Re: MKV files stutter.
Edit: Yup, iFlicks remuxed files work perfectly. What's the process Serviio uses for .mkv files?
zotune wrote:Updated list:
Serviio (OSX Client) to Samsung TV = Stuttering playback
Serviio (OSX Client) to Xbox 360 = Stuttering playback
TVMOBiLi (OSX Client) to Samsung TV = Stuttering playback
Serviio (Windows Client) to Samsung TV = Appears to work fine
sage: java [-options] class [args...]
(to execute a class)
or java [-options] -jar jarfile [args...]
(to execute a jar file)
where options include:
-d32 use a 32-bit data model if available
-d64 use a 64-bit data model if available (implies -server, only for x86_64)
-client to select the "client" VM
-server to select the "server" VM
-jvm is a synonym for the "client" VM [deprecated]
-hotspot is a synonym for the "client" VM [deprecated]
The default VM is client.
-cp <class search path of directories and zip/jar files>
-classpath <class search path of directories and zip/jar files>
A : separated list of directories, JAR archives,
and ZIP archives to search for class files.
-D<name>=<value>
set a system property
-verbose[:class|gc|jni]
enable verbose output
-version print product version and exit
-version:<value>
require the specified version to run
-showversion print product version and continue
-jre-restrict-search | -jre-no-restrict-search
include/exclude user private JREs in the version search
-? -help print this help message
-X print help on non-standard options
-ea[:<packagename>...|:<classname>]
-enableassertions[:<packagename>...|:<classname>]
enable assertions
-da[:<packagename>...|:<classname>]
-disableassertions[:<packagename>...|:<classname>]
disable assertions
-esa | -enablesystemassertions
enable system assertions
-dsa | -disablesystemassertions
disable system assertions
-agentlib:<libname>[=<options>]
load native agent library <libname>, e.g. -agentlib:hprof
see also, -agentlib:jdwp=help and -agentlib:hprof=help
-agentpath:<pathname>[=<options>]
load native agent library by full pathname
-javaagent:<jarpath>[=<options>]
load Java programming language agent, see java.lang.instrument
-splash:<imagepath>
show splash screen with specified image
sunnyday wrote:Very good question indeed!
h264/x264 streams packed into mkv seems prone to stutter when streamed to many (but not all) C- and D- series TV sets.
Meanwhile, the same streams packed into MP4 and MPEG-TS seem to play smoothly, regardless of bitrate.
I read at a different forum that some containers are hardware decoded inside TV, whereas other containers such as mkv are software decoded.
That would explain differences but not why it works better/worse on different media servers/different OS..
Cerberus wrote:sunnyday wrote:Very good question indeed!
not true. I have plenty of high quality Mkv files that have absolutely no stuttering,
sunnyday wrote:Really strange...for me the stuttering problem appears a little bit "reversed" compared to zotune:
Serviio (Windows 64bit) to Samsung TV = Stuttering playback for most mkv:s, all other containers work fine
TVMOBiLi (Windows 64bit) to Samsung TV = Appears to work fine
boink wrote:If it's a bad file all my mkv files must be bad, because i have stutter in all 6 movies i have testet with Serviio. Theese movies all run fine on a WD TV live and as mentioned before with TVMOBiLi as media server.
I would prefer to use Serviio because of a fine interface and great subtitle support.
As far as I know Samsung UE32D5005 is their low end model with the 'All Share' feature and have a different CPU than their high end models. Perhaps it's the reason. Please notice Sunnyday had the same problem with his D5005XXE TV and Serviio.
I dont know a place to upload, but I will try to find out a solution in the weekend, if you think it could help.
Users browsing this forum: No registered users and 125 guests
