MKV and LG 47LE5500 - Invalid File
Post Thu Jan 05, 2012 2:16 pm
Re: MKV and LG 47LE5500 - Invalid File
Alex Atkin UK wrote:Is there any way I can get information about if it supports transcoding or not?
Sorry don't understand the question (french)
The GetProtocolInfo of your device is interresting, do you try with Generic Profile ?
Alex Atkin UK
Post Thu Jan 05, 2012 2:28 pm
Should the TV announce if it supports transcoded content or not? If so, where can I check for this flag?
That said, it seems it CAN be done as I found mention of it on the Mezzmo forum with someone using it to transcode DTS audio for their 47LW5700, which appears to be another model based on the same hardware as the 5500 and 550T.
Actually I am forced to use the Default profile. Whilever Serviio detects my TV as powered on, it switches the profile back to Default. If I turn the TV off and change the profile it works, until I turn the TV back on.
Previous
Return to LG
