Serviio can only detect aac, ac3, mp3, mp2, pcm_s16le, wmav2, dca (DTS)... Zip, do you plan this?
aeproberts
Post Thu Oct 14, 2010 7:59 pm
      <Detection>
      </Detection>
Here is the latest profile that was posted in this forum. I was wondering if one of you with the knowledge would mind converting it to US spec for me. I don't have the knowledge or skills.
patters
Post Fri Oct 15, 2010 12:21 am
Lowlander
Post Sat Oct 16, 2010 4:36 pm
Hey patters,
Thanks for the tweaked profile, seems to work pretty well. A few days ago I filed a bitbucket ticket named "Triggering transcoding on wma_pro and wmv3", which is basically to allow filtering and transcoding of non(-Sony)-compliant codecs in asf containers and leaving all basic asf stuff untouched.
Speaking of the player's abilites: I'm still looking for a suitable container format for DVD-compliant MPEG2/MP2 files with subtitles. Has anyone achieved subs on the Sony BDP with anything other than MKV (and I'm not too sure about MKV working anymore either)? VOB seems to be no option, because an occasional 4:3 aspect ratio is not detected correctly from VOBs.
Have a nice one,
Low
thejudge
Post Mon Oct 18, 2010 12:24 pm
Ive another question regarding MKV's ( 264 + dts audio).
This seems to be the offical thread for the Sony 370 so ill continue posting here.
Everything ive thrown at it so far is working like a charm - ive transcoding turned off so i get the raw data streamed and everything is perfect - almost - sometimes i do get glitches - as though the data isnt being sent quick enough.
Is this a bandwidth problem? Its usually during heavy action /sound parts ( but not always ).
I am not using wlan - only using cable so i would have thought this would be ok.
Is there something i can do or maybe something ive not done that i should have.
Super programm BTW
Post Mon Oct 18, 2010 12:33 pm
thejudge wrote:...sometimes i do get glitches - as though the data isnt being sent quick enough.
Just for information, could you press the I+ button on remote control to look the realtime bitrate during glitch?
Also, could you have a look to the Windows Task Manager, Networking Tab?
thejudge
Post Mon Oct 18, 2010 3:06 pm
will do
Users browsing this forum: Baidu [Spider] and 11 guests
