YouTube
Re: YouTube
sonc44: What's the technique to find the playlist ID 1C90BDF46E6EACFD ?
Re: YouTube
Also with the playlist in the order oldest first, you only get the first episodes in the feed, instead of the latest.
Re: YouTube
I click on the Playlist itself and then copy the URL in the address bar of the browser.
In the playlist link/URL just remove the PL from the ID code and I believe that leaves a 16 character code for the playlist to use for the API get URL.
Example one of my playlist links is http://www.youtube.com/playlist?list=PL ... ature=plcp
the code between ( playlist?list=) and (&feature=plcp) is PL7C69431AD9AD5FFF.
Remove the PL from this and there is the Playlist ID to use.
Re: YouTube
Is there any way to forward/rewind youtube video when I am streaming to an Xbox 360? I have read through the forums but am unable to find anything about it. I am able to play feeds from youtube, but none of them forward or rewind. I am using the default profile for the Xbox.
Re: YouTube
My first time trying to add a feed. I added Youtube.groovy to C:\Program Files\Serviio\plugins
Added http://gdata.youtube.com/feeds/api/user ... be-profile which is a sample listed earlier in the thread and another feed that I made.
I also added them to my google reader and they work there, but it's nothing is showing up on serviio using a sony smp-n100. I restarted serviio.
The log says. I shut down serviio. Log readStill nothing after second restart. Is it just supposed to show up when I select the serviio icon on the screen? I see nothing new there.
The log says.
- Code:
2011-12-29 12:21:05,953 INFO [PluginCompilerThread] Added plugin YouTubeUrlExctractor (Youtube.groovy)
2011-12-29 12:21:30,015 INFO [FeedUpdaterThread] Started looking for information about online feeds
2011-12-29 12:21:30,031 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-12-29 12:21:30,046 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-12-29 12:21:33,625 INFO [ServiioConsole] Starting Serviio Console
Re: YouTube
Open that link in your web browser, nothing.....so serviio isn't going to show anything either.
Try this one, I know it works;
https://gdata.youtube.com/feeds/api/use ... ow/uploads
Then in serviio video menu go to your 'online' section
Re: YouTube
Hey,
First of all thanks for this useful script, worked wonderfully out of the box.
That said, please note that I'm quite noobish with serviio and this is my first post so go easy on me if I missed answer somewhere else on forum
Anyhow...
If I add following feeds to my online feeds list:
I get three entries on my TV (Samsung LE32C550) all titled but I only get the items from the first one in the list displayed when I enter the feed.
So if the trailers are the first in the list, entering any of the tree displayed folders will always display the entry from the first one.
I have few more feeds defined, and it appears that if the title is different, than the content is displayed correctly.
Is the title generated by the serviio itself or by the script?
Thanks in advance!
Anyhow...
Thanks in advance!
Re: YouTube
NX3 wrote:Open that link in your web browser, nothing.....so serviio isn't going to show anything either.
At any rate, I did figure it out kind of. In "Presentation", the on line was disabled
I can get https://gdata.youtube.com/feeds/api/use ... ow/uploads to work and I can get favorites to work, but I have been going nuts trying to get playlists to work. No matter what I have tried, I can't get any playlist to work. It says "There is no playable file". I would like to get the list from http://www.youtube.com/user/jctoad/#g/p on serviio. I can't get http://gdata.youtube.com/feeds/api/user ... B2EBD79963 to work even. I thought I was home free after I found that online was disabled, but now it's about 2 hours later and I'm getting nowhere fast.
Re: YouTube
mykee wrote:What I set:
- open firewall to TCP: 8895 and UDP to 1900 (but router is UPnP and set this mode)
- set resolution to High
- leave only this link on online feeds list and set to video type:
- max number of feed items to 20
- feed expiry interval to 6 hours.
I see in log now this:
- Code:
WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtsp://v5.cache7.c.youtube.com/CigLENy73wIaHwlrH3cG-Dp9lhMYESARFEgGUgx1c2VyX3VwbG9hZHMM/0/0/0/video.3gp. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:188)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:93)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:318)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:68)
at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:169)
My profile for Samsung TV:
- Code:
<Profile id="21" name="Mykee Samsung TV" extendsProfileId="1">
<Detection>
<UPnPSearch>
<FriendlyName>(^TV-\d{2}C\d{3}.*)|(^\[TV\][A-Z]{2}\d{2}D\d{3}.*)</FriendlyName>
<ModelNumber>(1\.0)|(AllShare1\.0)</ModelNumber>
</UPnPSearch>
</Detection>
<DeviceDescription>
<ExtraElements>
<sec:ProductCap>smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec</sec:ProductCap>
<sec:X_ProductCap>smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec</sec:X_ProductCap>
</ExtraElements>
</DeviceDescription>
<ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.SamsungContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192" maxVBitrate="8192" forceVTranscoding="true">
<Matches container="asf" />
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" maxVBitrate="8192">
<Matches container="flv" />
<!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192">
<Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.2" />
<Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.2" />
<Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.2" />
<Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.2" />
<!-- transcode H264 MP4 files with LPCM audio -->
<Matches container="mpegts" aCodec="mp2" />
<Matches container="mp4" aCodec="lpcm" />
<Matches container="matroska" vCodec="vc1" />
<Matches container="ogg" vCodec="mpeg4" />
<Matches container="3gp" aCodec="amrnb" />
<!-- transcode MKV with MPEG2 video, remux into mpeg2ts -->
<!-- transcode AVI with AVC video -->
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
<Matches container="ogg" />
<Matches container="mpegts" vCodec="mpeg2video" />
<!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems-->
<Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true" maxVBitrate="8192">
<Matches container="asf" vCodec="mpeg2video" />
<Matches container="wtv" />
<!-- transcode audio only for wmv with wmapro -->
<Video targetContainer="asf" targetACodec="ac3" aBitrate="256" >
<Matches container="asf" aCodec="wmapro" />
<Matches container="mp4" />
<Matches container="flac" />
</Audio>
this profile works pefect for me when i'm playing youtube HD videos, but when i try to play HD file from my computer (i have to say that this work perfect on Samsung C/D profile), i got message ''video codec not supported''.
So can someone help me to make profile that merge Samsung C/D profile and Mykee profile?
Re: YouTube
jctube: Correct form is http://gdata.youtube.com/feeds/api/playlists/8B39E1B2EBD79963?v=2
See posts above.
See posts above.
Re: YouTube
matehr :
It looks to me like you are not using the YouTube plugin, and the feed is being processed in raw form that will create this error.
You also need to use the Samsung C/D profile, and post any problems you encounter with it so they can be fixed rather than create a new profile that no one else will want to debug to fix problems that have already been fixed in the C/D profile.
Re: YouTube
jhb50 wrote:matehr :
I second that.
Re: YouTube
I'm using Youtube plugin.
If it's that so, why i can't watch youtube on Samsung C/D profile in FullHD format, but on this custom profile or Samsung B profile works perfect?
My problem with Samsung C/D profile is that i can't watch youtube in FullHD (it work on medium or low quality, and on high quality i get message ''video codec not supported''), and all files from my computer work perfect (720p, 1080p).
On this custom Mykee profile or Samsung B profile i can watch Youtube files on High settings and FullHD, but files from my computerr in 720p or 1080p won't work, and got message ''video codec not supported''.
Can you explain me this?
Now i want to edit Samsung C/D profile to play files both from my comp and Youtube.
Re: YouTube
jhb50 wrote:jctube: Correct form is http://gdata.youtube.com/feeds/api/playlists/8B39E1B2EBD79963?v=2
See posts above.
Not only do I have this playlist problem but there are other things that don't seem right about the box or at least how it uses youtube data.
1) No option to disable auto shutdown. viewtopic.php?f=11&t=4487
2) I also discovered a problem with youtube subscriptions. A user that I subscribe to may have 48 uploads, however, my Sony may say they only have 42. Some users it gets the number correct, others it gets wrong.
3) In the list of all subscriptions, it will always say that every user has 0 uploads, which is certainly not true.
Does anyone else see these types of errors or am I just special?
Update: I loaded some other playlists into serviio.
A list of 8 files. Only showed 6 when viewed directly by the box. Worked perfect when view via Online feed.
A list of 19 files. Worked perfect when viewed directly by the box. Was missing part 3 and parts 10-19 when viewed through Online Feed.
What the heck is going on?
Re: YouTube
matehr wrote:I'm using Youtube plugin.
b series profile transcodes alot more than it needs to that why it works,
Re: YouTube
I know that, and i know why.
it's because Samsung B profile is extended version of deafult generic dlna profile, and Samsung C/D profile is extended version of B profile.
Re: YouTube
matehr:
Go back and read the mykee posts above which report the same problem and his fix. You are using an old plugin.
Re: YouTube
jctoad:
I can only tell you that all five files are added correctly using the C/D profile for my Samsung, and all 5 files seem to be the same spec so I would expect yours to show all 5 as well.
WRT channels, Serviio can not support requests of the form http://gdata.youtube.com/feeds/api/users/jctoad/playlists?v=2http://gdata.youtube.com/feeds/api/users/jctoad/playlists?v=2 since the returned result is a list of playlist feeds of the form http://gdata.youtube.com/feeds/api/playlists/8B39E1B2EBD79963?v=2
which are supported but each must be added separately.
Re: YouTube
jhb50 wrote:jctoad:
