Mezzmo 2.1.9 with Sony BDP 370 PAL BR Player
kathat
Post Sat Sep 04, 2010 6:32 am
Mezzmo 2.1.9 http://www.mezzmo.com stream all kind of Video (mkv, avi, etc.) Pictures and
Music to my Sony BDP 370 PAL BR Player.
It is very easy to setup and it works "out of the box" after including the IP of my BRP. There is ne need to
edit files for hours to get a playable result on your TV.
With Mezzmo DLNA Server there are also no problems with exotic Video formats. I never get stuttering, audio
problems or disconnects with my 1080p mkv's.
Fast Forward and Backward in Video is also no problem. You don't loose your audio syncronisation.
In my opinion Mezzmo is a payable and well working solution, to stream all kind of Data for your Home
Entertainment.
Post Sun Sep 05, 2010 6:22 pm
Re: Mezzmo 2.1.9 with Sony BDP 370 PAL BR Player
Did you get your free licence for this?
http://forum.conceiva.com/showthread.ph ... o-for-free!
It must be positive and also contain a link to http://www.mezzmo.com. It should not be an advertisement - it should be an honest review.
:roll:
kathat
Post Fri Sep 10, 2010 8:27 am
No, but thanks for the information.
I will try to get one.....
Belfaborac
Post Fri Oct 15, 2010 11:13 pm
Well, FFW and RWD sure ain't working with Mezzmo here. None of the other stuff you mention has ever been a problem anyway, as far as all the other DLNA servers I've tried are concerned (and that's basically every one available under Windows).
Sounds like a cheap attempt at a free liscence to me, to be honest.
Mezzmo works just fine, but no better than any other DLNA server. In fact, Serviio handles more formats/codecs than Mezzmo here and the former would certainly be my choice of the two. If you absolutely have to use a server that isn't free, I'd say go for Wild Media Server, which is certainly superior to Mezzmo by a long way.
patters
Post Thu Oct 21, 2010 9:03 am
Yep. I used Mezzmo and uPnP Inspector while I was trying to troubleshoot some stuff on PS3MS and I can also say that the poster's claims are rubbish. You cannot FFWD/REW with Mezzmo on the BDP series.
Return to General discussion
Users browsing this forum: zman and 3 guests
