DLNA Device Support Information.
Post Thu Jan 05, 2012 8:58 pm
TOSHIBA DEVICES ONLY PLEASE
I am currently adding more DLNA support information to the serviio wiki and need the help of the users of the Toshiba Devices, please can you provide SINK report for all of your Toshiba devices if NOT listed below.
Current Toshiba devices I have reports for are:
Toshiba Regza WL743
i have attached a howto link and a sample file of how i need the information formated and suplied to make my life easier and get job done faster.
HOWTO: http://wiki.serviio.org/doku.php?id=device_sf
Sample File
LW550T.txt
(1.27 KiB) Downloaded 3461 times
Kind Regards Cerberus
Mods: can we please stick and leave unlocked please
Roderick
Post Mon Jan 23, 2012 7:45 am
Re: DLNA Device Support Information.
Here's the info on the 32SL800A
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_T,
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED
Post Mon Jan 23, 2012 8:02 am
thanks added to wiki.
macgd016
Post Mon Feb 06, 2012 1:53 pm
Here you are, 40WL753 info:
Post Mon Feb 06, 2012 6:12 pm
macgd016 wrote:Here you are, 40WL753 info:
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED
thanks will add to wiki when i have a moment,.
EDIT: Done this comes under the WL series.
kazan
Post Sat May 19, 2012 5:38 pm
Toshiba Regza 42WL863
|Kazan|
Post Sun May 20, 2012 3:51 pm
Thanks, its similar to all other Toshiba TV:
wiki.serviio.org/doku.php?id=devices_format_support
rodolfovento
Post Wed May 23, 2012 8:48 pm
Hi Illico :)
My english is very bad... sorry :(
I have a new TV Toshiba 46TL838 and can access to Serviio for browse my film.
In the pannell control of serviio my TV is classified as Generic DLNA Profile.
I follow yoru guide for discovere the correct information using Device Spy, but my TV dont recognized.
I search in the dlna.org and I found his specifics.
I'm not sure tha help you, but I send you the pdf that contein the specific...
REG88417223.pdf
(125.46 KiB) Downloaded 3273 times
This is sufficent for help you to update serviio?
Bye
Post Thu May 24, 2012 8:11 am
rodolfovento wrote:I have a new TV Toshiba 46TL838 and can access to Serviio for browse my film.
On serviio console, try to force "Toshiba" profile selected (click on profile name).
Could you enable detailed logging (see signature link) and post the result here ?
bibouchat
Post Tue May 29, 2012 8:53 pm
Hi everybody,
here is the support information for the tv toshiba 47VL863
47VL863.txt
(1.09 KiB) Downloaded 3000 times
aff-tar
Post Thu Jun 07, 2012 6:30 am
rodolfovento wrote:Hi Illico :)
REG88417223.pdf
Bye
I had the same issue with 46TL868. The best Serviio profile for now is LG TV/Player (it disables transcoding at all).
mpi
Post Mon Nov 19, 2012 9:40 pm
Just switched TV set to a Toshiba 55VL963F. It has latest firmware 6.9.ED.1
It seems current Toshiba REGZA profile is not appropriate for this set: generic profile seems better as first instance.
I tried to get info from Device spy, but Device spy can not detect this TV set.
Is DEBUG log supposed to provide similar info?
I did enable DEBUG, but could not find any meaningful info out of it.
Would be great if Serviio could do deliver such "spying" info.
Thanks for any help.
888
Post Mon Nov 26, 2012 1:14 pm
my TV is a 40TL963B, and as usual with this series of tv's it is not recognised by serviio or by the upnp tools.
by default it uses the Generic DNLA Profile, which works, apart from not being to play .avi's
when I change to the Toshiba Regza profile, I cant pause or fast forward the vid.
I've attached the DNLA certificate which hopefully you can use to create a profile for the TL series.
great app by the way.....it is so much better then everything else that I've tried.
TL963cert.pdf
(126.09 KiB) Downloaded 2732 times
Post Mon Nov 26, 2012 7:54 pm
888 wrote:Hi,
Thanks,
Could you try with this tools : http://wiki.serviio.org/doku.php?id=device_sf ?
You can try adding this at the end of ./serviio/config/profiles.xml, just before the </Profiles> element
EDIT: change id="Tosh2012"
   <Profile id="Tosh2012" name="Toshiba 40TL963B" extendsProfileId="1">
         <Video targetContainer="mpeg" targetACodec="ac3" targetVCodec="mpeg2video">
            <Matches container="avi" />
888
Post Tue Nov 27, 2012 8:57 am
Thanks Illico, much appreciated.
Unfortunately upnp tools dont detect my TV, so I cant attach the sink file.
I added that to my config - I had to rename "Toshiba2012" to "Tosh2012", as there seem to be a 10 character limit to that field.
Now it can play .avi files - I even added .flv and those can play as well.......awesome.
The only problem is that these two new formats cant pause, fast forward etc. - although I still have full control over .mkv .mp4 .mpg etc.
I've looked through the config file and cant work out why. I assume that .mkv and .mp4 file are being transcoded, as they are not supported directly via the network media player on the TV, and I was going to mimic the .mkv settings in the .avi setup to allow pausing, but I cant work it out.
I'm so impressed with the app, that I'm going to buy a licence right now. This app deserves to be supported.
thanks again for the very fast response.
Post Tue Nov 27, 2012 1:04 pm
888 wrote:Thanks Illico, much appreciated.
Ok.
888 wrote:The only problem is that these two new formats cant pause, fast forward etc. - although I still have full control over .mkv .mp4 .mpg etc.
With this new "Tosh2012" profile, mkv are delivered in native format.
888 wrote:I've looked through the config file and cant work out why. I assume that .mkv and .mp4 file are being transcoded, as they are not supported directly via the network media player on the TV, and I was going to mimic the .mkv settings in the .avi setup to allow pausing, but I cant work it out.
Not sure to understand...
With "Generic" profile or "Tosh2012" profile, mkv should be delivered in native format. Could you confirm that in tis way, mkv are ot supported ?
888
Post Tue Nov 27, 2012 2:45 pm
Hi Illico,
I've attached a section out of the user manual from my tv, which seems to say that the only formats supported over DMS are MPEG-2 PS and MPEG-2 TS. Every other format is supported over the USB port on the tv.
This is what I could not understand in the serviio config file - I couldn't see transcoding for .mkv and mp4, yet they work fine using the default profile.
i'm at work right now, so I cant test the tv, but I am sure when I disable transcoding .mkv and .mp4 stop working. I'll test this when I get home.
Post Tue Nov 27, 2012 2:53 pm
888 wrote:This is what I could not understand in the serviio config file - I couldn't see transcoding for .mkv and mp4, yet they work fine using the default profile..
When you said "default profile", do you mean "Generic Profile" or default "Toshiba REGZA" profile ?
with "Generic Profile" --> mkv are delivered in native format (then with new Toshiba2012 profile too), so if you TV play mkv with these profiles, usermanual is ot uptodate.
with "Toshiba REGZA" --> mkv will be transcoded to mpegts/mpeg2video/ac3 format
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
The best pratice is to use "Generic profile" and try to play sample files in most popular formats then check if they play fine or not, if no, create and edit a profile that transcode this format to one supported by the TV.
888
Post Tue Nov 27, 2012 3:30 pm
Sorry, I meant "generic profile". Everything seems to play well with this setting, except avi and flv. But with the "Tosh2012" addition these play now.
I think you are probably right, in that the manual is not up to date and has the wrong info.
Is there any way to get these transcoded avi files to pause - this is really the only problem I have now.
Thanks for all of the help, much appreciated.
Post Tue Nov 27, 2012 7:51 pm
Good.
Could you try with this profile:
   <Profile id="Toshiba2012" name="Toshiba 40TL963B" extendsProfileId="1">
            <Matches container="flv" />
I only change targetContainer="mpeg" to targetContainer="mpegts".
Return to Toshiba
