Unable to locate files
Dan_ho
Post Sun Dec 25, 2011 4:34 pm
Hi guys,
Having successfully installed servo on my Synology DS 209 with my upnp devices being able to see the servo server but I'm unable to see my files.
video files are located in "volume2/video/HD movies"
i entered volume2/video/HD movies under the library folder but it came out like this.... /volume2/homes/serviio/volume2/video/HD movies
see attached pic.
Also attached is my log file. Do advise me where i have gone wrong....been forum searching, goggling, trial and error... for hours but still unable to figure out whats the problem.
Any guidance for a linux noob?
Screen Shot 2011-12-26 at 12.21.07 AM.png (75.8 KiB) Viewed 9409 times
(57.99 KiB) Downloaded 803 times
Post Mon Dec 26, 2011 8:03 pm
Re: Unable to locate files
try to enter it as (note the leaing slash)
Post Mon Dec 26, 2011 11:30 pm
you can also try
//volume2/video/HD movies
Dan_ho
Post Thu Dec 29, 2011 2:47 am
Thanks! Got it to work...finally. Cheers!
Post Thu Dec 29, 2011 12:23 pm
what was the solution?
patters
Post Fri Dec 30, 2011 12:02 pm
Cerberus wrote:you can also try
That's not right. I think Zip's suggestion would have got it working. For some reason the OP had prepended the serviio daemon user's home directory on the folder path.
Post Fri Dec 30, 2011 1:21 pm
when looking around for howto for wiki i seen it written like that alot for external volumes, so was worth mentioning just incase it was same for his linux device. :)
