Samsung Youtube HD problem
fxandrei
Post Fri Dec 09, 2011 7:46 pm
Re: Samsung Youtube HD problem
So i deleted all the log and wanted to try again to analyze the logs.
And suprise .
IT WORKED :D.
So why did it not work before?
Well my only explanation is that maybe i tried to play a file that i already tried before, and when i did those modifications to the profile, i tried to play the file right away, and probably it played from some temporary file of some sort, that had that high bitrate.
So i guess that fix works.
I can now watch 1080p Youtube on my samsung.
Post Fri Dec 09, 2011 9:36 pm
Or you did not restart Serviio after you updated the profile... anyway glad it works now.
fxandrei
Post Fri Dec 09, 2011 11:00 pm
Nope .. I sure did.
I manually entered in services and restarted the server a couple of times.
But the video was probably from some temp file.
Anyway i edited the groovy now to stream 720p cuz it seems that my pc cannot handle full 1080p transcoding (either that or the wifi n isnt holding up).
But 720p is great for now.
Thanks a lot people.
U are great.
ACE
Post Fri Jan 06, 2012 12:58 am
I have same problem, with 0.6.1. I dont play 1080p videos from youtube. I have Samsung C6000.
Post Fri Jan 06, 2012 1:05 am
ACE wrote:I have same problem, with 0.6.1. I dont play 1080p videos from youtube. I have Samsung C6000.
https://bitbucket.org/xnejp03/serviio/i ... ranscoding
ACE
Post Fri Jan 06, 2012 1:09 am
I did this and it doesnt work. :(
Post Fri Jan 06, 2012 1:17 am
did u restart after making the change ?
ACE
Post Fri Jan 06, 2012 1:24 am
I don't understand, what needs to be change in the profile file?
Post Fri Jan 06, 2012 1:26 am
ACE wrote:I don't understand, what needs to be change in the profile file?
i just gave you a link to what needs changing and you said ud tried that. :S
ACE
Post Fri Jan 06, 2012 1:33 am
I tried, but on that link there is some piece of editable text. And I don't know which one is good.
Post Fri Jan 06, 2012 1:35 am
ACE wrote:I tried, but on that link there is some piece of editable text. And I don't know which one is good.
attach your profile.xml file here and i will edit it for you.
ACE
Post Fri Jan 06, 2012 1:38 am
profiles.xml
(56.68 KiB) Downloaded 772 times
Post Fri Jan 06, 2012 1:53 am
profiles.xml
(56.67 KiB) Downloaded 820 times
ACE
Post Fri Jan 06, 2012 2:03 am
Cerberus wrote:
profiles.xml
It doesn't work. :(
Post Fri Jan 06, 2012 2:08 am
try a different video on the feed not same one.
Post Fri Jan 06, 2012 10:02 am
This ticket is already in the release so no need to change profiles.xml AFAIK. Is there anything in the log?
fxandrei
Post Fri Jan 06, 2012 12:41 pm
zip wrote:This ticket is already in the release so no need to change profiles.xml AFAIK. Is there anything in the log?
nice ...
it would be great if somehow the seeking "thing" could be eventually be figured out.
Great software.
Previous
Users browsing this forum: Baidu [Spider] and 23 guests
