Toshiba 32SL415U - Media Player playing 2nd audio track
renton98058
Post Thu Dec 29, 2011 4:57 am
I have my DVD's Main Movies ripped to disk. I have installed Serviio on a Win7 PC, I have no issue connecting to the Serviio server on my PC, what I do get is the movies accessing the 2nd audio tracks on the movies and I can't find a way to change that. I'm not a coder or script builder so the scripting makes little sense to me here. Is there a way to specify which audio track is played or streamed to the TV? I am using VOB files. The VOBs also show up individually rather then as a complete Movie, any way to have one movie listing?
I'm new, just a user looking for a solution.
Thanks from Washington State
Post Thu Dec 29, 2011 5:18 am
Re: Toshiba 32SL415U - Media Player playing 2nd audio track
please provide some information on the files. see howto information below.
http://wiki.serviio.org/doku.php?id=file_np and http://wiki.serviio.org/doku.php?id=mediainfo
renton98058
Post Sun Jan 01, 2012 12:26 am
C:\Program Files\Serviio\lib>ffmpeg.exe -i "i:\dvds\mainmovie\21\video_ts\vts_01
_1.vob"
nfig
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 6. 0 / 53. 6. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 25. 0 / 2. 25. 0
libswscale 2. 0. 0 / 2. 0. 0
[mpeg @ 01288ae0] max_analyze_duration 5000000 reached at 5004667
I re-reipped the offending files and removed the director's cut sound tracks. What I'm not crazy about is having all the VTS_01_x.vob files show up to select from, any resolution. Also any hints on setting for the Toshiba 32SL415U TV?
Seems stream 0 codec frame rate differs from container frame rate: 59.94 (60000/
1001) -> 59.94 (60000/1001)
Input #0, mpeg, from 'i:\dvds\mainmovie\21\video_ts\vts_01_1.vob':
Duration: 00:22:16.68, start: 68.019600, bitrate: 6426 kb/s
Stream #0.0[0x1e0]: Video: mpeg2video (Main), yuv420p, 720x480 [PAR 32:27 DA
R 16:9], 9800 kb/s, 23.98 fps, 59.94 tbr, 90k tbn, 59.94 tbc
Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Stream #0.2[0x81]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Stream #0.3[0x82]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Stream #0.4[0x83]: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
Stream #0.5[0x20]: Subtitle: dvdsub
Stream #0.6[0x22]: Subtitle: dvdsub
Post Sun Jan 01, 2012 7:36 am
renton98058 wrote:I re-reipped the offending files and removed the director's cut sound tracks. What I'm not crazy about is having all the VTS_01_x.vob files show up to select from, any resolution.
merge them into an mkv or mp4 file, then add them to library.
Return to Toshiba
