tx-p42st31b
dayo
Post Thu Dec 29, 2011 3:23 am
tx-p42st31b
i had a tx-p42gt20b panasonic tv, steamed from laptop wireless to wireless router behind tv, cable from wireless router into panasonic tv all worked great :D .
just bought a tx-p42st31b panasonic tv, no media server in the input selection list :cry: , does this mean i cant stream in the same way as before? can i upgrade the tv software, or can i stream to tv by another means? thanks in advance.
Post Thu Dec 29, 2011 4:04 am
Re: tx-p42st31b
nope should work exactly the same, but without more information on your setup i cant help much more.
dayo
Post Thu Dec 29, 2011 10:29 am
Re: tx-p42st31b
what i did before was press my AV input button, bottom item on list was media server, i would click on that and i could then see items on my laptop, but new tv hasnt got media server on the list when i press the AV input button, dont think new tv has dlna, can i set it up some other way? thanks
NX3
Post Thu Dec 29, 2011 10:58 am
Re: tx-p42st31b
If the tv has no dlna media support, check in the manual, then you'd need a media player box like a WDTV Live to add the missing functionality.
dayo
Post Thu Dec 29, 2011 11:08 am
Re: tx-p42st31b
thanks, excuse my lack of knowledge but where do i get one and how do i set it up / how does it work, thanks
NX3
Post Thu Dec 29, 2011 12:13 pm
Re: tx-p42st31b
You listed a Comet specific model of the Panasonic so I'm assuming your in the UK. Amazon.co.uk sell them as do Argos (http://www.argos.co.uk/static/Product/partNumber/9046649.htm), along with many other retailers.
They cost about £80, full product Information;
http://wdc.com/en/products/products.aspx?id=330
It connects to your tv via a HDMI cable and it can natively play most popular file formats for audio, pictures, videos. You can connect devices via USB and play them directly on the WDTV or it can stream files from your laptop, up to you how you setup your system.
You can get other media players but WDTV is pretty good, simple to use and readily available at highstreet shops.
dayo
Post Thu Dec 29, 2011 3:42 pm
Re: tx-p42st31b
thanks nx3, looks fine, yes sorry i am in the uk, gutted i cant just stream like my old tv. thanks again tho
Post Thu Dec 29, 2011 3:59 pm
Re: tx-p42st31b
Look at the back of the TV and see if there is a Cat5 connection. If there is the TV might support some kind of DLNA / UPNP.
dayo
Post Thu Dec 29, 2011 5:23 pm
Re: tx-p42st31b
hi moltra, yes it has lan port and can be set up to a network, but there isnt an option to connect to a server like my old tv, unless i am missing something
Post Thu Dec 29, 2011 5:38 pm
Re: tx-p42st31b
Using Network Services
(DLNA / VIERA CAST / freesat)
DLNA®
This TV is a DLNA Certified™ product.
DLNA (Digital Living Network Alliance) is a standard that makes DLNA Certified digital electronics easier
and more convenient to use on a home network. To learn more, visit www.dlna.org.
It allows you to share photos and videos (including 3D images) stored in the DLNA Certified media
server (for example, PC with windows 7 installed, DIGA Recorder etc.) connected to your home network,
and enjoy watching them on the TV screen.
■Applicable data format
Photo : JPEG (Sub-sampling 4:4:4, 4:2:2 or 4:2:0)
Image resolution - 8 × 8 to 30,719 × 17,279 pixels
●Motion JPEG and Progressive JPEG are not supported.
Video : MPEG2 (PS format and TS format)
Image resolution - Up to 1,920 × 1,080 pixels
FPS (Frame Per Second) - 24 / 25 / 30 fps
●PS (Program Stream) format : used for DVD recording, etc.
●TS (Transport Stream) format : used for digital broadcasts, internet, etc.
●Depending on the network environment, including lack of transfer speed, contents may not be played
back properly.
●AVCHD and DivX files are not supported by DLNA, but can be played by Media Player (p. 76).
●Music files are not supported by DLNA functions of this TV, but MP3 and AAC files can be played back by
Media Player (p. 79)
There are a few steps to get the DLNA working. I suggest following the steps in the manual linked below.
http://dlc.panasonic-europe-service.com/EUDocs/GetDoc.aspx?did=194032&fmt=PDF&lang=en&src=3
dayo
Post Thu Dec 29, 2011 7:18 pm
Re: tx-p42st31b
hi moltra, the manual is for my old tv, tx-p42st31b is the new tv, it has the lan port on the back but i cant find a media server option, i dont think it supports dlna, thanks
NX3
Post Thu Dec 29, 2011 7:31 pm
Re: tx-p42st31b
Reviews online say it doesn't have DLNA, its not in the manual, it has networking for IPTV services in VieraCast like iPlayer
dayo
Post Thu Dec 29, 2011 7:49 pm
Re: tx-p42st31b
thanks NX3, thats it then seperate player it has to be, cheers guys
Post Thu Dec 29, 2011 8:01 pm
Re: tx-p42st31b
sorry about using the wrong model number.
I am still wondering if it can work or not. I know that VIERA Connect allows netflix and other videos to be played. I would check on the viera connect screen on your TV for a video player and if there is one try it with serviio.
Post Thu Dec 29, 2011 8:11 pm
Re: tx-p42st31b
if you want seperate player your better off buying a samsung or sony Bluray player, than trying to buy something like a directv box as you will get better support and be able to play blurays :)
Return to Panasonic
