Vimeo
Post Thu Jan 05, 2012 8:48 pm
Vimeo
Requires at least Serviio 0.6.1
Added 5/1/2012
Minor fix 6/1/2012
Fixed playback of videos without HD content 18/1/2012
Fixed the plugin (v2) 28/12/2012
Fixed the plugin (v3) 17/10/2014
Fixed the plugin (v4) 10/12/2015 (needs FFmpeg with SSH support)
Vimeo.groovy
(2.88 KiB) Downloaded 2055 times
jstahl
Post Fri Jan 06, 2012 4:47 pm
Re: Vimeo
I have this groovy installed.
Running 0.6.1 on osx.
Trying vimeo rss video feed: http://vimeo.com/user4577902/videos/rss
No content appear in that online folder.
Console reports:
2012-01-06 11:33:24,107 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://vimeo.com/moogaloop/play/clip:6/36db8b084548947bfa848f23e38b7c15/1325867601/?q=hd. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:272)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:208)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:101)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:344)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:87)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:254)
   ... 2 more
2012-01-06 11:37:25,259 WARN  [ProcessExecutor] Process /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 137! This is a possible error.
Post Fri Jan 06, 2012 5:13 pm
Re: Vimeo
Check if there is this message in your log: Could not work out FFmpeg default User-Agent
Otherwise post ffmpeg -version
jstahl
Post Fri Jan 06, 2012 5:32 pm
Re: Vimeo
Didn't see that warning in the log.
./ffmpeg -version
built on Dec 14 2011 01:44:37 with gcc 4.0.1 (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include --extra-libs=-lpolarssl
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
ffmpeg 0.9
jstahl
Post Fri Jan 06, 2012 6:21 pm
Re: Vimeo
It looks like the groovy isn't generating the correct videoid.
2012-01-06 12:48:42,925 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://vimeo.com/moogaloop/play/clip:2/ ... 2122/?q=hd. It might not play.
I don't think the videoID is 2 in this test case.
Post Fri Jan 06, 2012 9:28 pm
Re: Vimeo
I updated the groovy, install it and try again
jstahl
Post Fri Jan 06, 2012 10:11 pm
Re: Vimeo
Something similar:
Added a RSS feed : http://vimeo.com/revtest/videos/rss
Directory still shows no content.
Console details below
2012-01-06 17:00:40,367 INFO  [PluginCompilerThread] Added Feed plugin Vimeo (Vimeo.groovy)
2012-01-06 17:06:02,947 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-06 17:06:03,048 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-06 17:06:03,158 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-06 17:06:03,160 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-06 17:06:04,702 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://vimeo.com/moogaloop/play/clip:34601202/6d94847edab8c02074f75f9b97920801/1325887563/?q=hd. It might not play.
   ... 2 more
2012-01-06 17:06:04,914 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://vimeo.com/moogaloop/play/clip:34543679/06f9181124b2e8bc36ea8982995eac45/1325887563/?q=hd. It might not play.
   ... 2 more
2012-01-06 17:06:05,073 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://vimeo.com/moogaloop/play/clip:26289832/259fe77efbb8d341782e87ee2fa2ab1e/1325887563/?q=hd. It might not play.
   ... 2 more
2012-01-06 17:06:05,233 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://vimeo.com/moogaloop/play/clip:25877371/d5963ca2c0fb7307207c3d700d01f737/1325887564/?q=hd. It might not play.
   ... 2 more
jstahl
Post Fri Jan 06, 2012 10:38 pm
Re: Vimeo
Actually some videos are working now from vimeo.
I think the problem now lies with the videos that are a different ratio. (tall, not wide)
such as this video.
Post Fri Jan 06, 2012 11:08 pm
Re: Vimeo
ffmpeg works ok for this one..
try replacing this line in the plugin
def videoXmlDetails = openURL(new URL("http://vimeo.com/moogaloop/load/clip:$videoId"), getFFmpegUserAgent())
with
def videoXmlDetails = openURL(new URL("http://vimeo.com/moogaloop/load/clip:$videoId"), "Lavf53.24.0")
jstahl
Post Sat Jan 07, 2012 2:22 pm
Re: Vimeo
Hi Zip,
Didn't seem to make a difference.
All the 'tall' video content does not seem to get indexed as content.
Do you think this is an issue with ffmpeg for osx?
Thanks for the help.
BDM
Post Sat Jan 07, 2012 3:38 pm
Re: Vimeo
Hi Zip,
Installed 0.6.1 and the latest plugins. Alle feeds from VIMEO are showing on Viera but nn of the video's can be played! Something to do with transcoding?
For gear and settings see sign.
Cheers!
Panasonic Viera TX-P54Z1 (2.403) WIRED - Profile: "Toshiba REGZA" | Play Station 3 (4.0) WIRELESS - Profile: "Playstation 3" | OSX LION (10.7.2) | Serviio (0.6.1)
Post Sat Jan 07, 2012 5:53 pm
Re: Vimeo
jstahl wrote:Hi Zip,
try to run
ffmpeg -i "video_url_from_pc5dczc_log"
Use he ffmpeg from Serviio.app bundle.
Post Sat Jan 07, 2012 5:54 pm
Re: Vimeo
BDM wrote:Hi Zip,
Cheers!
Post detailed log. What message are you getting?
BDM
Post Sun Jan 08, 2012 11:12 am
Re: Vimeo
zip wrote:
BDM wrote:Hi Zip,
Cheers!
Hi ZIP, Thanks for your reply! The movies on Vimeo are mostly .MOV or .MP4 which the server "cannot read file". All files show up in the listing and the thumbs are made too.
While all other LOCAL .MOV and .MP4 can be read.
Using the DirecTV HD profile.
Cheers!
Post Sun Jan 08, 2012 1:59 pm
Re: Vimeo
Why not the Viera plugin?
BDM
Post Mon Jan 09, 2012 9:52 am
Re: Vimeo
zip wrote:Why not the Viera plugin?
Hi Zip,
The Viera plugin is not working for my gear. No .MOV / .FLV are transcoded with it.
Or am I doing something wrong here?
Cheers!
JUser
Post Mon Jan 09, 2012 10:45 am
Re: Vimeo
Have downloaded Servio 0.6.1
For Vimeo, I have noticed the following : added rss feeds
http://vimeo.com/channels/streoscopy/videos/rss
and
http://Vimeo.com/channels/hd/videos/rss
The above URL works ; I can see in my Sony TV ,all the videos list and play them also.
But many other channels are not working.
For example
http://vimeo.com/channels/saisouljourns/videos/rss
though this is folder is visible, but could not see any contents.
Could you please compare this rss feed and working rss feed (mentioned above hd or streoscopy), and fix it ? Thanks
JUser
Post Mon Jan 09, 2012 10:58 am
Re: Vimeo
Hello Zip
in my query submitted few minutes back,,
there is a typo:
The Correct URL is
http://vimeo.com/channels/stereoscopy/videos/rss
and not streoscopy" as mentioned in my post.
Post Mon Jan 09, 2012 8:45 pm
Re: Vimeo
works for me. are there any errors in your log?
JUser
Post Tue Jan 10, 2012 2:23 am
Some Vimeo channels are not playing
Thanks Zip for your response.
This is regarding Vimeo Plugin for the folllowing rss feed:
I am able to see the folder in my Sony TV but folder is empty. I am using Windows XP version of Serviio.
Is this problem due to slow internet connection? May be some channels like "stereoscopy" or "hd are retrieved immediately so that their contents appear and the channel like "saisouljourns" respond a bit slow causing this problem?
I am pasting excerpts of the log as follows:
2012-01-10 07:00:24,484 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://vimeo.com/moogaloop/play/clip:33 ... 8992/?q=hd. It might not play.
... 2 more
2012-01-10 07:00:27,078 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://vimeo.com/moogaloop/play/clip:33 ... 8993/?q=hd. It might not play.
Return to Available plugins
