PS3 - Media Server Error
cultan
Post Sun Jan 01, 2012 7:44 pm
Upgraded to latest version of Serviio and now using PS3. All MKV files will not play. All but one gives me a Media Server Error. Log file shows problem with ffmpeg. I've read through posts but still confused as to how to resolve this problem. Log file and details of one of files attacched. I have confimred that Playstation 3 profile being used. Files from DVD folder Video TS will play but none of MKV.
(12.82 KiB) Downloaded 594 times
MI3.txt
(4.16 KiB) Downloaded 605 times
Post Mon Jan 02, 2012 3:55 pm
Re: PS3 - Media Server Error
what OS are you running on your server? Ubuntu/linux? if yes try this
http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux
cultan
Post Wed Jan 04, 2012 11:41 pm
I am running Vista Home Premium 64 Bit with SP2
cultan
Post Thu Jan 05, 2012 1:59 am
Results of ffmgeg -1 as follows:
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i
nfig
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 6. 0 / 53. 6. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 25. 0 / 2. 25. 0
libswscale 2. 0. 0 / 2. 0. 0
ffmpeg.exe: missing argument for option 'i'
For specific file example details as follows:
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "m:\myfile.mkv"
nfig
[matroska,webm @ 0184dc80] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 180000.00 (18
0000/1) -> 59.94 (60000/1001)
Input #0, matroska,webm, from 'm:\myfile.mkv':
Duration: 02:05:23.90, start: 0.000000, bitrate: 448 kb/s
Chapter #0.0: start 0.000000, end 242.408833
title : Chapter 1
Chapter #0.1: start 242.408833, end 777.827044
title : Chapter 2
Chapter #0.2: start 777.827044, end 1278.076800
title : Chapter 3
Chapter #0.3: start 1278.076800, end 1592.257333
title : Chapter 4
Chapter #0.4: start 1592.257333, end 1976.474500
title : Chapter 5
Chapter #0.5: start 1976.474500, end 2370.501467
title : Chapter 6
Chapter #0.6: start 2370.501467, end 2816.446967
title : Chapter 7
Chapter #0.7: start 2816.446967, end 3104.301200
title : Chapter 8
Chapter #0.8: start 3104.301200, end 3454.884767
title : Chapter 9
Chapter #0.9: start 3454.884767, end 3728.991933
title : Chapter 10
Chapter #0.10: start 3728.991933, end 4146.671411
title : Chapter 11
Chapter #0.11: start 4146.671411, end 4699.256778
title : Chapter 12
Chapter #0.12: start 4699.256778, end 5011.401944
title : Chapter 13
Chapter #0.13: start 5011.401944, end 5255.112078
title : Chapter 14
Chapter #0.14: start 5255.112078, end 5648.037944
title : Chapter 15
Chapter #0.15: start 5648.037944, end 6163.486211
title : Chapter 16
Chapter #0.16: start 6163.486211, end 6670.859744
title : Chapter 17
Chapter #0.17: start 6670.859744, end 7047.869711
title : Chapter 18
Chapter #0.18: start 7047.869711, end 7523.903500
title : Chapter 19
Stream #0.0(eng): Video: h264 (Main), yuv420p, 720x480 [PAR 8:9 DAR 4:3], 23
.98 fps, 59.94 tbr, 1k tbn, 180k tbc (default)
Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s (default)
Media Info as folows:
eneral
Unique ID : 197746835655502000373733553145226292440 (0x94C4A7BC7A0509DFDC9EF9C7E7C96CD8)
Complete name : M:\myfile.mkv
Format : Matroska
Format version : Version 2
File size : 1.73 GiB
Duration : 2h 5mn
Overall bit rate : 1 974 Kbps
Writing application : HandBrake 0.9.5
Writing library : libmkv 0.6.4.1
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 5mn
Bit rate : 1 487 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 23.976 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.179
Stream size : 1.30 GiB (75%)
Writing library : x264 core 112
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=2 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=0 / open_gop=0 / weightp=0 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=none
Language : English
Default : Yes
Forced : No
Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 2h 5mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 402 MiB (23%)
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : Chapter 1
00:04:02.408 : Chapter 2
00:12:57.827 : Chapter 3
00:21:18.076 : Chapter 4
00:26:32.257 : Chapter 5
00:32:56.474 : Chapter 6
00:39:30.501 : Chapter 7
00:46:56.446 : Chapter 8
00:51:44.301 : Chapter 9
00:57:34.884 : Chapter 10
01:02:08.991 : Chapter 11
01:09:06.671 : Chapter 12
01:18:19.256 : Chapter 13
01:23:31.401 : Chapter 14
01:27:35.112 : Chapter 15
01:34:08.037 : Chapter 16
01:42:43.486 : Chapter 17
01:51:10.859 : Chapter 18
01:57:27.869 : Chapter 19
Any thoughts on Media Server Error - A Network Error Has Occured (00000000) ??
NX3
Post Thu Jan 05, 2012 8:27 am
You might want to edit out the file name, pretty sure you can't own that film in a legit way anywhere yet and this forum / Serviio doesn't really want to get involved in anything illegal.
cultan
Post Thu Jan 05, 2012 10:40 pm
Previous post correctecd.
Post Thu Jan 05, 2012 10:44 pm
NX3 wrote:You might want to edit out the file name, pretty sure you can't own that film in a legit way anywhere yet and this forum / Serviio doesn't really want to get involved in anything illegal.
no one cares about that unless it was a porn name, you can call a file anything u want
