.ISO -support?
Tormio
Post Thu Mar 24, 2011 5:38 pm
.ISO -support?
Hi. Thanks for a great program.
Could you please add support for .ISO -files if it's possible to do... ?
Tarkin
Post Mon Mar 28, 2011 11:24 am
Re: .ISO -support?
I will second that request.
Right now, ISO support is the only thing which keeps me using XBMC in addtion to Serviio-supported DLNA playback.
Post Mon Mar 28, 2011 11:52 am
Re: .ISO -support?
TheNemic
Post Sat Apr 09, 2011 11:23 pm
Re: .ISO -support?
Yes ISO file support would be very nice :)
| Samsung UE40D5005 LED | DreamBox 800HD se | Windows 7 | Synology DS1515+ NAS |
Post Sun Apr 10, 2011 1:48 am
Re: .ISO -support?
TheNemic wrote:Yes ISO file support would be very nice :)
There is no Status or ETA on this being added to serviio, so i doubt it will be added untill atleast 0.7 but ZIP will correct me if he has plans to add this sooner or not at all
AeroSC
Post Mon Nov 07, 2011 7:12 pm
Re: .ISO -support?
I vote for adding ISO support as well. If I had that and keeping the server from hibernating the computer, I'd never look at another DLNA server. Serviio would do everything I need.
joelkaberg
Post Tue Nov 08, 2011 8:57 pm
Re: .ISO -support?
AeroSC wrote:I vote for adding ISO support as well. If I had that and keeping the server from hibernating the computer, I'd never look at another DLNA server. Serviio would do everything I need.
You can stop the computer from hibernating yourself via windows settings, http://lmgtfy.com/?q=stop+windows+compu ... ibernating
JohninLA
Post Wed Nov 09, 2011 4:14 pm
Re: .ISO -support?
Another vote for iso support!
Thank you for a great server!
laz305
Post Sun Nov 13, 2011 10:28 am
Re: .ISO -support?
bobbygee
Post Sun Nov 13, 2011 4:22 pm
Re: .ISO -support?
vidserve
Post Tue Dec 13, 2011 6:53 am
Re: .ISO -support?
and another, howerver, I'm not holding my breath because .ISO is not supported in the DLNA speciofication.
Post Tue Dec 13, 2011 9:24 pm
Re: .ISO -support?
features are NOT added based on votes they are based on ZIP (if he wants to add tehm he will ) so keep posting will just annoy the moderators and helpers who have to keep reading a post they have already delt with.
Post Wed Dec 14, 2011 10:11 am
Re: .ISO -support?
Not tested, but should have a look at this tool
http://loopy.sourceforge.net/
rosario.f
Post Mon Jan 02, 2012 10:01 pm
Re: .ISO -support?
Another vote for iso support! :D
eclp
Post Tue Jan 03, 2012 10:15 pm
Re: .ISO -support?
Oh yes, ISO support would be great!
bandid
Post Tue Aug 05, 2014 9:05 pm
Re: .ISO -support?
Any update on .ISO support?
Regards
Davide
Post Wed Aug 06, 2014 6:14 pm
Re: .ISO -support?
centralware
Post Thu Aug 14, 2014 8:57 am
Re: .ISO -support?
@ZIP This should be a relatively simple process (adding ISO container support)
1) mount the selected ISO file (mount -o loop /path/to/file.iso /mnt/iso/ClientID/file.iso.tmp)
2) read the VTS directory and locate what seems to be the largest set of concurrent VOB files (likely main movie - the other option would be to actually add support to read the info files, etc. but this would be a good "first step")
3) stream the VOB(s) accordingly, using the list of VOBs found as a playlist to play one right after the other.
4) once playback ends (or is ended) dismount the ISO (and likely a maintenance script for mishaps to clean up the mounts)
5) in the interface, also look for filename.iso.jpg (or similar) for thumbnails to be displayed (just a nice feature)
Later, if/when you have the desire to do so, then get into reading the IFO files and support menus and the likes if deemed prudent.
Hope this helps with the public's requests!
~TJ~
Wixie
Post Thu Aug 14, 2014 6:16 pm
Re: .ISO -support?
Well that does not make much sense.
ISO files are images of disks. There are better formats for storing movies on a harddrive.
So why choose ISO when you are not going to burn them?
In my opinion ISO files becaming more and more obsolete.
Thats too complicated. What about multi angle? What about seamless branching disk? That doesnt work without progressing the whole DVD/Bluray structure
There are just streams inside a VOB file. The language info etc is stored inside the ifo.
IMO ressources shouldnt be wasted for that "feature"
I dont get it. Why using ISO files? The support is more than bad. Most players cant handle them. Go for MKV/MP4
rottenmutt
Post Mon Oct 13, 2014 5:43 pm
Re: .ISO -support?
Return to Feature requests
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 6 guests
