Panasonic BDT210
Post Wed Jan 04, 2012 9:21 am
Re: Panasonic BDT210
Informations added to wiki : http://wiki.serviio.org/doku.php?id=dev ... #panasonic
Do you try with "Generic Profile" ?
This device may support :
- MPEGTS / H264 / LPCM
- MPEGTS / H264 / AC3
- MPEGTS / MPEG2VIDEO / AC3
- MPEGPS / MPEG2VIDEO / AC3
- JPEG
- probably MP4 / H264 / AAC (mp4,mov)
nothing about audio ?? (MP3,etc)
Post Wed Jan 04, 2012 9:29 am
wouldnt supprise me illico panasonic some to have very bad dlna support, thanks for adding to wiki :)
PMI
Post Wed Jan 04, 2012 8:58 pm
Illico wrote:Informations added to wiki : http://wiki.serviio.org/doku.php?id=dev ... #panasonic
- JPEG
Using the "Generic DLNA" profile, no videos play at all. (v 1.70 of the firmware)
Using the Panasonic Viera Profile some videos play, some do not, but not as well as on the TC-L32E3 I have connected to the same server.
Assuming the software is the same as the BDT310, there is information online about what formats are supported through DLNA, but I can pretty much confirm that the Panasonic Viera Profile will NOT work as is. If anyone has a specific question about what to test, I will try. The BDT210 is pretty much plug-and-play with WMP 12, but restricted to formats which are supported by Microsoft.
Not sure what to say about Audio, MP3s play, folders look about right, playlists work... artist and other info looks right. There is no support for album art. A lot of the features are not documented, the manual just tells you how to configure it to use with Microsoft WMP.
Peter
Post Wed Jan 04, 2012 9:58 pm
- JPEG
there not teh same sink report show that BDT has very limited support.
i didnt expect it to work right off the bat as BD and TVs alway seem to have different support.
if you can provide some information on what does and doesnt play with viera profile that would be helpful though.
PMI
Post Thu Jan 05, 2012 1:58 am
Cerberus wrote:if you can provide some information on what does and doesnt play with viera profile that would be helpful though.
AVI files (1024x768 orig. resolution) play, but distorted (stretched horizontally). WMV files (720x480, orig. from Windows Live, I think) play. MKV files do not play, not sure why, that is supposed to be one of the supported formats. WTV files recorded in WMC play after I added them to list to be transcoded to MPEG-TS for my Viera TV.
When using WMP 12, all video fie formats that Media player supports play, but I do not know what WMP does with them to get them to play. The functions for play, pause, stop, resume, fwd, rev, work in WMP 12. In Servio, play, pause, and stop work, resume works sometimes, fwd and rev stop play, but most of the time do not work after that. Pressing pause or stop sometimes leads to not being able to connect with Serviio.
That is all I remember, without running new tests.
Peter
Post Thu Jan 05, 2012 2:33 am
and we go back to talking about WMP12, im at point of giving up here, cause i really dont care what WMP12 can or cant do weare talking about serviio.
http://wiki.serviio.org/doku.php?id=file_np - i need exact details on the files.
PMI
Post Thu Jan 05, 2012 4:26 am
Cerberus wrote:http://wiki.serviio.org/doku.php?id=file_np - i need exact details on the files.
testfile3wmv.txt
(1.35 KiB) Downloaded 1403 times
testfile2mkv.txt
(1.2 KiB) Downloaded 1365 times
testfile1avi.txt
(1.06 KiB) Downloaded 1340 times
Peter
PMI
Post Thu Jan 05, 2012 4:31 am
Those are some samples for file types I mentioned above.
AVI file: plays but distorted
WMV file: plays
MKV files: do not play
WTV files: play
testfile5wtv.txt
(3.84 KiB) Downloaded 1300 times
testfile4mkv.txt
(1.22 KiB) Downloaded 1271 times
Peter
Post Thu Jan 05, 2012 4:47 am
ok that great have run out of time now but will look at building a starter profile for this tonight, but more files you can give me with exact info on if they okay or not an what error is given (video codec not supported/ audio codec not supported).
Post Thu Jan 05, 2012 6:36 am
OK try this profile,(add it to bottom of profiles file DONT replace viera one) i think this should now work. ZIP and illico will jump in if i have made big mistake in there tho
   <Profile id="21" name="Panasonic BD Player" extendsProfileId="1">
      <MediaFormatProfiles>
      </MediaFormatProfiles>
          <!-- remux DTS/FLAC/LPCM/AAC in MKV/MP4 to AC3 -->
            <!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2video and ac3 audio -->
            <Matches container="avi" />
            <Matches container="asf" />
            <Matches container="flv" />
            <Matches container="ogg" />
            <Matches container="3gp" />
            <Matches container="wtv" />
            <Audio targetContainer="mp3">
            <Matches container="mp4" />
            <Matches container="flac" />
         </Audio>
PMI
Post Thu Jan 05, 2012 6:52 am
One short 1024x768 video, original in AVI format, converted to MP4 and to MKV for testing.
First tested with Panasonic Viera profile, on Viera TV, TC-L32E3: all three files play
Then tested with same Panasonic Viera Profile, on BDT210: AVI file plays, but distorted (horiz stretch), MP4 and MKV do not, player says "Cannot play."
testfile32mkv.txt
(1.18 KiB) Downloaded 1239 times
testfile31mp4.txt
(1.43 KiB) Downloaded 1264 times
testfile30avi.txt
(1.04 KiB) Downloaded 1224 times
Peter
Post Thu Jan 05, 2012 7:59 am
did you try the profile is just posted ? not much I can do about aspect ratio I dont think but will see.
EDIT: yer nothing i can do about aspect ratio at the current time but there is open bit bucket ticket to try and fix it
Post Thu Jan 05, 2012 8:52 am
PMI wrote:on BDT210: AVI file plays, but distorted (horiz stretch)
A workaround, try this : viewtopic.php?f=11&t=2956&start=30#p27617
PMI
Post Thu Jan 05, 2012 2:23 pm
Cerberus wrote:did you try the profile is just posted ? not much I can do about aspect ratio I dont think but will see.
Ran out of time last night, so my last post was with the same old profile. Will try in a few hours, thanks.
Peter
Post Thu Jan 05, 2012 5:14 pm
awesome illico thanks :)
PMI
Post Thu Jan 05, 2012 5:58 pm
Loaded and running. No obvious change compared to the Panasonic Viera Profile, but I did not have a chance to do much with it.
Anything specific I should be looking for?
Peter
Post Thu Jan 05, 2012 6:00 pm
yer hopefully Mkv and Avi now play, make sure you restart serviio after adding the profile and that u select it in console.
PMI
Post Thu Jan 05, 2012 7:30 pm
Cerberus wrote:yer hopefully Mkv and Avi now play, make sure you restart serviio after adding the profile and that u select it in console.
Done that, selected the new profile, its name shows up next to the player name, restarted W7, but AFAIK, there is no chg in what plays and what does not.
Only tested 2 AVIs, they play the same, distorted (yes, I know you can't do anything about that).
Tested all MKVs in my test directory (5 or 6), and none of them play.
No change from when I posted the text files generated by ffmpg.
Peter
Post Thu Jan 05, 2012 7:44 pm
yer distorded -use the fix from illico
hmm no mkv thats annoying, try this changing the MKV this line
MP4/WTV and WMV - all of these work im guessing ?
FFmpeg readout wont change.
PMI
Post Thu Jan 05, 2012 8:51 pm
Cerberus wrote:yer distorded -use the fix from illico
I will try the fix later, IF I can figure it out.
I will work on the MKV next.
No. They do not all work.
All WMV work.
Most WTV work (I have not investigated what the ones work have in common).
No MP4 work.
edit:
So, I will have this profile now:
Pan_BDT210_profile.txt
(1.48 KiB) Downloaded 1246 times
Peter
Return to Panasonic
