Samsung D6000 - 5.1 not working with serviio
sinjin
Post Fri Dec 30, 2011 5:05 pm
Hi, I tested my TV's surround sound system with various youtube videos and it worked perfectly. Now that I am trying to play movies streamed by serviio, I only get stereo.
Under transcoding tab, in Audio Channels I selected Keep Original, saved and restarted the server. It didn't help. Also I checked to make sure that the videos I am trying to play are 3F2R/LFE.
I've been googling for a while now, and no luck. Any ideas?
Post Fri Dec 30, 2011 5:26 pm
Re: Samsung D6000 - 5.1 not working with serviio
depends on file type if surround sound is supported, by the device.
Post Fri Dec 30, 2011 5:28 pm
post ffmpeg -i of the file
sinjin
Post Fri Dec 30, 2011 5:59 pm
Here are some of the videos that I tried playing:
nfig
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (66893/1395) -> 23.98 (66893/2790)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Street Kings.mp4':
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isom
    creation_time   : 2011-01-09 18:39:21
  Duration: 01:48:48.78, start: 0.000000, bitrate: 2893 kb/s
    Stream #0.0(und): Video: h264 (High), yuv420p, 1280x528 [PAR 1:1 DAR 80:33],
 2489 kb/s, 23.98 fps, 23.98 tbr, 66893 tbn, 47.95 tbc
      creation_time   : 2011-01-09 07:36:45
    Stream #0.1(eng): Audio: aac, 48000 Hz, 5.1, s16, 400 kb/s
      creation_time   : 2011-01-09 18:41:35
nfig
[matroska,webm @ 002d89c0] max_analyze_duration 5000000 reached at 5024000
[matroska,webm @ 002d89c0] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (200000
00/417083) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'Apes.2011.x264.BDRip.(720p).
IRONCLUB.mkv':
    title           : Rise of the Planet of the Apes (2011) - Released by IRONCL
UB
  Duration: 01:44:56.45, start: 0.000000, bitrate: 3520 kb/s
    Chapter #0.0: start 0.000000, end 324.407000
      title           : 00:00:00.000
    Chapter #0.1: start 324.407000, end 557.974000
      title           : 00:05:24.407
    Chapter #0.2: start 557.974000, end 859.067000
      title           : 00:09:17.974
    Chapter #0.3: start 859.067000, end 1087.545000
      title           : 00:14:19.067
    Chapter #0.4: start 1087.545000, end 1203.786000
      title           : 00:18:07.545
    Chapter #0.5: start 1203.786000, end 1358.148000
      title           : 00:20:03.786
    Chapter #0.6: start 1358.148000, end 1517.015000
      title           : 00:22:38.148
    Chapter #0.7: start 1517.015000, end 1782.656000
      title           : 00:25:17.015
    Chapter #0.8: start 1782.656000, end 2018.266000
      title           : 00:29:42.656
    Chapter #0.9: start 2018.266000, end 2309.098000
      title           : 00:33:38.266
    Chapter #0.10: start 2309.098000, end 2472.595000
      title           : 00:38:29.098
    Chapter #0.11: start 2472.595000, end 2719.008000
      title           : 00:41:12.595
    Chapter #0.12: start 2719.008000, end 2930.177000
      title           : 00:45:19.008
    Chapter #0.13: start 2930.177000, end 3176.632000
      title           : 00:48:50.177
    Chapter #0.14: start 3176.632000, end 3450.280000
      title           : 00:52:56.632
    Chapter #0.15: start 3450.280000, end 3566.730000
      title           : 00:57:30.280
    Chapter #0.16: start 3566.730000, end 3690.145000
      title           : 00:59:26.730
    Chapter #0.17: start 3690.145000, end 3903.608000
      title           : 01:01:30.145
    Chapter #0.18: start 3903.608000, end 3980.268000
      title           : 01:05:03.608
    Chapter #0.19: start 3980.268000, end 4174.962000
      title           : 01:06:20.268
    Chapter #0.20: start 4174.962000, end 4275.688000
      title           : 01:09:34.962
    Chapter #0.21: start 4275.688000, end 4544.123000
      title           : 01:11:15.688
    Chapter #0.22: start 4544.123000, end 4709.204000
      title           : 01:15:44.123
    Chapter #0.23: start 4709.204000, end 4989.276000
      title           : 01:18:29.204
    Chapter #0.24: start 4989.276000, end 5270.390000
      title           : 01:23:09.276
    Chapter #0.25: start 5270.390000, end 5580.366000
      title           : 01:27:50.390
    Chapter #0.26: start 5580.366000, end 5828.948000
      title           : 01:33:00.366
    Chapter #0.27: start 5828.948000, end 6296.459000
      title           : 01:37:08.948
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1280x544 [PAR 1:1 DAR 40:17],
 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) (forced)
      title           : Released by IRONCLUB
    Stream #0.1(rus): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s (default) (forced
      title           : DD 5.1 @ 448 kbps - Dub
    Stream #0.2(rus): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s
      title           : DTS 5.1 @ 1536 kbps - MVO, Omikron
    Stream #0.3(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s
    Stream #0.4(rus): Subtitle: [0][0][0][0] / 0x0000 (default) (forced)
      title           : Forced
    Stream #0.5(rus): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.6(eng): Subtitle: [0][0][0][0] / 0x0000
      title           : Forced
    Stream #0.7(eng): Subtitle: [0][0][0][0] / 0x0000
nfig
Seems stream 0 codec frame rate differs from container frame rate: 24.01 (65535/
2730) -> 24.00 (10000000/416667)
Input #0, avi, from 'Illusionist.2010.XviD.DVDRip.(HDRip).NovaLan.avi':
    encoder         : VirtualDubMod 1.5.10.2 (build 2540/release)
  Duration: 01:19:40.92, start: 0.000000, bitrate: 2454 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 720x384 [PAR 1:1 DAR 15:8], 24 tbr, 24 t
bn, 24.01 tbc
    Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Post Fri Dec 30, 2011 7:47 pm
these should play natively, so if the TV supports surround sound it should work. Do you have it connected to your receiver via optical cable?
There might also be some option in the TV's audio settings about how it should pass through audio.
sinjin
Post Fri Dec 30, 2011 8:08 pm
Yes, its connected through optical cable. I'm playing videos through samsung's smart hub. I accessed youtube videos through smarthub, and surround sound testing videos worked flawlessly. Then I accessed videos hosted on my computer, I connected to the serviio server on my computer using videos app on the smart hub, and the rear speakers aren't working.
Is it possible that the rear speakers are disabled for the video app, but enabled for the youtube app in the smarthub?
Post Fri Dec 30, 2011 8:23 pm
did quick google to confirm but it seems although Samsung say it SHOULD work, alot of owners have not managed to get the device to do 5.1 when streamed from a dlna server.
edit: after a bit more googling I found it will only work if audio is in a specific format " DD ac3 5.1 "
sinjin
Post Fri Dec 30, 2011 8:41 pm
I tried running more videos and they appeared to work with the rear speakers. (Meaning the settings in the TV are set just fine!) Which is good, but I really want the other videos to work as well.
Any ideas on how to fix the problem?
Post Fri Dec 30, 2011 8:45 pm
please provide detail on file that works then maybe we can sort it out :)
but i have a feeling manually remuxing the file might need to be done.
sinjin
Post Fri Dec 30, 2011 8:55 pm
Actually it seems like the files that worked were Stereo... (yet the rear speakers worked --which still proofs that they are enabled in the TV settings?) Here are the two files:
nfig
bn, 24.01 tbc
nfig
Seems stream 0 codec frame rate differs from container frame rate: 29.98 (65535/
2186) -> 29.97 (10000000/333667)
Input #0, avi, from 'D:\DOWNLOADS\Ed.Vud.1994.XviD.DVDRip.blondealex.avi':
    encoder         : VirtualDubMod 1.5.4.1 (build 2178/release)
  Duration: 02:06:34.26, start: 0.000000, bitrate: 1635 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 704x368 [PAR 1:1 DAR 44:23], 29.97 tbr,
29.97 tbn, 29.98 tbc
    Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
sinjin
Post Sat Dec 31, 2011 2:33 am
This video is 6 channels and it worked with all speakers:
nfig
[matroska,webm @ 013b8c00] max_analyze_duration 5000000 reached at 5002000
[matroska,webm @ 013b8c00] Estimating duration from bitrate, this may be inaccur
ate
Input #0, matroska,webm, from '300.2006.720p.BluRay.DTS.x264-ESiR.mkv':
    title           : 300.2006.720p.BluRay.DTS.x264-ESiR
  Duration: 01:56:32.57, start: 0.000000, bitrate: 1536 kb/s
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1280x536, PAR 1:1 DAR 160:67,
      title           : 300
    Stream #0.1(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s (default)
      title           : DTS @ 1.5 Mbit
    Stream #0.2(eng): Subtitle: ass (default)
    Stream #0.3(rum): Subtitle: ass
    Stream #0.4(swe): Subtitle: ass
    Stream #0.5(fin): Subtitle: ass
    Stream #0.6(dan): Subtitle: ass
    Stream #0.7(dut): Subtitle: ass
    Stream #0.8(ger): Subtitle: ass
    Stream #0.9(fre): Subtitle: ass
    Stream #0.10(spa): Subtitle: ass
    Stream #0.11(por): Subtitle: ass
    Stream #0.12(pol): Subtitle: ass
    Stream #0.13(cze): Subtitle: ass
    Stream #0.14(hun): Subtitle: ass
    Stream #0.15(scr): Subtitle: ass
    Stream #0.16(slv): Subtitle: ass
    Stream #0.17(gre): Subtitle: ass
    Stream #0.18(heb): Subtitle: ass
    Stream #0.19: Attachment: [0][0][0][0] / 0x0000
      filename        : CronosPro-Bold.ttf
    Stream #0.20: Attachment: [0][0][0][0] / 0x0000
      filename        : CronosPro-Semibold.ttf
    Stream #0.21: Attachment: [0][0][0][0] / 0x0000
      filename        : CronosPro-SemiboldIt.ttf
    Stream #0.22: Attachment: [0][0][0][0] / 0x0000
      filename        : times.ttf
    Stream #0.23: Attachment: [0][0][0][0] / 0x0000
      filename        : timesbd.ttf
urielbrent7
Post Thu Jul 16, 2015 7:56 am
Hi, can you tell me how/what settings did you do to get 5.1 Surround from your D6000 please. I appreciate it.
Users browsing this forum: Baidu [Spider] and 24 guests
